Question about Fantom Vacums FM741 Twister Bagless Upright Vacuum
Help unclog vacuum cleaner
Clogged somewhere can't figure out how to take it part to get to the clog
  • Anonymous Mar 28, 2008
    vacum is not picking up dirt filter tank is clog
4 Suggested Answers
harley12
  • 22 Answers
SOURCE: clogged
You can call your manufacturer of the vaccuum cleaner and get some help. Or try unplugging it and turn it upside down and beging taking it apart. Take the brush out and then work your way to the motor. There maybe something lodged up in by the brush. Also check in the bag department and look in the hole where the bag is installed. You may have some luck there. Good luck.
Posted on Sep 21, 2006
reddevil6
  • 1673 Answers
SOURCE: SEBO vacuum cleaner
Take the hose off and see if the light is still on or is it off. If it is off, then there is a clog in the hose. While the hose is off, drop something thru it and see if it comes out the other end. Press the retaining clip and the hose will disconnect. Separate the power head from the handle unit to make sure there is no clog by the brush roll. If it is still on then probably the computer controller, part # 5740ER has a problem. It is located in the power head.
Posted on Feb 16, 2008
  • 29 Answers
SOURCE: My bissell 9400 pro heat steam cleaners sprayers are clogged again...how can I fix this with out taking it to a shop to get fixed?
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Posted on May 29, 2009
Vacuum is clogged
Without specifics of Model, I can't tell you how. There are no clog ports in Dirt Devil vacuums. Usually a hose has to be removed to unclog.
Apr 05, 2014 | Dirt Devil 12 Amp HEPA Filter Vacuum...
My shark navigator freestyle is clogged.
There's also a screen in the dust cup(where everything goes) mine was clogged there, just scraped the dust off it. And it stopped venting out the side.
Mar 15, 2014 | Shark SV1100 Navigator Freestyle Cordless...
Suction not working well. how do I unclog?
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
heatman101
Nov 27, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My hoover floormate h3060 has not been used for some time, when I went to use it, it would not dispense the cleaner..The last time I used it, I used a mixture of amonia and borax. I think the hose is...
You most likely have either a clogged screen at the bottom of the fill tank or the jets that spray fluid are clogged. You can unscrew them and power a paper clip through them. If the hoses are by chance clogged which doesn't happen often, Pull one off at a time and blow real hard to unclog, then put it back on, then move to next hose.
Do NOT take all of them apart at the same time or they can get mixed up and it's a pain to figure out how it all went back together.
Feb 07, 2010 | Hoover H3060 FloorMate SpinScrub 800...
The vacuum became clogged and motor abruptly stopped, after unclogging vacuum will not power on.
Check the power lines coming into the suppley 9-10 the main feed came loose, you may have to solder the wire back, but there would be a short somewhere, or you ran the it to long while clogged and blew the bendix/motor
Aug 11, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Hose that releases the water and cleaner on my Hoover is clogged
Your right the hose is clogged.. Use a portable vacuum to blow the dirt inside the hose.
Jul 24, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Clogged hose...
Hi!
Low suction, poor pickup, or no suction may be due to a clog in the vacuum cleaner. If you notice a change in the sound of the motor or a reduction in the spinning action in the Dirt Container, check for clogs. Unplug cleaner from electrical outlet. Empty Dirt Container. Check Upper Tank and Louvers for build up or clogs. Check to make sure Louvers are installed correctly. To unlock the Louvers, grasp the rim and turn toward the left. Pull straight down to remove. If the Louvers are missing or not locked into place, check and clear the tube in the center of the Dirt Container. Remove the Twist ‘n Snap Hose from the vacuum by turning to the left. Check the Suction Inlet, Hose and Hose Wand for clogs. Remove any clogs from the hose using a long, narrow object. Check the Foot Hose for clogs. If needed, remove the screw attaching the Hose Wand Base to the vacuum. Straighten the Foot Hose and unclog with a long, narrow object. If the clog persists, then check the Rotating Floor Brush the Air Passageway for obstructions.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 10, 2009 | Bissell 6594 PowerForce Bagless Upright...
I have a clogged hose. How can I take it apart to get the clog out? or what can i stick up it to get it out?
Most vacuum cleaner hoses can be unplugged at some point. One way to clear a clog is to reverse the hose & let the vacuum **** the clog out the way it went in. If you have to remove the clog manually, a length of coat hanger wire, with a small hook bent on one end, will serve. Most clogs are near the hose ends, so not much wire length is required.
Apr 14, 2009 | Fuller Brush FBPTCAN Bagged Canister...
Clogged vacuum hose
I used a snake like they sell for unclogging pipes. I can use the snake on one end to break it up. I attach the other end to my industrial wet.dry vac and **** it clean. Sometimes I cannot imagine how it fills half a five gallon bucket of dog hair and stuff.
Jul 30, 2008 | Kenmore 22812 Bagged Canister Vacuum
Suction problem
get rid of the carpet its shredding and falling apart.no sence in vacuuming old rotten carpet.or try using a vacuum without a brush roller and just suction
Jul 15, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Fantom Vacums FM741 Twister Bagless Upright Vacuum Logo
54 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
