Need to replace Foxconn Model PV702012M CPU cooling fan. What will fit?
  • 349 Answers
If it was me i would take the old one off and go my local pc shop and ask for one the same as it .
good luck
Posted on Mar 15, 2008
How to check for Asus UDQF2PH62BAS CPU FAN compatibility?
The only way to see if this replacement part will work for you or not, your product's Part Numberhave to be the same with our replacement Part number. If it's on the list, then it will be compatible. (Your Deivice Model number is not good enough to verify correct product).Part numbers can be located on your Asus UDQF2PH62BAS Cooling FAN or you can check your user's manual. Another way to check for compatibility would be to check the listing within the "Fits the following model." The list will provide you with the product model that would be compatible with the List item. for more information :
Mar 28, 2012 | Computers & Internet
How do i quiet this fan down? 478
What do you mean by Quiet it down? If the fan is running at an excessive speed, try to look in the Bios (Hardware monitor) settings to set the CPU fan to auto. This will provide a balance between fan speed and cooling.
If the fan itself is mechanically noisy, then you are probably looking at a shot bearing, causing it to run noisily. For the cost of a new heatsink and fan (about £20.00), its worth considering replacing it
Feb 10, 2010 | Foxconn (CMIP31S) CPU Fan
I broke my cooler :(
You can solder the two open ends of the wires/base together. Generally, it doesn't hurt at all to have the yellow wire not connected. As long as the fan is still running, you will be fine. The yellow wire gives information about the fan RPM. You just won't be alerted if the fan stops working.
Jan 25, 2010 | Foxconn CPU Cooler Fan CPU Fan
Foxconn CPU fan making noise
It sounds like the fan bearing is shot, I'd recomend not using the computer until fan is replaced.
yes it is possible to replace the fan, i would recomend that you replace it with an aftermarket cooler. all you need is what kind of CPU you have, then find out what kind of socket it is, from there you can find the cooler you would like.
Jan 27, 2009 | Foxconn CPU Cooler Fan CPU Fan
Looking for cpu fan or combo heatsink for a foxconn mother board
CPU heatsink/fans are usually sold as a unit at, as well as al other computer supply places. Fan and heatsink are specific and  must match CPU and socket.
Jan 17, 2009 | Coolmax CPU Fans CPU Fan
Your motherboard specs are at
Looks like you could go up to a 3.8GHz P4, make sure you get a fan that will cool it properly.
Dec 28, 2008 | Foxconn 661FX7MF-S Motherboard
Could a faulty fan cause my pc not to switch on
Normally the computer will still come on even if the fan is not there but then will sometime display cpu fan warning and then sometimes turn off depending on motherboard and so on but unless the fan wires are shorted out or something this is most likely not the case
It sounds like your power supply has gone bad
Do you hear any type of winning sound or like a discharge sound that is barely noticeable when you turn it on? You would probably almost have to put your ear right next to it to hear it or listen carefully when you press power because that sound is one of the capacitors in the power supply that has gone bad and the power supply would need to be replaced
Do you have another power supply you can use to see if it works with a different one?
Nov 25, 2008 | Intel Foxconn: Foxconn CPU Cooler For P4...
CPU Cooling Fan
Here's a link for one of the cheapest I found. You can also check Ebay, you might get a better deal.
Jun 25, 2008 | Foxconn Computers & Internet
Audio driver
I think you might be picking up the wrong model, RTL (Realtek) 8100 series is a network device. Can you make sure of the model number please.
If you still need the drivers for RTL (Realtek) they can be found at:
If not please supply the full details of the device your are looking for.
May 11, 2008 | Intel Foxconn: Foxconn CPU Cooler For P4...
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
