Cordless Mouse & Keyboard install I need help
Hi, I'm trying to install a logitech cordless mouse and keyboard I have followed the limited instructions and it's not working... do I need to uninstall the current keyboard and mouse first???
  • 349 Answers
If you have a disc for the new items ,install first,shut down pc, then take the old mouse & keyboard off connect the new wireless ones before rebooting
you may need to sync the mouse & keyboard by holding in the small little button on each item and the reciever unit untill the lights come on indicating it is recieving the signals from both mouse & keyboard.if this does not work put the old mouse back in reboot then go into control panel / mouse, and sellect wireless mouse ,turn off the pc plug the new mouse back in then boot up
good luck
Posted on Mar 11, 2008
Lost manual on how to start cordless mouse and keyboard
I believe this is you keyboard and mouse combo as its the only one dell uses at the moment,en?section=downloads&|downloads||dd
Apr 06, 2010 | Logitech Cordless Mouse
Logitech mouse n keyboard wont connect
whenever you chage the battery you have to syncnonize your keyboard and mouse to sensor of the reciver. you can see on the back side of the keyboard there is connect button just press it and on the recevre side also press the connect buton same setting do with mouse also.
Sep 08, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
Logitesh lx300 cordless mouse and keyboard
try reinstalling the drivers. initially though, press the connect button on the usb dongle. then press the connect button on the mouse and then on the keyboard. if anything this should let you connect the mouse to let you install the drivers. the drivers will then automatically install.
Apr 25, 2009 | Logitech Cordless Desktop LX300 Cordless...
Logitech wireless keyboard and mouse (ex 100) won't connect
The mouse and keyborard have to be in direct view of the reciever. Even a small obstruction will effect the operation
Nov 02, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Cordless Keyboard and mouse -Instruction book
Commonly referred to as the LX300, the PDF manual for this logitech cordless optical mouse/keyboard combo may be downloaded from the following site:
Aug 14, 2008 | Logitech diNovo LX300 Keyboard/Mouse
V320 cordless opitical mouse for notebooks
Yes, the cordless mouse will work on a desktop system, but because of the limitations in distance between the mouse and the USB transceiver, you will have to plug the transceiver into a USB port on the front of your system, or to a USB port on your keyboard or monitor if they have one.
You will also have to install the correct drivers on to the desktop system using the INSTALL CDROM that should have come with the V320 mouse.
Hope this helps!
Jul 29, 2008 | Logitech Cordless Mouse
Hotkey problems
I had the same problem but finally found a solution hidden in the depths of Logitech. It's quoted below. I had to do it a couple of times before it worked, and it seems that you need to reconnect the mouse at the same time. I didn't the first time and then the keyboard refused to work. (Finger trouble?) :-(
The following is from :-
This article applies to the following products:
Cordless Access Duo
Cordless Acess Duo Optical
Cordless access keyboard
Cordless Elite Duo
Cordless MX Duo
Cordless Navigator Duo
You may be able to reset the keyboard and resolve the problem by clearing the keyboard capacitors. To do this, remove the batteries from the keyboard and type continuously on as many keys as possible for one to two minutes. This action should simulate touch-typing; you should not press and hold only some keys down.
After you clear the capacitors, replace the batteries and synchronize the keyboard using the following procedure:
  1. Make sure the batteries are in correctly. A diagram on the device itself or in the Getting Started Guide should tell you the correct polarity for the batteries.
  2. Press the connect button on the receiver.
  3. Press the connect button on the bottom or right hand edge of the keyboard.
    NOTE: If you are using a Cordless Desktop System, you must do this procedure for both the mouse and the keyboard.
The "Connect" button on the mouse is quite small and usually requires a pencil tip or other small object to push it. Remember, ALL Logitech cordless devices will have a synchronization button. If you have the "Cordless Mouse" with Model Number (M/N) M-RN67, the button will be located in a small hole on the lower portion of the back of the mouse. You will need a paper clip to access the button.
Jul 03, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Cordless keyboard and mouse" then install, then press left ctrl + alt + f12 , and you see Miracle, type that code and you board will work
Jun 26, 2008 | Logitech Cordless Desktop MX3200 Laser...
Logitech cordless mouse and keyboard installation
You probably already done this but try pressing the receiver button and while it is flashing turn the board over and press the small reset/connect button on the bottom of the board and also the reset/connect button on the bottom of the mouse. It should work okay after that. here is hoping that helps. Bud
Dec 20, 2007 | Logitech Cordless Desktop MX3200 Laser...
Computers & Internet Logo
300 people viewed this question
David Payne
David Payne
