Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
No sound microsoft kernel audio mixer
Muy computer lost a sound even i re format it still the same problem the kernel audio mixer is missing cannot update or install why? i already use my mother board CD installer but still not functioning still no sound pls. help me
  • Anonymous Mar 26, 2008
    I'm not sure if my problem relates to the kernel audio mixer. The messag i keep on getting is no audio device found & no audio mixer present. I've seen some advice about going into systems and putting sound on automatic but found mine already on. Other advice found relates to a control panel printer and other devices route which leads to an add hardware prompt, which leads no where as there is none. I dont think it has anything to do with soundcard, I know nothing of mine and others have said thiers wasnt the problem elsewhere.. I was wondering if anyone over the years has found any solution to this or many solutions. I am looking for a solution for this problem for xp proffessional.. I would appreciate any help relating to this please. Thankyou
I dont no???
Posted on Mar 11, 2008
Fix kernel dell xp
There are several different ways that kernel.dll errors can show up on your computer. Here are some of the more common ways that you might see kernel.dll errors:
  • "Kernel.dll Not Found"
  • "This application failed to start because kernel.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\kernel.dll"
  • "The file kernel.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: kernel.dll. Please install [APPLICATION] again."
Kernel.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the kernel.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Kernell.dll Errors
Kernel.dll errors are caused by situations that lead to the removal or corruption of the kernel DLL file.
In some cases, kernel.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Kernel.dll Errors
Important: Do not download kernel.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of kernel.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the kernel.dll error.
  1. Restore kernel.dll from the Recycle Bin. The easiest possible cause of a "missing" kernel.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted kernel.dll but you've already emptied the Recycle Bin, you may be able to recover kernel.dll with a free file recovery program.
    Important: Recovering a deleted copy of kernel.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some kernel.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the kernel.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the kernel.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the kernel.dll file. If the kernel.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the kernel.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to kernel.dll. If, for example, you're receiving a "The file kernel.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The kernel.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if kernel.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the kernel.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The kernel.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause kernel.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual kernel.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair kernel.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid kernel.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the kernel.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the kernel.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any kernel.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To
The kernel.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 8, Windows 7, Windows Vista, Windows XP, and Windows 2000.
Sep 12, 2013 | Microsoft Windows XP Professional for PC
I format my computer n i reload all the program but sound lost . what i do now ?
Most likely you are missing the audio drivers for your computer. Depending on the type of computer, go to that manufacturers website and go to the support section. Then in drivers and downloads, choose the type of computer you have and download the audio drivers. For example, if you have a dell computer, go to
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
and choose your model, then download the audio driver it gives you.
May 01, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Where can i get a driver for kernel wave audio mixer, my pc has n
Hello :
You can download it from your motherboard's manufacturer website .
If you provide more details about your motherboard maybe I can help you better .
good luck .
please rate !
Apr 03, 2010 | Microsoft Windows Media Player
Sound problem
Hello....
No Sound, No Volume Control, Mixer not Found, No Sound device installed…etc etc, This is a generic issue with all Windows OS updates....many of the users are facing this issue....this issue began after an auto update from MS changed many IRQs of Win OS, mainly the Sound and Audio Control system of Windows.
1 - R U facing NO Audio / No Sound issue...?
2 - Is ur Volume Control not responding ?
3 - Is ur Sound and Audio Device in Control Panel Grayed out ?
4 - Do u get a msg "No Active Mixer Devices Installed....when u try to open Volume Ctrl etc etc ?
If ur ans to any one of them is Yes...then u are being spammed by Microsoft....as ur Sound Control IRQ is being frozen by a recent update from Microsoft....
NOTE..THIS…IS…VERY..IMPORTANT...
No file update or any sound driver update can fix it, neither Microsoft is issuing any patch to fix it…or giving any help on this.
Full solution is available in my website (Support page)...it's quite simple process to fix it, and I am not charging any money, just trying to do some service and help everyone affected by this stupidity from Microsoft.
www.sureshayyar.110mb.com
visit my support page.
all the best...
Jan 03, 2010 | AOC LM 520A 15" LCD Monitor
Lost all sound... can't do anything on the computer at all. Have to hookd up my ipod to the back of the computer to listen to music. Some where with installing this and Sequel 2 it has removed my sound.
Hello....
all the best...
Dec 30, 2009 | M-Audio Fast Track External Sound System
My laptop doesn,t have an audio after formatting..help me with this.. my technician format my laptop, i mean notebook..blue yung tatak..it's made by toshiba..after formatting, all the audio even the...
Hello....
No Sound, No Volume Control, Mixer not Found…etc etc, This is a generic issue with Windows OS....many of the users are facing this issue....
1 - r u facing NO Audio/Sound issue...?
2 - is ur Volume Control not responding ?
3 - is ur Sound and Audio Device in Control Panel Grayed out ?
if ur ans to any one of them is Yes...then u are being spammed by Microsoft....ur Sound Control IRQ is being frozen by a recent update from Microsoft....NOTE IMPORTANT...no file update or any sound driver update can fix it, neither Microsoft is issuing any patch to fix it….
Full solution is available in my website (Support page)...it's quite simple process to fix it, and I am not charging any money, just trying to do some service.
www+sureshayyar+110mb+com
Copy the above address in the browser, replace + with dots
all the best...
Dec 21, 2009 | Toshiba Satellite Laptop with AMD Athlon...
No sound, computer says no sound device
Hello....
if ur ans to any one of them is Yes...then u are being spammed by Microsoft....ur Sound Control IRQ is being frozen by a recent update from Microsoft....NOTE..VERY..IMPORTANT...no file update or any sound driver update can fix it, neither Microsoft is issuing any patch to fix it….
Copy the above address in the browser, replace + with dots...
all the best...
Sep 26, 2009 | Inland ProSound 2000 Computer Speakers
Audio Driver Problem
i guess some of your device drivers were corrupted. what I can recommend you is that you reinstall your windows XP with an "R" (stands for repair) option (which will rebuild your OS without losing any of your files and settings).
Jun 26, 2009 | HP Compaq d530 SFF PC Desktop
I tunes has detected a problem with audio configuration audio/video playback
Go to Start> Run
Type in 'Services.msc' without the quotes.
Find Windows Audio in the list. Most likely it has not 'started', as stated beside each of the items in the list. Click on it, then click 'start'. Re open your itunes and it should be working.
Oct 17, 2008 | HP Compaq WF1907 Monitor
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
104 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
