Question about Kenwood Audio Players & Recorders
Vintage Kenwood Receiver Kr-9600 Sound cut out
70'S model Kenwood KR-9600 Worked on at least 5 times for same reason in the last 30 years. Sound cuts out either one side or the other. Turn it up or wiggle numerous controls might get it back for a few minutes. From the repairs it lasts for a while but comes back. I bought this beauty from a friend in 1982 & It will go to the grave with me. I have a cheesy electronics degree, would old solder joints need heating?
  • 979 Answers
SOURCE: KR-X1000 Power Problems
Sorry, no freebies from what I see online. But, when you power up, does it play before it shuts down? This will help me formulate a better answer for you...accordianman
Posted on Oct 25, 2007
SOURCE: Yamaha Receiver R-700 Input & Recout switches cut out!
I have 2 of the same receivers. One works perfect and the other had the same problem as you describe. The faulty one I brought to work to use. Since I wasn't planning on recording anything I desoldered both swithces and swapped them. The REC OUT switch is a 6 pos SW, and the INPUT is only a 5 pos SW, but it works. Now my sound doesn't cut out any more and I have a receiver for work.
Posted on Dec 26, 2007
  • 17 Answers
SOURCE: Kenwood Receiver KR-V127R - left channel not working
Select an input that is not connected, for example select CD with no cables going to the CD input on the backside. Will you then hear equal humming on both channels? If so, the amp stage is ok,
and the problem lies in the signal level circuitry.
Open the cover and use a plastic (insulated) stick to touch suspectible cables and components. When the sound returns, you've found the cause. Resolder or reseat the component/cable/card.
Use the insulated stick, NOT your fingers!
Posted on Jan 01, 2008
  • 319 Answers
SOURCE: problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Posted on Aug 14, 2008
  • 624 Answers
SOURCE: I have vintage PIONEER SX1010
This could be solder connections that are cold or cracked, you can look for them on the power supply board and the amplifier boards. Sometimes it is not an easy thing to remove the boards, but usually you can at least pull them out far enough to solder on them. Just make sure that you re-connect everything just as it was when you took it apart. The amplifier boards are connected to the heat sinks. If my memory serves me right, you will have 2 amplifier boards, one for each channel. The heat sinks have short fins on them and those two boards will have lots of bad solder connections. The power supply is normally not as bad, but is worth checking out. You may be able to see the bottom of that board without removing it. Just make sure you take the bottom panel off of the unit and, of coarse, the top cover. The power supply board is where the power transformer has it's secondary wires connected to it and you will have 2 very large capacitors on it.
Be very careful when you solder on these boards, make sure you have no solder bridges (where one solder pad overflows onto another close by), it is a very easy thing to do by accident even for the best of technicians. You will find lots of solder connections that look grainy and are not shiny silver in color, and some with a ring crack around them. Make sure that every single one of those are reflowed with solder.
You should also clean the controls with a good contact cleaner made for electronic switches and relays. Start with the power switch, that could even be the cause of your entire problem. Spray or get drops of the contact cleaner inside the switch and then work the switch by turning it on and off, over and over again. Sometimes it needs to be done several times. You may even need to open the switch by taking it apart, to clean it good. Be careful, sometimes they are not too easy to get back together again. If you take it apart, look at the contact that it has and you will see some black residue. That needs to be removed with some contact cleaner and a burnishing tool. Or you can scrape it with a small sharp pick like a dental pick or a very small file to run across it if you can not find a burnishing tool.
Then you should clean all the other controls like the volume control, balance, treble, bass, speakers and even the function controls. You should not take those apart, they may never get back together again.
Once this is done, you should have your receiver working almost like new again. That is really the best you can hope for.
If you feel like this may be a bit more than you can do yourself, a service center would normally charge about $200 give or take about $25 to refurbish your receiver depending on the rates of the service center. Your old Pioneer receiver is well worth the high service cost, people who own them rarely give them up. Being one of those people yourself, you are in the position to understand why. Most other people just don't understand what it means to have such high quality equipment. After all, it has worked wonderfully for you for what, about 30 to 40 years? Try getting that out of anything made today, good luck with that!
If I can be any more help, just let me know by posting back on this thread.
p.s. Anything less than a "FixYa!" rating would lower my overall rating so I would prefer no rating at all if you do not believe I deserve a FixYa! rating. I only do this free help for people to earn a high rating, it is our only reward.
Posted on Sep 07, 2008
Avr kenwood kr v5090
Have you tried the "Simulated" surround setting?
If you don't get sound in "Simulated" mode then you have probably lost the surround channels.
If you do get sound then your "Media"
is not recorded with a surround "Track". or the surround "Processor" may have issues that need to go to the repair shop.
Mar 25, 2014 | Audio Players & Recorders
Kenwood receiver speakers static pop
Your volume emitter needs to be replaced. And or the resisters on both sides of it.
Apr 18, 2012 | Kenwood Kr-5600 Vintage 70s Am/fm Stereo...
I have an old kenwood kr-9000 gx,and when ever I turn knobs,I get a crackling or static sound,and one channel might cut out,sometimes,fiddle with it and it goes away ,and years ago I lost my user...
I have the service manual for Kenwood KR-9000 G idk would it help You but if needed will gladly send it to You, its in Adobe pdf form 12,6 Mb, I think You might need that more then the user manual because in this You can find what are the values of the potenciometers that You would like to renew.
This is the link to it, hope You find it usefull.
Best regards.
Feb 25, 2010 | Audio Players & Recorders
I have a Kenwood KR-A4010 Am/Fm Stereo Receiver. Every five seconds the sound fades in and out. Can anyone find a solution to this problem?
Something in the unit is smoked and potentially dangerous. Get that puppy down to a repair shop. Don't leave it unattended if you turn it on. Got a fire extinguisher handy?
Apr 28, 2009 | Audio Players & Recorders
Same problem with KR-A46
Hi all,
may I ask if anybody solved the station memory problem
with Kenwood KR-A46. I do have the same and I dare to fix it
but I am looking for the right solution.
May 22, 2008 | Kenwood KR-A5080 Receiver
Have a kenwood KR-V990D and can't seem to bring the volume up
kenwood has always showed negative numbers 00 is as high as it will go
Jan 06, 2008 | Kenwood KR-V990D Receiver
Problem with playing my Kenwood KR-X1000
Nov 19, 2007 | Kenwood KR-X1000
456 people viewed this question
Top Kenwood Audio Players & Recorders Experts
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
