I was given a kenwood ts440s hf transceiver and it has the leads for dc power supply. What can I use to power this radio? Is it primarily set up for mobile use or can it also be powered for in house usage? Unfortuantely, no manual came with this gift!!
    Problem Solver:
  • 14 Answers
To use supply the radio with 12 volts you would have to use a power supply such as an Astron which can be purchased at Ham Radio Outlet and other ham radio shops, you can get their number on the internet. The 110 AC to 12 volt DC is not the problem..it requires the amperage to make the radiois work.... You can use a 12 volt battery and use it for a maybe an hour without charging....the radio will not work with a car battery charger... Hope this helps
Posted on Mar 12, 2008
I have a vintage Hy Gain Hy Power microphgone, model 610, that I would like to connect to a Kenwood 440 SAT HF transceiver. Please tell me what to connect where on the Kenwood 440 SAT mike plug.
White is the MIC wire
Copper shield is GROUND
Black is usually PTT, otherwise use RED for PTT
vpaxi2bbtoaaaaaelftksuqmccaa==
The above drawing is the TS-440SAT mic connector pinout. The pin numbers should be visible on the MIC connector.
You can get the complete manual at www.mods.dk for free.
Sep 03, 2017 | Kenwood Radio Communications
I have a KENWOOD TS-940SAT HF Transceiver that powers up with the TX indicator on, no power output and no receive.
Very little information about the situation of the transceiver is provided, it might be a complex one. The Kenwood TS-940SAT features a built-in automatic antenna tuner covers the amateur bands 160 through 10 meters. It is advisable for you to reinstall the transceiver and follow the right set up step to see if it works out eventually.
Apr 18, 2016 | Computers & Internet
How much current must the external power supply be able to provide?
To run an HF transceiver (100 W), the radios normally want to see up to 20 - 35 watts of power available at 12 volts. You earlier referenced the FT-990 HF transmitter, which takes a normal AC voltage input from a line cord. Normally a 20 amp circuit would suffice. Since you did not specify if the radio has the internal heavy duty internal AC switching power supply. For an 110 V connection, the unit requires an 8 amp fuse, and 4 amp for 220. I have included a link where you can download the manual for reference: http://www.download.n7tgb.net/yaesu/FT990/FT-990_Manual.pdf
Mar 31, 2015 | Radio Communications
My radio cuts out completely. Wait ! minute and repress the power button, radio back on.
sounds like the power supply. Check all your connections and wires just in case. But it REALLY sounds like the power supply.
Mar 06, 2015 | Yaesu FT-990 DC Transceiver
What could cause Transceiver to shut when power output is increased over 40 watts?
My first guess would be that you have a bad/poor antenna,coax, causing high reflected power, next would your power source. You will need a 25A or higher rated power supply, with clean 13.5V power to run at the higher power levels. Meter the power supply voltage when you xmt at a lower power level, maby 30w, watch for drop in voltage. If voltage drops (some) at 30w, most likely supply won't hold voltage up at your 40w and higher power levels.
Oct 17, 2014 | Kenwood TS-570D HF Transceiver
Kenwood TS 2000X: Low HF TX power output on HF bands ONLY.
Hello, this problem is solved and how?
I have the same problem on HF and VHF 30Watt max output
1.8 MHz-20M 0-5Watt
10M 25 Watt
6M-30Watt
2M-25Watt
70cm 42Watt is ok
23cm 10Watt is ok
thanks
Tuxon7@gmail.com
Jun 12, 2009 | Radio Communications
I want to download Owners Manual for Kenwood TS440S Transceiver
I think you will find everything you need on This Page
Here's the link info: http://www.ham.dmz.ro/kenwood/ts-440s-circuit-improvements.php
Apr 25, 2009 | Kenwood Audio Players & Recorders
79 people viewed this question
 Grubhead
Grubhead
