Question about Panasonic AG-DVC30 Mini DV Digital Camcorder
Only one channel when using my xlr adapter in AG-DVC30
Every time I try to use my XLR adapter I only get one channel, please help? Regards
  • 78 Answers
XLR cables only carry one channel. There is an option in your camera to split into two channels - enable it, or split into two channels in post. To record left and right from the DVX using XLR cables, you'll need one for left, and one for right.
Good luck.
Posted on Apr 08, 2008
Can you get an adapter to run 5 microphones. Channel 5 does not have a mic jack. Is there an adapter to plug to a mic that will connect with this channel?
What I think you are looking for is an XLR to 1/4" adapter. This will let you plug a standard mic cable into a line in or 1/4" channel. You can find them online pretty easliy if you search xlr to 1/4 adapter.
Hope this helps!
Jun 22, 2011 | Audio Players & Recorders
My external mic wont work! Please help.
If the mic is working on other camera's, what about the adaptor ? If there is a possiblity of checking the mic and the adaptor together on other equipment ? Use another mic with the same plug as the camera, ie. PC microphone (you can even test by using an earphone, the earphone can be used as mic) If it works then the XLR mic with adaptor is the problem. If ther other mic (used for testing) also did not work then the microphone jack (socket) in the camera is defective or the gain setting of the camera is set to minimum.
Jun 05, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Would like to use with a mac computer but it does not have a USB cable. Please let me know if it could be done. Thanks.
This is because this microphone has an XLR audio connector for output. YOU CAN'T USE THIS CONNECTOR FOR THE USB PORT since the XLR is an audio type connector while USB is a data type connector. You might use a cable with XLR female at one end and 3.5mm jack like this one with mono jack at the end (not stereo as the amazon's link) and connect this cable at the microphone and at the sound card of your computer. The quality with this solution won't be very good, it depends on your audio card. A better solution is to use XLR-to-USB-Signal-Adapter/dp/B001PPXFAG/ref=sr_1_16?ie=UTF8&qid=1290885531&sr=8-16">this adaptor or equivalent in order to connect the mic on the adapter and the adapter with a USB cable at your computer. It's a better but more expensive solution.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Nov 27, 2010 | Samson R21S Microphone
How can I connect my mackie mixer 1202-vlz3 to my mac mini
use the xlr (3 prong) main left and right outputs of the board. get xlr to 1/4 inch cables. one end will be 3 prong, to plug into the mixer, then the other end will be a mono 1/4 inch plug, like a big headphone plug. Then you have to get a dual mono 1/4 inch to stereo 1/8 inch adapter and plug it noto the line in. if there is no lone in, but a microphone jack instead, you will get a mono signal instead of a stereo signal. in this case, just use 1 channel of the mixer, instead of both of the stereo outs, and use a single mono 1/4 inch to mono 1/8 inch adapter.
the xlr to 1/4 inch cables can be purchased at a music store. the 1/4 inch to 1/8 inch adapters will probably need to be purchased at radio shack.
Nov 03, 2010 | Mackie 1202vlz3 12 Channel Mixer
I need to know how to wire an xlr y adapter
I always solder it this way.
Take a female XLR connector, two thin sym. cables and two male XLR connectors.
Solder both cable parallel in the female connector and the ends on the male connectors.
This way you get the same signals on both inputs of your amplifier.
Regards,
Gerard
Oct 26, 2009 | Behringer EUROPOWER EP2500 Amplifier
Crown amp xs900 will not reset
naz, get a hold of crown, tell them whats up. check all fuses and connections first. the unit is worth $900.00. they should be a little understanding.
Features
  • 2-ohm dual (per channel) : 1200W
  • 4-ohm dual (per channel) : 900W
  • 8-ohm dual (per channel) : 600W
  • 4-ohm Bridge : 2500W
  • 8-ohm Bridge 2100W
  • Indicators for : Signal, Clip, Power, AC Mains, Fault, Bridge, Temp.
  • Housed in a rugged, all-steel 2U chassis
  • Microprocessor-controlled protection system.
  • Flow-through ventilation from front to back.
  • Internal heat sinks with forced-air cooling for rapid, uniform heat dissipation.
  • EIA Standard 19-inch rack mount width
  • Safe with all types of loads.(2 to 8 ohms in Stereo, 4 to 8 ohms in Bridge Mono.)
Inputs
  • XLR-¼" combo connectors: One per channel
  • 3-pin female XLR connector and TRS ¼" phone jack accept balanced or unbalanced signals.
  • 3-pin Phoenix-style connectors (2-channel models only),One per channel, accepts balanced or unbalanced signals.
Output
  • Balanced XLR connectors (2-channel models only)
  • One per channel, 3-pin male XLR connector in parallel with XLR-¼" combo and Phoenix-style input connectors for daisy-chain operation.
  • 5-Way binding post output connectors: One pair per channel; accept banana plugs, spade lugs or bare wire.
  • 4-Pole Speakon output connector (2-channel models only)
  • Accepts a 4-pole Speakon connector.
Dec 31, 2008 | Crown XS900 2-Channel Amplifier
Connecting a guitar amp to a mixer amp
Hi cliff
Connect either of the XLR DI output of the Behringer directly to a MIC IN channel on the Powerpod using a standard Microphone cable. If you wish to push a stereo sound then connect both(L + R) of the XLR DI outputs from the amp... that's about all you need to do. The only reason you need to use stereo(both XLR Outs) from the Behringer is if you want a full stereo FX output from the amp, otherwise you can get away with 1 connected. You may need to back the gain off for those channels on the power pod. You can get a manual for the Powerpod from here
and user manual for the acx900 here
Hope this has helped you, If not, feel free to ask any questions. Cheers.
regards
robotek
Aug 08, 2008 | Phonic Audio Players & Recorders
Intermittent audio problems from mic jack
This camera has a history of problems with the audio encode/decode process IC which causes loss of audio input and distorted audio processing. Most noticeable is the loss of audio packets in playback of pre-recorded material.
If your problem is in the mic. jack I believe you would be hearing the buzz while monitoring with the headphones. Also, if the camera has been dropped, the audio I/O board connector can break away from the main board causing a bad ground loop or loss of phantom power, this is a common problem.
Hope this helps in some way,
Joe Weibel
customelectronics.org
Jan 31, 2008 | Panasonic AG-DVC30 Mini DV Digital...
Need of codes....
Hi I hope this will help http://www.dvcentral.org/tricks.html Tricks 4 XLR ins: Get the Canon MA-300 adapter and get yourself 4 XLR inputs. Perfect for a couple of wireless lavs, a boom, and another mic. Sure, it's less data for the audio channels, but it's plenty for voice recording. Sure, you can't digitize audio 3&4 easily, but it is possible, and it's just so darn useful to have four audio channels in the field. (Also, you can easily mount the wireless lav receivers right on the back of the camera.) Using the Canon on-camera mic via an XLR input: Say you're using a single boom mic, inputting via XLR 1. You've got XLR 2 doing nothing, and the on-camera mic doing nothing. Seems a waste. Well, all you need to do is adapt the on-camera mic to input through XLR 2. A short female-mini-to-male-XLR adapter will do for the audio signal, but the mic needs power. Simple, just get a short micro-mini extender cable, plug one end on to the mic, and the other into where the mic's connector would normally plug, on the camera's handle. Make sure the mic is switched to stereo, and voila, you have a second XLR mic. Monitoring in the field: Though many people told me it couldn't, the XL H1 downconverts to NTSC on the fly during recording, so you can plug a little monitor or deck into the video and audio out jacks and have yourself a video tap. Perfect for the director who wants to see what's going on through the camera. I used a little DV camera, and recorded it all so we could have a playback tape if needed. Very useful. (Note that the output NTSC is anamorphic, stretching the 16:9 image over the whole 4:3 frame. A monitor with a 16:9 switch is useful, or something that automatically adapts, such as what I used, a Sony PD-100 DVCAM camera.) Native slow motion: In a 24F project, shoot 30F and use Cinema Tools to slow down the footage to 24fps for a slight slow motion effect. Use 1/60 shutter speed for a standard look, or 1/30 for a slightly dreamier feel. Good Luck.
Sep 15, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Panasonic AG-DVC30 Mini DV Digital Camcorder Logo
85 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
