Question about Samsung SP-S4243 Television
Samsung TV flickering image
I have a Samsung Plasma SP-S4223 tv that is about 15 mos old. It has started to show some blue pixels on the left side that flicker while watching either HD or regular channels. It seems to be getting worse over the past month.
  • rdim Mar 22, 2008
    Seems to be linked to interference between the cable and the speakers. Only occurs with cable television, not with DVDs. It is worse with HD stations than others. Moving the speakers away from the television have helped somewhat, but not completely solved the problem.
  • 29 Answers
You seem to have what is called error diffusion. Either call samsung about it and arange service or do it on samsung.com. What kind of warranty do you have? Depending on your date of purchase you might be able to get samsung to help cover it or pay for it all.
Posted on Mar 09, 2008
  • Christa Dening
    Christa Dening Jun 14, 2008
    Advise to change the connections your using with the cable box, try the one with the dvd player. If that doesn't help than the problem is with the cable box.
I need owners manual for my Samsung Plasma TV model SP -S4223
You can download a pdf copy of the manual at the link below. Click on or copy and paste the link into your browser and save the document on your computer. The document opens with Adobe Reader.
http://downloadcenter.samsung.com/content/UM/201105/20110502125808069/BN68-00991J-00Eng_110502.pdf
Nov 12, 2011 | Samsung SP-S4243 Television
I have a Samsung SP-S4223 42in. EDTV.
This is called tiling and this happends because of a weak signal from whatever device you have hooked to it weather it be cable or a sat dish. Try checking and makie sure you have good signal to this. If this matter gets wrose then you would need a repairman. Thanks
May 24, 2009 | Samsung SP-S4223 42 in. Plasma EDTV
Samsung Plasma TV has horizontal lines of colored dots
I have the same problem, currently searching for a solution. Have you resolved your problem yet? Looking to repair myself, any tips or ideas that you have/expirenced would be greatly appreciated. Thanks, Todd
Apr 10, 2009 | Samsung SPN4235 42 in. Plasma HDTV
No picture or sound
This type of repair might not be a DIY since requires the use of a multimeter to check all the voltages from the power supply to all the circuitry in your plasma.
First step should be to measure all the voltages to the Y and X sustainer boards and since you do not have audio as well to check the 12 volts source as well.
If your plasma is less then a year old, still cover under manufacturers warranty.
Oct 20, 2008 | Samsung SP-S4223 42 in. Plasma EDTV
Plasma tv
this happens because of panel conditioning. as the panel ages it requires different voltages to produce the picture.it takes about 1000 hrs before it has conditioned. it is a simple adjustment a tech can do for you. when this adjustment is made no other adjustment will be needed for this problem.
Jan 03, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Bright blue pixels on left side of plasma screen
try to adjust Vs & Vsc within 5% of their spec on the power supply board when you notice the problem.
Jan 01, 2008 | Televison & Video
Blue snowy pixel areas on my plasma
some of these panels were mis-calibrated from the factory after not aging long enough. Let the TV run for atleast 2 hours and adjust the Vs and Vscan voltages. When it is blue in the left I have found generally the Vs is about 10 volts too high.
Jun 16, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Red and blue specks
some pixels may have burned out. i'd call the manufacturer and see if tech support cant help you out. but it sounds like a pixel problem
May 02, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung SP-S4243 Television Logo
433 people viewed this question
Jerry Greenberg
Jerry Greenberg
