Question about Lexmark X5470 All-In-One InkJet Printer
Refill cartridge after refill.lexmark stiil reprts cartridge empty
  • bcshoban Nov 16, 2008
    i bought a new color cartrige for my lexmark x5470 and i put it in and it say's color ink level low what do i do
  • fitlike Feb 23, 2009
    I have same problem with my x4550 both refills are not registering and keep showing low ink so print gets cancelled until I replace the cartridges (which are both full) is there any thing I could do, patch the driver (anything)
    President:
  • 2,072 Answers
More then likely the cartridge has failed.
That is not uncommon upon refill.
You can try cleaning the exterior of the cartridge with a cloth and some alcohol, as well as the contacts on the print head where the cartridge is loaded into the machine.
Sometimes those can become contaminated.
I strongly suspect the cartridge will nor respond though.
Posted on Mar 09, 2008
  • Rick Kasper Mar 10, 2008
    When I get "thanks for trying" it makes me want to not help on here.
    Your cartridge needs replaced.
  • 24 Answers
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
840
Posted on Mar 02, 2009
I have a Lexmark X9575 all-in-one printer. When I refill the ink cartridge the printer still says it is empty. How can I reset the printer to think the cartridge is full again?
Lexmark Printers will not recognize Refilled Cartridges, The Fuse inside the cartridge blows and makes the cartridges Unusable is there is an attempt made to refill one!
Apr 08, 2013 | Lexmark X9575 InkJet Printer
Lexmark x4650 refilled ink cartridge but printer says it's empty and won't print
Lexmark does not recommend using refilled cartridges. However, if you have successfully used one before, there's a possibility that the refilled cartride got damaged along the process of refilling. Try to insert a different known working cartridge to determine if the other is faulty. Or better yet, try to purchase a new genuine Lexmark cartridge.
Jun 14, 2011 | Lexmark X2500 All-In-One Printer
I refilled my new cartridge but priter says its empty
Hi there
Did you say you refilled them your self if so then buy new inks because Lexmark not will take refilled cartridges, sorry but this is down to Lexmark how they made them so it will not take refilled and cant be reset.
All the best Pineworks
Mar 14, 2010 | Lexmark All-in-One Printer with PictBridge
Refilled ink cartridge and printer tells me to replace cartridge
its impossible trust me,there is some kind of microswitch in the cartridge that tells the printer its empty-now then listen up-refill it before its empty and it will not know,hows that for a work around
Feb 25, 2010 | Lexmark X9350 All-In-One InkJet Printer
Empty ink
According to your problem it seems your cartridge has been damaged or choked so change your cartridge. Because some times when we use refilled cartridge, Ink goes dry and printer's sensor can not sense the ink.
Regards
Ashly
Feb 23, 2010 | Lexmark X2600 InkJet Printer
Purchased 36xlcartridge
If this is a refilled cartridge, most likely the electronics have been turned off on the cartridge. I own a cartridge refilling store and I don't refill the Lexmark 36 or 37 because the printers turn off the electronics on these cartridges when they get empty so they can't be refilled. If this is an original Lexmark cartridge, I think that Lexmark is making their printers so extremely sensitive to refills that they even kick out some original manufacturer cartridges. I have had a couple customers that this has happened to and it seems to happen more frequently with prebate cartridges. I recommend exchanging your cartridge for a new one (Lexmark brand).
Nov 02, 2009 | Lexmark X3650 Printer
Refilled lexmark #4 cartridge but printer still says it is empty,
Hello sir; I don't understand "refilled " means in here, is that means refurbish, if answer is yes , try not to use it, please use "OEM". generic one caused a lot problem.
Aug 28, 2009 | Lexmark X2690 All-In-One InkJet Printer
Still getting message empty cartidge lexmark x2650
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 26, 2009 | Lexmark X2650 All-In-One InkJet Printer
I just refilled the cartrige, but it says the ink is low, My printer brand is Lexmark2400.
You may have a non refillable cartridge.
Lexmark has an interesting development with their inkjet cartridges which they began some years ago with toner cartridges. A court decision required Lexmark to allow their cartridges to be refilled. However, Lexmark would naturally prefer that you only buy from Lexmark. Thus, Lexmark has developed the following system:
  • Lexmark offers for sale two different versions of the same cartridge:
  • The regular version (#23, #24, #28, #29, #41, #42) is not refillable. It is the "Return Program" or "Prebate" cartridge. Supposedly, when you buy this cartridge you agree to return the empty cartridge to Lexmark. In return, Lexmark gives you roughly $5 off the retail list price of the cartridge.
  • The "A" version (#23A, #24A, #28A, #29A, #41A, #42A) can easily be refilled. However, the price of the cartridge is roughly $5 higher than the regular version, so most people unknowingly buy the regular version.
Jun 23, 2008 | Office Equipment & Supplies
Lexmark X5470 All-In-One InkJet Printer Logo
81 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
