Question about RCA 14F512T 14" TV
My Rca TV model 27v412t
The FPA is locked and won't allow us to use the controls on the TV and we don't have the original remote
  • 119 Answers
SOURCE: FPA Lock
After doing a little research, it looke like the front panel lock , can only be removed from the parental control menu using your remote. If your universal remote does not get you into the menu, see if you can borrow a friends rca remote long enough to get you into your menu & remove the fpa.
Posted on Nov 03, 2006
  • 556 Answers
SOURCE: RCA 27V412T FPA LOCK ON & REMOTE LOCK
If the front panel lock is on, you will need a working original remote (or a universal remote properly programmed for RCA) to turn the set on. The IR receiver is next to the buttons on the fromt but the RCA IR receivers are very reliable, and I have yet to see a bad one in a modern RCA TV. Once you turn the set on by remote, you can enter the menu and turn the FPA off.
Posted on Oct 06, 2007
techman
  • 3130 Answers
SOURCE: FPA Locked ON
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it’s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Posted on Jan 24, 2008
SOURCE: FPA lock on; have no remote control
FPA Lock On and have no remote for the TV on a RCA TV
Posted on Jun 07, 2009
Ironfist109
  • 3018 Answers
SOURCE: I have a TruFlat RCA
Try this -
  1. Press menu for main menu.
  2. Press CH + or CH - to highlight preferences.
  3. Press "OK" to enter preferences submenu.
  4. Press CH + or CH - to high light "FPA"
  5. Press VOL + or VOL - to turn the FPA on or off.
  6. Press MENU repeatedly to exit.
  7. Back to normal
  • FPA stands for Front Panel Lock. It makes it so kids don't push all the buttons on the front of your TV. The power button on the TV will still work and the remote will still function as normal.
Regards, Tony
Posted on Apr 30, 2011
I NEED HELP GET THIS FPA LOCK OFF I DON'T HAVE A REMOTE FOR THE TELEVISION HOWEVER I HAVE CABLE I WENT IS FAR PUT MENU BUT IT WON'T SCROLL
You are going to have the original remote and the owner manual to do this--Universal remotes never had or will have key features the original one has.
Apr 11, 2012 | RCA 27F650T 27" TV
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
Mar 11, 2012 | RCA TruFlat 27F520T 27" TV
Dog ate remote where can i find one?
Hello
If you want to get its original model remote control; you have to contact the nearest RCA authorised service center at your town. You can't buy its orignal from nowhere else. A universal RCA remote control will work with it, but sometimes some buttons of it may not synchronised. So try to get its original model. Moreover, if by anyway this set happened to be in FPA lock, you cannot open the lock without the orignal remote control. A universal remote control, whatever it may be, won't work then. OK.
Sep 24, 2011 | RCA 20F512T 20" TV
I accidentally turned on the fpa lock and don't have a remote. What now?? Any hope? I also could not get the CC up before I got locked out.
Hello
To turn out FPA lock with RCA TV, you must have its original remote control handset. If you haven't one, just buy a new one of borrow it from your friends or relatives, who own the same model of RCA TV. After unlock, you can use any other remote control. If you are using the original remote control, do the following to unlock it.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Sep 01, 2011 | RCA TruFlat 27F520T 27" TV
I have and rca tru flat tv and my FPA lock is on... i have a brighthouse remote that im using on it but i need to know how to turn it off
Hello
Without its original remote control, opening the FPA lock of RCA will be difficult. Just try to get one new remote for this set or jut borrow it from any of your friends or relatives who own the same model set, just to open its FPA lock. After opening lock, you can use your brighthouse remote. You can open the lock with one amoung the following procedure.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Jun 27, 2011 | RCA TruFlat 27F520T 27" TV
How to take of the FPA on a RCA 27V412T
Hello
To unlock the FPA lock of RCA tv, do the following. One amoung the process will surely unlock your RCA. You must have its original remote control handset to do this..
Most RCA TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
May 22, 2011 | Televison & Video
I have a TruFlat RCA model # 27F520T have lost original remote and FPA lock is on how do I unlock without original remote? Dish universal remote not working to unlock tv, it will pull up menu but cannot...
Try this -
  7. Back to normal
Regards, Tony
Apr 30, 2011 | RCA TruFlat 27F520T 27" TV
My tv wont come back on fpa lock on
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy.
Deva
Apr 21, 2011 | RCA 20F420T 20" TV
Oct 02, 2007 | RCA 27F530T 27" TV
RCA 14F512T 14" TV Logo
56 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
