Question about Whirlpool Calypso GVW9959K Top Load Washer
CE error hi i have a calypso and when i turn it on to wash it gives me someting saying CE what does it mean and how do i fix it please email me at zplxe@hotmail.com please and thankyou
  • help 101 Mar 09, 2008
  • starrigger Mar 16, 2008
    I too have a Calypso washer with CE error code. The tech sheets indicate this is a problem with the motor control board. The first time this occurred was 2 months ago. I determined with a multimeter that the fuse on the board was blown, which means you need to replace the whole board. I bought a new board from Sears Parts, installed it, and was back in business. (Cost about $160 with shipping.)
    Two months later, same problem. The fuse on the new board is blown. Sears is sending me a replacement part, but I'm wondering if the part was defective or if something else is causing that fuse to blow. Can anyone tell me how I might determine if there's a secondary cause?
    I've performed resistance tests on the motor the board connects to (using the tech sheet that came with the washer). Everything on those tests looked good. Is there something else that might be causing an overload on that fuse?
    Thanks.
    Novelist:
  • 131 Answers
There is a Rotor Position Sensor on the motor under the tub. 1st try unplugging and re-installing the sensor connector several times to clean the contacts. If this doesn't work, replace the sensor.
Posted on Mar 10, 2008
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
"CE" comes up when we turn washer on. We've
Hi
CE is a communication error which flashes if there is any breakdown in communication between the machine controller and the motor controller. To solve this issue check the drive motor and the motor controller and replace the part that is bad. Hope this helps...please post back for further assistance.
Daniel
Mar 12, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Code on washer is CE--What does this mean and how do I reset the unit??
communication error if there is any breakdown in communication between the machine controller and the motor.controller, ce flashes and the unit beeps once
Oct 04, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error message CE displaying. Machine will not run.
Hi, concerning the CE error, the tech sheets indicate this is a problem with the motor control board with a blown fuse on the board. The solution is to replace the board....
Oct 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Flashing ce
Most all error codes on a Calypso end up being a pump problem. If all the water can't be pumped out, the tub gets too heavy for the motor to handle and it will cause a CE error code. Something like lint or wire or screw may be caught in pump impellar. If your not familiar with repair you need to call for service.
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Whirlpool Calypso washing machine, model
communication error. changing the MCU. sometimes a bad pump could be the problem
Kenmore elite calypso 24082 error code CE
On the ccu, the board on the right is usually the culprit, I have recently replaced one with that same error but I would first unplug it and remove and re connect each plug on the board looking for dark connections or dialysis, corrosion. If not fully insert each plug and try again.
Sep 06, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
115 people viewed this question
Dan Webster
Dan Webster
Sal De
