Question about Kitchen Ranges
I have a Jenn-Air counter top (down draft) gas range. I just noticed that one of my burners would not turn on. The stem appeared to be frozen. However, I was able to get it to turn a couple of times, but it did not turn easily. I didn't want to force it, but I can't seem to get it to turn at all now.
  • 1 more comment
  • papawhiskey Mar 09, 2008
    It's the left rear on the grill side. It appears that all of the burner valves work the same way.
    The burner lights when I can get the stem to turn. The problem is I can't get the stem to turn.
    I have a Jenn-Air counter top (down draft) gas range. I just noticed that one of my burners would not turn on. The stem appears to be frozen. However, I was able to get it to turn a couple of times, but the stem did not turn easily. I didn't want to force it, but I can't seem to get it to turn at all now.
    Genius:
  • 3,587 Answers
The 'stem' as you say, is most likely gunked up with grease, etc. you can either try to clean it out with long swabs(only partially effective) or you 'll need to replace that whole assembly.
nods to Micromaster for his good approach
Posted on Mar 09, 2008
  • Patrick Michaels
    Patrick Michaels Mar 09, 2008
    thanks for the vote...you might want to consider cleaning all of them, at the same time..be careful not to soak them or immerse them under water.
    Brigadier General:
  • Kitchen Ranges Master
  • 3,614 Answers
Which burner got the problem?
  • micromaster
    micromaster Mar 09, 2008
    Have you done some double check of the unit or have you investigate or monitor it by yourself, which you have noticed aside from the 1 burner doesn't ignite.
    Any other info.aside from the fact.
  • micromaster
    It's your better option to replaced the gas igniter, it's to risky if you self service or fabricate anything just to make the burners fire-up. Possibly may cause such danger.
    Can you provide me the model and type of the unit, i,m kinda specify which i would start to trace solutions.
. Burners will not work unless the down draft fan is turned on and then neither works at full capacity.I flipped the breaker off and on.
Call Jenn-Aire to have a technician troubleshoot your cook top on site. You will save time and aggravation whether your cook top is gas or electric, possibly wired improperly, etc,etc,etc.
Apr 02, 2015 | Jenn-Air Cooktops
JGC8536
If the front left also does not light normally, my best guess would be that the wires for the front left and right rear are crossed and the insulation may have fried. Besides that possibility, I have no clue.
Feb 14, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Jennair down draft cooktop
hi i have a Jenn air down draft as well you should have a spring loaded flap like a dryer they sell them
separately, you can buy them at home depot or lowes that will stop some of the cold air coming in not all of it.
Dec 14, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Burner controls
if you remove the knobs from the unit nad look closely doen the shaft of the protruding valve stem you should be able to see a slot for a regular screwdriver to fit down, its gonna have to be long adn thin but that is the flame adjustment screw,
put the flame down to low and use a pair of pliers to hold the valve stem from turning as you try to adjust the screw, turn it very slowly you seel an adjustment happen (dont really know if its counter clockwise or clockwise, but youll figure it out playin gwith it for a bit, just remember to hold the shaft from turnig, and although your turninf the valve down to simmer it does not afffect the high setting
Apr 06, 2008 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Older 6 burner wolf commercial range ignition problem.
If it were the gas regulator, existing flames would go down as more burners are turned on.
There are set screws on the pilot fittings that come out of the manifold, you could try turning those Counter-clockwise to turn the pilots up. (Don't loosen them all the way, they will fall out!) If that doesn't work chances are the pilot stems will have to be replaced to get a higher pilot flame.
Mar 07, 2008 | Wolf Range CHR-10-229-FT11 Kitchen Range
Jenn air pro range 36" prg3610np
hi after the burner ignites turn knob until it stops trying to ignite thanks
Jan 07, 2008 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
Burner Problem
it appears that the air intake intake is incorrectly set or you have the incorrect gas jets fitted to the product. Regards Engineer
Jun 11, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
