My dvd player will no longer play any dvd's, when i put a dvd in, it will say loading and then it will say no disk, do i need to get a dvd cleaner.? please help
whenever i insert any disc even brand new it says no disc...
when i opened the dvd player what i saw the motor doesn't swing properly it stop so soonwhenever i insert any disc even brand new it says no disc...
i put in the dvd and the machine says "loading,,,,," and after so long it says"no disc"i put in the dvd and the machine says "loading,,,,," and after so long it says"no disc"
You can't post conmments that contain an email address.
Cleaning would be a good first step, but don't expect miracles. You may very well need anything from an alignment to replacement of the optical assembly...accordianman
Try using a cleaning disk for the laser eye. This is a special dvd with a brush grafted on it to clean off thedoirt on the laser. Hired DVD;s are often covered in greasy finger marks and other debris which gets transferred to the iris as the disk spins. this eventually clogs the laser and it can no longer do a load and often reports no disk.
When a DVD goes into DVD player it has to spin it and read it. If your DVD player is not reading the disk. The disk could be dirty. The DVD player might need to be cleaned. You could be trying to play a PAL disk on a NTSC player or Visa Versa. or the region coding might be wrong. Try playing a clean disk that you have played in it before. That might tell you if you need to clean the DVD player.
There are a lot of reasons why that could happen. Sometimes when a DVD player needs to be cleaned it won't read a disk.Sometimes when you try to play a NTSC disk on a PAL DVD player or visa versa it won't play. Region coding could be another issue. And sometime home burned DVDs won't play in certain players.
yes, Lazer wont aline to read, they get progressively worse, sometimes intermittent, if that is the case then you will need a whole new internal cradle. maybe time to get another one. the Yeti
Your toshiba is not spinning that's why it keeps on saying loading. Unplug the dvd Open the device,once open plugin the dvd and put the dvd cleaner in the player. take your finger on the top where the dvd disk is and spin the disk. What happening is that you are cleaning the len. keep spinning until it spin on its own.Put the toshiba top back on and clean again. It should clean on it's on. Now you can play your dvd. Clean your dvd on a regular basic.
With the power turned off, open the DVD Player, and
then open the top where you load the DVD into the player. Locate the
laser lens
and notice that the laser is attached to a transport assembly that
moves the laser
diagonally outward in a slot. 1. Slide this assembly outward to the end
of its track. 2. Slide the assembly back inward to the closest inward
position. 3. Repeat the process of sliding the assembly outward and then
back inward.4. Put in a music CD and let it play all the way through.
This helps to calibrate the laser head assembly movement. When the
music CD is finished playing. 5. Put in a DVD, and you should have a
working unit
again This is a factory solution from Mintek that was given to a
customer who ask for help with the forever loading disc problems. This
solution may work on other models of portable DVD players. Most
portable DVD players use this type of transport mechanism. Try this
solution it might work for you.
