Question about Dryers
Amana electric LEA10AE dryer
Quit drying. When I took it apart, there is an orange wire that runs from the front, (blower unit?) to the element unit. Pulled element unit out and realized the orange wire on element end is fried. So something went haywire. Would it be the little component that the wire plugs into on element end? Or??? I fixed the wire but still have no heat.
Thax in advance for the help.
Jewell
    President:
  • Dryers Master
  • 2,651 Answers
Usually that wire "fries off" with bad connection, ify ou can check for contionuty through the components on the heater you find the problemUsually the thermostat with the box like stand off mounted to that back wall.(also ck to make sure your breaker(s) didnt pop
Posted on Mar 09, 2008
WD 9900 does not dry
Most all dryers, including combo washer/dryers, have an electric wire coil for a heating element.
I suspect yours has given up ( they usually break in two, stopping the electrical flow). You should need to have the element replaced.
Going to need to take the whole machine apart to fix this.
Be blessed.
Apr 17, 2013 | QuietLine WD-9900 Front Load Washer /...
Heating element quit working on my frigidaire affinity dryer
If the unit still works, it just does not dry, please have a professional diagnose the heating element and the blower assembly. Either, or, could be faulty at this time. This is not a typical DIY job so please consult a professional.
Sep 19, 2012 | Frigidaire Affinity AEQ6000WH Dryer
Having heating problem with Roper REX4634JQ0 dryer?
probably have a weak hi-limit thermostat on the element housing or cycling thermostat on the blower housing
Apr 26, 2012 | Roper Dryers
How do i fix a duet dryer that takes too long to dry
I pulled apart the back of my dryer to access the heating element. I noticed I have a break in one of the coils. So, that means I need to buy a new one. The thing I noticed is that only of of the terminals at the bottom of the heating element has a plug on it. There are no additional wires inside the dryer that could have come off so I am a little confused as to if i new coil will work.
I watched a video online and it clear shows both terminals being connected. Anyone have any advice?
Feb 20, 2012 | Whirlpool Duet 3.8 cu. ft. Front Load...
1. Initially had power to Interior Blower Unit 2. Blower Fan quit running and then lost power to unit. 3. Troubleshoot'n done: a. Wall power supply is good b. Conductivity check on plug =...
Assuming that this is a personal AC as opposed to industrial blower unit, see if you can manually spin the blower with the unit supposedly ON and running. Wear eye protection. It's possible that the motor burned out; there are LOTS of tiny wires in the motor coils.
Jul 16, 2011 | Heating & Cooling
Dryer stopped in middle of cycle back was very hot let cool down tried to restart nothing after much playing around bypassing switches and such determind thermal fuse was shot ( pulled off wires and...
I'm assuming the thermal fuse you bypassed is the small one on the right hand side of the element case. Part # LA-1053. Comes with new safety t'stat also ( the one above the element). Use both. T'stat on blower housing is the cycling t'stat. Unlikely to cause problem. You need to determine what caused the failure. Most often themal fuses fail due to improper airflow. What kind of venting does your dryer have. Vent connector from dryer to wall should be rigid metal or heavy metal flex. I see alot of foil venting sold by DIY stores, but not approved by dryer manufacturers. Easy way to check is to start dryer with vent attached, hold top up a couple of inches and look at element. It should glow soft orange. If element is very bright, red hot to white, then remove venting from the back and see if element glows less bright. If there is a noticeable difference then you will need to correct airflow problem or thermal fuse will blow again. Also check lint filter by putting in sink and running water thru it. If it holds water then scrub it clean even if it doesn't look stopped up. Fabric softener sheets leave a wax coating on the filters.
Jan 12, 2011 | Maytag PYE2300AY Electric Dryer
Unit only works upside down!
there is a water level next to the ocilater make sure that the canal is clean. try some water and vinegar
Apr 07, 2009 | Venta VS 100 Humidifier
My blower motor stopped working, front and back of van.
My rear blower motor stopped working and my Brother took the unit apart. He found out that the fan blade had seized up the unit. After he took out blade and sanded down blades, it worked fine. However, I am not sure about your front unit. Good luck.
Jan 18, 2009 | 1997 Ford Econoline
FEX831CSO dryer stopped heating mid-cycle
Apr 22, 2010 My dryer would not dry the clothes either. the heating element would only come on once then nothing. The high limit thermostat was bad. Pull the electrical plug. Remove the top cover and the thermostat has an orange/black wire to it. It is hard to get to the screws but I was able. Then I found the element would cycle many times but not stay on long enough to dry the clothes thoroughly - I found the culprit - the motor driven fan creats a suctionin the drum and the hot air from the rear coil is pulled thru the drum, thru the front door (via the holes in the door's inner face) down thru the lint screen, thru the outer fan housing and out the exhaust. My problem was that the door's cardboard backing had seperated and along with the trapped lint clogged the door's holes and restricted the air flow. I took the door off, seperated the 2 halves, removed the cardboard and cleaned the lint out. The dryer is now working like new. Summary: The high limit thermostat was bad probably from cycling so much and the air flow diminished slowly over time to the point I did not notice until the clothes just wouldn't dry. Check the air flow first. Hope this helps
See less
Dec 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Question about kenmore dryer
Most heat related problems associated with long dry times are contributed to clogged ventilation. A dryer needs proper air flow to dry efficiently. If the external ducting is clogged, this will cause the internal heating circuits to actually overheat to the point of failure. If your dryer is heating, but simply taking a long time to dry, I would recommend a thorough cleaning of all ducting.
An easy way to determine if you have restricted air flow somewhere is to simply remove the vent house from the back of the dryer and attempt to dry a load as you normally would. The air flow coming from the dryer should be forceful and warm (about 140 degrees F on most dryers). If it is, I would begin an inspection of your ducting from the point where it enters the wall, to where it exits your home. Rule of thumb: The SHORTER and STRAIGHTER the vent ducting, the BETTER. If you have ventilation that runs up the wall and into an attic, runs under a crawl space, or has excessive bends or kinks, all of this can contribute to creating chokes points where lint can accumulate and cause more resistance on the blower. In a nutshell: it reduces the dryer's efficiency.
If the air flow coming out of the dryer is weak, you need to inspect the internal ducting where the blower fan is. If the air flow is cold, you more than likely have a blown thermal cut-out (safety thermostat), or heating element. On your model dryer, the heating element and TCO are located behind the drum. If both components are good, you should be able to see the element glowing through the holes in the back of the drum and feel heat.
Read through the advice I've given and let me know what your symptoms are. Hopefully this is just a simple air flow problem. NOTE: DO NOT run the dryer for extended periods (meaning days or weeks) with the vent hose off. This will cause the humidity level in your home to increase, along with the temperature. Which can lead to mildew. I hope this information is helpful. Let me know if I can be of further assistance.
Sep 21, 2008 | Kenmore 62872 Electric Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
Marvin
Marvin
