I have a d-link DI-524 i am trying to connect a new laptop to the router but it asks for passwords which i don't have i reset the router and went through the install processbut when i type the 19216801 on the browser it says no componet can be found what do i do to make this thing work greg
  • 818 Answers
    Brigadier General:
  • 3,614 Answers
Hello Greg,
Try 192.168.2.1 / 192.168.2.0, post back and let me know..
micro
Posted on Mar 09, 2008
  • 13,433 Answers
Hey man.
First we need to find the correct ipaddress of the device.
press start -> run -> ipconfig
you should see something like this:
Windows IP Configuration
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : saunalahti.fi
Link-local IPv6 Address . . . . . : fe80::8c84:e222:b747:1969%8
IPv4 Address. . . . . . . . . . . : 192.168.11.2
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.11.1
Note the default gateway is the address of the device so
now open up your browser and type: HTTP://192.168.11.1
Remember to replace that ip with yours! that is how I would connect to mine :)
Then the login screen should come up. I havent looked in your manual yet but if its nesasery il look up the default passwords for you but.
You can try the following:
User: Password:
Admin 1234
root 1234
root
root 0000
commend if you need more help.
  • Ekse Mar 09, 2008
    the default password should be
    username: admin
    password: (EMPTY NOTING HERE)
How do I Reset My Password in My D-Link DI-524? I've Tried the 192.168.0.1, but Nothing Happens, just keep getting the Password Re-Set window
If you forgot your password, you can reset the router to it's factory defaults (You will lose all your settings/changes you made).
You can go here to see how to do it.
http://technicallyeasy.net/2008/02/how-to-reset-d-link-di-524-wireless/
Oct 13, 2011 | D-Link AirPlus DI-524 Wireless Router
I reset my computer to original setting and forgot to write down my wifi password. How do i recover it?
You don't - you reset the router with the button at the rear and you login into it using the default one (admin) and do all the setting again as explained here
Sep 19, 2011 | D-Link AirPlus DI-524 Wireless Router
I lose my original cd kit installion for d-link di-524
You don't need an installation CD.
If the default password has been changed then -
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings. To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 23, 2011 | D-Link DI-524 High Speed 2.4GHz (802.11g)...
When i run wisard it ask about old passworld
This FAQ is for the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624M, DI-624S, DI-774, and DI-784.
Step 1 Open a web browser and enter the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter.
Step 2 The username is admin and the default password is blank (nothing). Click OK.
Step 3 Click the Tools tab and then click Admin to the left.
Step 4 To change the administrative password, enter a new password in the Admin section.
To change the user password, enter a new password in the User section.
Step 5 Click Apply then click Continue to save the settings.
Note: If you forget your password, you can reset the unit to factory defaults.
Click here for instructions.
Nov 02, 2010 | D-Link AirPlus DI-524 Wireless Router
Tried resetting the password
Resetting your means that all information will be lost
you will need to configure your router again as you did when you first bought it
May 18, 2010 | D-Link AirPlus DI-524 Wireless Router
Cannot connect laptop to wireless. Apparently my password is wrong (even though I am sure it is not). Have tried to reset wireless router (D-link DI 524) without success.
Make sure that the password that you have is correct if not then you will need to check the password of the wireless network.
Click Here for more info about wireless network.
Oct 08, 2009 | D-Link AirPlusG DI-524UP Wireless Router
Need passphrase from D-Link router DI-524
1. if the default login never been modified b4, u can hook a network cable to the router, type "192.168.0.1" to enter the router config. Once inside, u can edit the password or disable it.
*U may prompt for username (admin) and passsword(empty).
2. If the default login has been modified and u r not able to enter the router config, u can just reset the router by inserting a pin to the small hole to get back the factory default settings. Then u can perform above step again to reconfigure your wireless router.
Mar 13, 2009 | D-Link DI-524 High Speed 2.4GHz (802.11g)...
Cannot connect DI-524 to VISTA
There is nothing on DI-524 what is Vista specific. Make sure you installed your dirivers properly. I have the same , works without problems.
Jan 22, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
Forgotten key to access my secure d-link wireless router model
hey what you can do is you can reset the entire router... by using the reset button on your D-Link router... Or else you can also access the router by using the following IP address in the internet exlorer...
try 192.168.1.1 or 192.168.1.0 & then go to the wep settings & reset the router or change the password for the router...
Jan 18, 2009 | D-Link AirPlus DI-524 Wireless Router
New laptop can not connect to Di-524 router
connect the router to pc via a ethernet cable, then there should be a reset pin hole on the back, press this, the router will restart and clear the password, restart pc next, then type in the routers address again and you should connect.
You can then remove the cable and connect using the wireless connection
Sep 04, 2008 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
263 people viewed this question
David Payne
David Payne
