Question about Dell Inspiron 6000 Notebook
Unable to get a wireless connection outside of home
I cannot get a wireless connection anywhere outside of my home. I have never been able to since I have owned this computer and now I have a job where I need to use a wireless connection. The IT folks can't get it to work. PLEASE FIX!
  • Justin Gates May 11, 2010
    Have you tried reinstalling the driver for your wireless adapter? Is it still under Dell warranty? If so, call Dell tech support, if they can't fix it they'll replace it.
  • Bill Ghee May 11, 2010
    Have you tried using a PCMCIA card. Not something you would have laying around probably. This would however determine if the motherboard needs replcd.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 156 Answers
Hi
More info is needed to clarify and help suggested solution.
1) What type of wireless infrastructure do you have at home?
a. Which wireless band is used at home? Wireless band a or b/g or n?
b. Are you able to connect wirelessly at home? If so, what wireless router/modem is in use?
c. Which wireless card is installed on the laptop? Which drivers are installed for the wireless card?
d. What wireless channel is being used at home?
2) What type of Wireless infrastructure do you have at work?
a. Which wireless band is used at work? Wireless band a or b/g or n?
b. Does the wireless management application/utility "pick" wireless signals but you are unable to connect or no signals are "picked" up?
c. What wireless channel is being used at work?
Note: Generally, wireless IEEE 802.11a cards cannot be used for 802.11b/g or 802.11n wireless networks. Some cards are rated 802.11a/b/g but they must be set to either 802.11a or 802.11b/g and not both. In the US wireless channels allowed are 1-11. Generally in Europe it is 1-14. Japan and other regions have there own specifications. Setting the wrong region (channel range) can cause signal problems.
You may bring these questions to work IT as you may not have all the answers.
Mike
Posted on Apr 13, 2008
I am getting a message on my coolpad phone saying data error code unable to establish wireless data connection. What does this mean?
you are recieving the error message due to weak data given by your network provider, try to change your location when accessing wireless data connection. go and find the strong signal outside your home.
Dec 06, 2016 | Cell Phones
Won't connect to Wirelss hot spots outside of home. Wi fi at home works but anywhere else I just get a Error code 003-3201 pops up.
Is the Wifi strong enough to go outside with it? Do you change the WiFi spot outside of your home? For example, if you are at a gas station, do you connect with your home network? This doesn't work.
May 26, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
3 failed attempts to connect HP DV6t laptop
First as a test, turn off the wireless security, and see if the laptop can connect.
If it can connect with security turned off, then it is likely that you are making some type of mistake with the password. (Such as caps lock being on, or having a keyboard error.)
Good Luck!
Jan 03, 2010 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
IPod Touch does not connect to my home network?
In my case, I keep getting endlessly prompted to enter my passcode for my wireless router. I found that if I reboot the iTouch - hold down the top power button and slide the "slide to power off". Wait for it to finish powering off and then power it back on by holding the same button. When it comes back up it automatically connects to my home network again. Seems to happen every time I connect to an outside wifi network and then return home... I wish I knew WHY it does this - I suspect it has something to do with how my home wireless router is configured.
Dec 22, 2009 | Apple iPod touch
Wireless connection
check to make sure the wireless zero configuration utility is on ..check from services in the computer and make sure that there is a check in use windows on the network card itself from network connections. Then it should work .
Jun 13, 2009 | Actiontec GT704WG Wireless Router...
Unable to get PC to recognize wireless connection with DI-624
Which is it? PC cant connect or not able to setup wireless? If the router came with a setup CD, run that from your pc... Make sure you have a crossover Cat5(ethernet) cable connected between the router and a PC just to set it up initially... within the router can enable or disable wireless function... But to really narrow your device down, i need to know the hardware revision number... its on the same label as the MAC address on the outside of your router
Apr 03, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
How do i get connection using belkin wireless g plus mimo notebook card i have only the card is there still a way i can connect only having the card that goes to my laptop. or do i need a router or can i...
1. If your laptop has a built-in wireless adapter, then you don't need a belkin wireless g plus adapter.
2. You can connect to the Internet using your adapter provided that the location where you at offers wi-fi or wireless connection
3. If you want wireless connectivity at home, then you need to have a wireless router and subscribed for DSL/Cable broadband connections
Nov 07, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I am having problems with my wireless connection. When I try to connect to a wireless connection such as an airport, coffee shop, etc. I get a connection to the network but am unable to connect to the...
tht is becasue u odnt have heir WEP or WAP password if it has a password then ur adapter will seem to connect to it but wont give u internet access to the router which means no intenet
Sep 25, 2008 | Computers & Internet
New Laptop Will Not Connect
The first thing u need to do connect ur router to the computer with a wired connect access the router page (firmware) ip address which need to enter to open the same on internet explorer is 192.168.0.1 enter the user id & password of router (default user id & password is admin or password)
step 1 go to wireless change the channel to 6 (this the best channel)
Step 2 go to add/remove in control panel remove the dell wireless utility
step 3 go to device manager in control panel go to network adapter right click on wireless network adapter & select uninstall or remove
step 4 Now click action on top of device manager & click on scan for hardware changes it will reinstall the driver
Step 5 now go to network & sharing center go manage network connection right click on wireless network connection & select the connect it will show the list of wireless network now connect to ur network enter ur security key once ur connected save the network & ur issue is resolved
Jun 04, 2008 | D-Link DI 514 Wireless Router (DI-514)
Dell Inspiron 6000 Notebook Logo
299 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
