Question about LG Televison & Video
LG LH-T6540 dvd/amp has no sound or static when set to video 1, to amplify volume from t.v. It also does this when set in dvd mode.
  • 476 Answers
SOURCE: I own an LG (LH-W750TA)
Open tray
Press PAUSE
Enter 0 0 0 0 0
Region change screen should appear.
Enter region 1 - 6 or 0 for multi-region.
Press PAUSE
Posted on Apr 23, 2008
gandhiforyou
  • 275 Answers
SOURCE: DVD PLAYER MULTI REGION CODES
you can change your dvd region code but i advise you not to change it instead use a software . here is the link for the software to download :- http://www.4shared.com/file/19492658/43612f11/DVD_Ghost.html?s=1
if it doesn't work then contact me ok.
Posted on Jun 28, 2008
Benimur
  • 6966 Answers
Your LG LH-W750 is a 700W Wireless Home Theatre and the DVD player is only one component of the system. Having said that, the DVD player would not be carrying the same model number. It would be the mechanism and circuitry of another model and incorporated into your main unit. Hence region free code would have to be for the original model number of the DVD player and not the Home Theater. Sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • 20 Answers
SOURCE: lg lh t550. WHEN DVD
Basically films on DVD cary diferent audio formtas when playing. On the remote when playing a dvd thre shuold be an audio button which then scrolls through what language/commentary to use
Posted on Sep 23, 2008
  • 146 Answers
SOURCE: want to know how to set my LG dvd/hdd player to multi region
IF there is a code for it you will have to check on some of the sites that have region hacks for DVD players. Not all players have the capability of changing them to region free. I looked to see if your model was listed on a couple of the sites that have directions, info and or firmware updates to change region settings on various makes and models of players, and I didn't find yours listed anywhere. It may use methods from other LG models, but you have to do a little research, some google searches and a little trial and error. Keep in mind that applying these hacks can render your unit inoperable and not recoverable. You might want to look into getting an inexpensive player from Phillips, Durabrand, Apex or one of several other manufacturers that are easy to find codes for and simple to change region coding, and in alot of cases cost less than 50 USD. Phillips are the easiest to get codes for and they are reasonably priced in most department stores like Target and Walmart or at Best Buy and Circuit City. Durabrand are Walmart brand players that cost 25 or 30 dollars and they are easy to do as well.
Hope this helps
Cheers
Posted on Jan 03, 2009
I have an 2002 Nissan altima and DA display on the radio is working but no sound
Hi candy Love , I love that name ! What Altima ? S ,SE or SL
AUDIO
Revision: May 2004 2002 Altima
AUDIO PFP:28111
System Description EKS002KQ
BASE AND MIDLINE SYSTEM
Refer to Owner's Manual for audio system operating instructions.
Power is supplied at all times
 through 15A fuse [No. 31, located in the fuse and fusible link box]
 to audio unit terminal 6.
With the ignition switch in the ACC or ON position, power is supplied
 through 10A fuse [No. 6, located in the fuse block (J/B)]
 to audio unit terminal 10.
Ground is supplied through the case of the audio unit.
Audio signals are supplied
 through audio unit terminals 1, 2, 3, 4, 13, 14, 15, and 16
 to terminals + and - of front door speaker LH and RH
 to terminals + and - of rear door speaker LH and RH
 to terminals + and - of tweeter LH and RH.
BOSE® SYSTEM
 to audio unit terminal 6, and
 to Bose speaker amp. terminal 1.
Ground is also supplied
 to speaker amp. terminal 17
 through body ground B117.
 to speaker amp. terminals 23, 24, 25, 26, 27, 28, 29, and 30.
Audio signals are amplified by the speaker amp.
The amplified audio signals are supplied
 through speaker amp. terminals 2, 3, 9, 10, 11, 12, 13, 14, 15, 16, 18, and 19
 to terminals + and - of subwoofer LH and RH.
SPEED DEPENDENT VOLUME CONTROL (MIDLINE SYSTEM AND BOSE SYSTEM)
If activated, the radio output volume will be automatically adjusted to compensate for increased driving noises
at higher driving speeds.
The radio receives a vehicle speed signal from the combination meter, and selects the output volume.
Feb 01, 2015 | 2002 Nissan Altima
Tip
LG LH-D6235 DVD Region Free Fix
LG LH-D6235 DVD Home Theater Region Free Fix
Would you like to make your LG LH-D6235 DVD Home Theater Region Free?
Follow these steps:
  1. Press the Pause button on your remote control
  2. Using your remote control enter the code 3, 1, 4, 1, 5 and 9 (If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.)
  3. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control
  5. Power off your player and wait a few seconds
  6. Power on your player
I hope that helps.
____________________________________________________________________
Download LG LH-D6235 Home Cinema System Manual
on Jul 14, 2010 | Televison & Video
Tip
LG LH-D6235 Region Free Fix
Follow these steps:
I hope that helps.
on Jul 14, 2010 | Audio Players & Recorders
The radio works and plays fine but if i put a dvd or cd in no volume the dvd does play though just no volume
Are you running the audio through an amplifier? If so, it sounds like you are using the blue wire (power antenna remote turn on) instead of the blue/white wire (amplifier remote turn on). The power antenna remote turn on turns off when leaving tuner mode, turning the amp off.
Nov 07, 2012 | XO Vision X341BT 7-Inch In-Dash Touch...
Volume too low on toshiba portable dvd sd-p91ske
see the causes and fix it:God bless you
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Jul 21, 2012 | Televison & Video
Tip
Follow these steps:
I hope that helps.
on Jul 14, 2010 | LG LH-D6230 System
I have a LG TV 37LC46-ZC with LG surround sound DVD Player/Amplifier LH-T550TB and a Sky HD Box. This used to work fine through the scart leads on the old sky box but since I changed over to HD Box I...
I know that's not all that helpful at the moment but I know that the no video out (to run a 2nd tv) that's there way of getting you to have a 2nd sky box I hope that is not the case with audio but it is a possibility ..try using phono plugs
audio out (RED WHITE omd audio in on your amp I have a look about and repost
Nov 26, 2017 | Televison & Video
I have a LG Record reciever home theatre model is LH-RH9691 and im having a problem with the volume only when the radio is working. It can only turned up slightly when set to max volume. But when...
in lg home theater system in video mode the complwte speaker will work and in mp3 only two will word .the radio get only a min volume in lg due to the range of antina
Apr 25, 2011 | LG Audio Players & Recorders
I just bought a Samsung HD LCD 32 in TV and want to play it through my Home Theatre System. I set the TV to external speakers, put the HTS in aux mode, but I don't get sound. My old Samsung SDTV would...
If you do not have a manual for the machine down load one at http://www.samsung.com/us/support/downloads/LN32B460B2D
It will show you how to set up a Home Theater Connection
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
to the AUDIO OUT [R-AUDIO-L]
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
Nov 29, 2010 | Samsung LN32B460 32 in. LCD HDTV
Televison & Video Logo
424 people viewed this question
