Question about MSI MS-6734-10 (-6734-010) Motherboard
Omg msi 2600+ ....how to reset bios?
I have takin cell out and power. waited 2 days came back no workie. no display. i have changed the graphics card (agp nvidia 4400 to palit 4400) it has onboard but no workie.
  • 34 Answers
Replace the cell and the reset your bios settings it will work for you .
Posted on Mar 09, 2008
Adding discrete graphics card to p6stp-fl
!O_O!
1) Unplug the computer from power.
2) Press the Power On button in, and hold it in for a count of 10 seconds. Let go. (HAS to be 10. Count)
Do this same procedure TWO more times.
(IF the Power On LED flashes for a second, keep repeating until it doesn't)
What you are doing is clearing CMOS Error Codes, and resetting BIOS Setup parameters back to the factory default settings.
3) FOLLOWING Anti-Static Precautions remove the graphics card.
Plug the monitor back into the Integrated (OnBoard) graphics, of the motherboard. (VGA connector)
4) Plug the computer back into power. WAIT 1 minute, turn the computer on.
5) When Windows has loaded wait a couple of minutes, then take that graphics card's Installation (CD) Disk, and put it in the optical drive.
If the disk doesn't start loading after 10 seconds, go to My Computer, and double-click on the drive letter, next to the optical drive, the Installation Disk is in.
When asked choose all software. Nvidia Control Panel, and drivers.
Your computer will keep on using the Integrated (OnBoard) drivers, for graphics. It will Not use the drivers, and software you are installing now, until the graphics card is physically installed.
Install all software. If you are asked to restart your computer -> NO
Close all windows, go back to your desktop screen.
Turn the computer off normally.
(Start > Turn Off Computer > Turn Off)
6) Unplug from power, follow Anti-Static Precautions.
Unplug the monitor from the motherboard. Physically install the graphics card.
Plug the monitor into the graphics card. Close the computer case.
7) Plug into power. WAIT 1 minute, turn the computer on.
You may have to go into Nvidia Control Panel, and set the correct parameters for your monitor. (Screen Resolution / Color quality )
Clear CMOS Error Codes, and reset BIOS Setup back to factory settings doesn't work?
You get to go back into BIOS Setup, and set the submenu you changed, (Or submenu's), back to the factory standard setting.
(F6?)
You are trying to use the OnBoard graphics drivers for the -> graphics card. This = NO.
You need THE drivers for the graphics card installed F-I-R-S-T.
(OnBoard. ON the motherBOARD.
Used to be used for Integrated Graphics.
Makes it easier to understand if you use OnBoard Graphics )
Why?
When a device, (In this case a graphics adapter card), is installed, Windows 'breaks it's neck' to find suitable, matching drivers.
If THE drivers are not there, Windows will match up one of it's THOUSANDS of generic drivers.
This = No.
You need THE drivers already installed. Windows looks to see what device is installed, then finds THE drivers needed.
Regards,
joecoolvette
Sep 13, 2012 | EliteGroup P6STP-FL Motherboard
Ihow to boot up and get display and set bios on msi motherboard g41m-e43
Add one item at a time.
First memory, then graphics card.
Plus you cleared CMOS Error Codes, and set the BIOS Setup parameters back to the factory default settings.
Guess what the default graphics setting is for an MSI G41ME43 motherboard?
Yep, AGP.
http://www.msi.com/product/mb/G41M-E43.html
[Wow, I like MFlash, and the solid Polymer capacitors.
Live BIOS Update 5, and Easy OC Switch.
However if the motherboard fails, I'll bet the Integrated Circuit, (I.C., or 'chipset'), that controls APS, is the first electronic component to go.
I would also watch OC'ing. Has to be done in incremental steps. Automatic feature or not. A 20 percent boost is A LOT.
Hardware components have as tendency to heat up.
Watch it as this lowers the 'life expectancy' of the chips.
Heat - 'Kills' ]
http://www.msi.com/product/mb/G41M-E43.html#/?div=Detail
Motherboard chipset:
Northbridge is an Intel 82G43. Southbridge chip is an Intel 82801GB part number. (ICH7) You can't see them as they are under Heatsinks.
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
Scroll down.
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Southbridge_9xx_and_3.2F4_Series_chipsets
Ram Memory:
Two ram memory slots for Dual Inline Memory Modules on the motherboard. (DIMM)
A) UNBUFFERED
B) 1.5 Volt (DC)
C) DDR3 Sdram at either 800MegaHertz, or 1066MHz.
[ This puzzled me. DDR3 Sdram at 800MegaHertz?
Why would anyone want to use DDR3 Sdram at 800MegaHertz?
Seems to me going backwards.
Faster frequency rates.
Low end for DDR3? 1066MHz.
High end for DDR2? 800MHz.
DDR3 is faster in comparison to DDR2 per se, because of the prefetch buffer. 8 burst deep compared to DDR2's 4 burst deep.
(Or DDR's 2 burst deep)
Not because of the CAS Latency, though.
DDR3 has a much higher CL, than compared to DDR2.
(Average CL for DDR3 at 1066MHz = 7-7-7-20
DDR2 = 5-5-5-15. Note* -> A-V-E-R-A-G-E. )
When using DDR3 Sdram at least use 1066MHz, IMHO
The maximum ram memory frequency rate, that your motherboard will support ]
So what manufacturer of ram memory is it, and what is the manufacturer code of the ram memory module/s? ('Stick')
JEDEC sets the standards for Ram Memory.
Voltage standard for DDR3 Sdram ram memory is 1.5 Volts (DC)
So the factory default setting is 1.5 Volts, for the motherboard.
However your motherboard supports SPD.
(Serial Presence Detect,
http://en.wikipedia.org/wiki/Serial_presence_detect )
Point of the above?
If you are trying to use high-performance ram memory; say one needing a slightly higher voltage, and/or has lower CL ratings; then the SPD on the motherboard may make automatic adjustments.
(Adjustments to the parameters in your BIOS Setup)
May take 2 to 3 'Cold Boots', though.
(Turn the computer all the way off. Wait 1 minute. Turn the computer back on = Cold Boot)
I order for SPD to work, BOTH the motherboard, AND the ram memory, have to have SPD feature.
If the ram memory is too low in quality, (Read cheap), it may not have SPD.
Means you have to go into BIOS Setup, and set the ram memory parameters, manually.
[ Delete key to enter BIOS Setup.
Main BIOS Setup menu > Cell Menu > Memory Z > Advance DRAM configuration >
1) DRAM Timing Mode
2) CAS Latency
3) tRCD
4) tRP
5) tRAS
6) tRTP
Don't forget you have to SAVE changes, or it will be as if you have done nothing at all.
If a mistake is made;
Go back to BIOS Setup, and in the Main menu, use the Down Arrow key to arrive at Load Fail-Safe Defaults. IF -> OK is 'highlighted' (Black surround) press the Enter key. If not, use the Right Arrow key, or Left Arrow key, and highlight OK ]
The ram memory also has to be UNBUFFERED.
Unbuffered ram memory is the opposite of Registered ram memory.
Registered ram memory is more stable, usually one clock slower, and more expensive, than compared to unbuffered ram memory.
Registered ram memory is usually used in SERVER computers.
(A Server computer may look at information 2 or 3 times, before it acts on it. It needs to be C-O-R-R-E-C-T for a server computer )
"Cleared the board i believe"
Turned the computer off? Unplugged from power? Pressed the Power ON button in, and held it in for a count of 10 seconds? Then let go of the Power On button, then performed the entire procedure again, 2 more times?
{Clears CMOS Error Codes, and resets BIOS Setup back to the factory default settings}
You MAY have cleared the motherboard. It's what I use, and have recommended for years on the 'net. Doesn't mean it always works, though. Sometimes you just have to go into BIOS Setup, and set the parameters back to the factory default settings.
(For you? Load Fail-Safe Defaults )
A) Won't boot:
Because the ram memory is the wrong one, (Or ones); OR, the ram memory is high performance, and BIOS and SPD hasn't recognized it yet.
Remove the graphics card.(Computer unplugged from power. Anti-Static Precautions FOLLOWED!)
Remove the ram memory.
Reinstall the old ram memory, and plug the monitor into the VGA port, in the I/O area on the back of the computer tower.
Just get the computer working again. After about 10 minutes of fooling around on the computer, ('net?), turn the computer off.
Install the new 2GB.
(IF, just one ram memory module, be SURE to put it in Slot 1.
{DIMM 1} The ram memory slot closest to the Processor )
Leave the computer case open. You may be going back in pretty soon. (Graphics card)
WAIT 1 minute, then turn the computer on.
Joy?
If no joy shut the computer down. (Press the Power On button in, and hold it in for a count of 10 seconds)
If it doesn't work this time, you may wish to try it again.
Sometimes takes 2 to 3 times, before the high-performance ram memory is recognized.
You can also go into BIOS Setup, as mentioned, and physically set the ram parameters.
After 3 times I would give up however, and send the ram memory back. Wrong one/s.
If you get the new Ram Memory working, Cool!
If not remove it, and use the old ram memory.
Might as well get the computer going with the new graphics card, while you wait on the proper ram memory to arrive.
Did you plug the monitor into the graphics card?
Sometimes we computer geeks get in a wee bit of a hurry, when we get shiny new parts. Make sure the monitor cable is plugged into the graphics card.
There is another tiny thing; DRIVERS
If you did not use the Installation Disk (CD) first, THEN physically installed the graphics card, you are Wrong.
OR downloaded the drivers from EVGA.
What happens if you physically install a graphics card, THEN come back and install the drivers?
Most of the time a Driver Conflict.
Windows: "Which drivers do I use? These or THESE?"
Also sets BIOS Setup to the correct graphics aperture.
With the computer set back to the factory default settings, and the monitor plugged into the VGA port on the motherboard, you can get Windows running, and install, or download AND install, the Drivers.
ONCE the drivers, (And user interface -> Nvidia Control Panel), have been installed, you can then physically install the graphics card.
[Again; If you download the drivers, do NOT forget you have to go to where they are downloaded, and DOUBLE-click on the file, then use the Installation Wizard. (Or double-click on the .exe file)
INSTALL them! ]
Drivers installed, close all windows, go back to your desktop screen.
Turn the computer off. Unplug from power. FOLLOW Anti-Static Precautions. Physically install the graphics card. Plug the monitor into the graphics card. Plug the computer back into power. WAIT 1 minute, turn the computer on.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 06, 2012 | MSI G41ME43 Motherboard
How to reset bios on a msi g41m-p26
on the board is a jumper right above the pci slot (blue) with the pc powered off, move the jumper to pins 2 and 3, then wait 5 seconds, then move it back to 1 and 2. your bios is now reset :)
Jan 01, 2012 | Computers & Internet
I WANT TO UPGRADE THE GRAPHIC CARD ALSO THE RAM CAN YOU PLEASE TELL WHICH GRAPHIC CARD AND RAM WILL WORK ON MY MOTHERBOARD? Model Name : 8LD533 M/B Rev : 1.X BIOS Ver : 6.00 PG Serial No. :...
  1. Memory Type:DDR266( PC2100) 184 pin (2.5v)
  2. 2 x DIMM
  3. Max capacity: Up to 2 GB
Expansion Slots
  1. 3 x PCI (PCI 2.2 compliant)
  2. You can only used PCI graphic card not PCIE Graphic card
  3. PCI graphic card is hard to find now but you can try to find at any computer surplus shop
May 22, 2011 | Intel Motherboard
My msi p55-gd55 doesn't post and I don't get any video
Your board didn't come with on board video so, you must have a video/garphics card? Need make, manufacturer, and model of card for graphics. It comes with three PCIe slots.
Apr 06, 2011 | MSI P55-gd55 Desktop Motherboard - Intel...
Problem With Nvidia 8400 SE Graphics card
Try reflow technique.
It could work.
Its might be a GPU problem.
It can be overcome by doing reflow technique.
You need to do following.
1. Uncover ur PC casing
2. Locate the nVIDIA PCI-E Card.
3. On the card, locate the power supply pin of GPU fan.
4. Remove the pin.
5. Switch on ur PC.
6. Still u may get scrambled display/wavy screen, but wait for 5 minutes.
7. Press reset button on ur PC.
8. Ur PC might work.
9. Switch it off.
10. Connect the power supply pin back as it is.
11. Power on ur PC.
thats all.
Removal of fan power, makes the GPU to get high heat, it a reflow technique.
Remember, not to touch the GPU portion (heat sink), as it may be in higher temperature.
Try this, it works most.
Clarifications:
gnaveendra@gmail.com
May 21, 2010 | Nvidia GeForce 7200 Graphic Card
I change my video card settings in Bios to AGP, after that, i already installed my video card, but no display appeared, ican't restore my video card setting to previous settings because my monitor has no...
if you still have old video card remove the new one and replace with old one
change setting back in bios
then reinstall new card and instead of changing through bios just start computer it should automatically change settings for you
please let me know
May 03, 2009 | Computers & Internet
BIOS won't start
what u can do is to try reset the cmos on your motherboard,
the instructions are in your motherboard guide
or go here:
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=1524
Jan 01, 2009 | MSI K9N2GM-FIH Phenom Socket AM2+ 2600 MHz...
HOW TO DISABLE MY ONBOARD GRAPHIC CARD??
For user BIOS21 & julio1963,
How to enable you're (Add-in AGP video card) & disable the onboard, integrated S3 graphics UniChrome 2D/3D PCI graphics card.
Enter you're bios. Open you're user manual to page 3-13. Integrated Peripherals. Go to, Init display first. Set to AGP.
(Not to PCI). That is all you need to change. The MSI bios will than see you're add in AGP card & automatically disable the PCI S3 graphics, (Onboard) card.
Enjoy!
If I can help you further, feel free to post here.
Please, each user's vote this issue as a fix, if this helped you to get you're bios to see you're new AGP graphics cards.
Mike
May 31, 2008 | MSI KM4M-L Motherboard
MSI MS-6734-10 (-6734-010) Motherboard Logo
250 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
