Question about Lexmark X5470 All-In-One InkJet Printer
Refill lexmark after refill,lexmark still reports cartridge empty
  • Anonymous Mar 13, 2008
    I get the printer-is-out-of-ink messaqe too. I can get mine to work fine if I just press the start button once more ---takes two taps to get it done. sadly, I hqve to keep watch on ther printout to detect a real empty cartridge. but that the hey! It's cheap!
  • CPERA Jun 14, 2008
  • 29 Answers
Fiend your solution direct from Lexmark. Here is your solution
Posted on Mar 02, 2009
  • 2,035 Answers
Lexmark cartridges are designed not work with refilled ink ,,,If ur lucky it will work some times ..Please use new cartridge it should work fine
Posted on Mar 11, 2008
Lexmark S405 refill cartridge reset
When a Lexmark cartridge is refilled, it will not be able to report its ink level.
Please note that all Lexmark printers work best when original supplies or genuine Lexmark cartridges are used. We do not recommend the use of third party, refilled or remanufactured cartridges - you might not get the print quality you expect from ink that is specially formulated by Lexmark.
Nov 27, 2011 | Lexmark Interpret S405 Wireless All-in-One...
The front window on my lexmark P4350 allways says the cartridges are empty even when they are full please help
Are you still able to produce printouts? Try to re-seat the cartridges in the printer.
Please note that a refilled cartridge will not be able to report its ink level.
Oct 12, 2011 | Lexmark P4350 All-In-One InkJet Printer
Can u help me with resetting my Lexmark x7350? i revilled my cartridges, and now the printer says my color cardridge is allmost empty. Thank you!
Once the Lexmark cartridge is refilled, it can no longer report it's ink level. ). You should be aware that a refilled cartridge will not be able to report its ink level, and you might not get the print quality you expect from ink that is specially formulated by Lexmark to pass through microscopic nozzles at extremely high temperatures.
May 24, 2011 | Lexmark X7350 All-In-One Printer
My lexmark X5410 will not accept the black and colored refilled ink cartridges from walgreens. It keeps reporting that the right cartridge is missing.
If you have refilled the cartridges 28 and 29, it's pretty normal that your printer won't print. Those cartridges are not for refill (they can be refilled, but won't work once the printer says they are empty). If you have refilled a 28A and 29A and it doesn't recognize the one of the cartridges, try removing them and clean the electric contacts with a dry cloth. Put them back in. If that doesn't help, I suggest you buy a new cartridge.
Apr 11, 2010 | Lexmark X4530 InkJet Printer
I refilled my new cartridge but priter says its empty
Hi there
Did you say you refilled them your self if so then buy new inks because Lexmark not will take refilled cartridges, sorry but this is down to Lexmark how they made them so it will not take refilled and cant be reset.
All the best Pineworks
Mar 14, 2010 | Lexmark All-in-One Printer with PictBridge
Refilled ink cartridge and printer tells me to replace cartridge
its impossible trust me,there is some kind of microswitch in the cartridge that tells the printer its empty-now then listen up-refill it before its empty and it will not know,hows that for a work around
Feb 25, 2010 | Lexmark X9350 All-In-One InkJet Printer
Refilled ink cartridge but it says cartridge is empty how do i reset my printer?
Actually each original cartridge has a sensor that reports back to the printer information like ink level and others.
Once the cartridge gets empty, there is no way to reset it, even though you just refill it.
Please don't forget to rate this answer if it helps.
Nov 09, 2009 | Lexmark X2500 All-In-One Printer
Purchased 36xlcartridge
If this is a refilled cartridge, most likely the electronics have been turned off on the cartridge. I own a cartridge refilling store and I don't refill the Lexmark 36 or 37 because the printers turn off the electronics on these cartridges when they get empty so they can't be refilled. If this is an original Lexmark cartridge, I think that Lexmark is making their printers so extremely sensitive to refills that they even kick out some original manufacturer cartridges. I have had a couple customers that this has happened to and it seems to happen more frequently with prebate cartridges. I recommend exchanging your cartridge for a new one (Lexmark brand).
Nov 02, 2009 | Lexmark X3650 Printer
Refilled lexmark #4 cartridge but printer still says it is empty,
Hello sir; I don't understand "refilled " means in here, is that means refurbish, if answer is yes , try not to use it, please use "OEM". generic one caused a lot problem.
Aug 28, 2009 | Lexmark X2690 All-In-One InkJet Printer
Still getting message empty cartidge lexmark x2650
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 26, 2009 | Lexmark X2650 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
154 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
