Question about Canon Sure Shot 80 Tele/Date 35mm Point and Shoot Camera
Where can I get a manual for this 35 mm camera? Canon does not have one on line.
I settings on the dial on the back of this totally automatic point and shoot are missing and I can't figure out what they were were. I have noticed that one opens the lens, and before I put in the first roll of film, nothing seemed to control the auto flash. Now the auto flash doesn't work, and I have no idea what this little dial on the back can do to help, if anything. This is very specific to this particular camera. Please, no generic film use answers.
  • 2,179 Answers
The dial has six positions. If you rotate the dial fully clockwise, you are at the "Auto" position. In this position, the flash will fire if light is insufficient.
One click counterclockwise from this is "Auto with Redeye Reduction", and a preflash lamp will fire before the shutter to reduce redeye.
The next click counterclockwise is the "Off" position.
The next click counterclockwise is the "Flash On" position, and the flash will always fire with the shutter.
The next click counterclockwise is the "Flash Off" position, and the flash will not fire.
Full counterclockwise is the "Self Timer" position, and the shutter will fire 10 seconds after the button is depressed.
Posted on Apr 16, 2008
My 580EX clicks when I turn it on... the Wide Angle shield is totally in. Plus it is set on ETTL but the Zoom - - mm and the rectangle box is flashing... it will not respond to any buttons pushed or the...
Jack, place the flash on the camera.
Then do the following:
1. Load up Canon EOS Utility software
2. Connect camera with USB Cable to computer
3. Turn on camera
4. Click on EOS Utility
5. Click on flash setting
More help send to my email.
atdlee@netzero,com
Jan 17, 2014 | Canon SPEEDLITE 580EX TTL Flash
What is the focal lenth on the powershor A1300
Your camera has a 5.0 - 25.0 mm (35 mm equivalent: 28 - 140 mm) lens with apertures from f2.8 - f6.9.
Unfortunately you don't have a manual mode or an aperture priority mode where you can set the aperture yourself.
There's more about your camera here: http://is.gd/WGRntf
Feb 05, 2013 | Canon PowerShot A1300 16 Megapixel Digital...
If you had a compact camera it would say 10x zoom what is the equivilent in a 70mm -300mm tamron
A 35-80 mm lens is 2.3X zoom. Divide 80 by 35 and you'll get the result.
It is usually better to know what the focal length of a lens in "35 mm equivalent" is and judge by that, rather than relying on the "X" power of the lens. For instance, most point and shoot cameras start at about 35 mm and have either a 3X or 4X zoom. This would make it a 35-105 or a 35-140. I've seen some that start at 28 mm, though. A 3X starting at 28 mm is 28-84 and a 4X is 28-112. Neither one is a particularly strong telephoto lens and the 4X is just about the same as the 3X that starts out at 35 mm.
It's also important to realize that tradition dictates that lens focal lengths are usually expressed in terms of "35 mm equivalent," where "35 mm" refers to a 35 mm film camera. This is because of the relation between the sensor size and the actual focal length of the lens and the resultant angle of view of the lens.
I have one point & shoot that is actually a 5.8-24 mm zoom. This is a 4X zoom. The 35 mm equivalent is 28-116 mm. The sensor is 7.2x5.3 mm. (1/1.8") (And I wish I knew someone who could explain how the heck they came up with sensor size terminology!)
I have another point & shoot that is actually a 5.7-17.1 mm zoom. This is a 3X zoom. The 35 mm equivalent is 34-102 mm. "How could a shorter focal length give a longer 35 mm equivalent?" you might ask. It's because the sensor is only about 5x4 mm. (1/2.5")
I have a few Nikon DSLR's and - thankfully - they all have the same size sensor. They all have a "lens factor" of 1.5. This means that you just multiply the actual focal length of the lens to get the 35 mm equivalent and then you can make comparisons accurately from camera-to-camera. Most Canon's, for instance, have a lens factor of 1.6. On a Nikon DSLR, a 28 mm lens is the "35 mm equivalent" of a 42 mm lens. On most Canon DSLR's, the same 28 mm lens is the equivalent of a 45 mm lens.
These example are just to show you how freaking confusing it can all become if you try to make sense of the "X" power of a zoom lens.
Bottom line...
Check the 35 mm equivalent specifications for the lens. This way, you will be leveling the field and comparing apples to apples. More or less.
Jul 10, 2012 | Tamron 75-300mm f/4.0-5.6 LD Lens for...
Canon prima super 115 film type camera which type batery use
It takes one 3V lithium battery, CR123A or DL123A or equivalent.
If you need a manual, you may download a copy at http://www.cameramanuals.org/canon_pdf/canon_sureshot_prima_105_zoom-1.pdf
Apr 20, 2012 | Canon Prima Super 105X - Point & Shoot /...
I just got a Canon EOS Rebel X 35 mm camera, it didnt come with a manuel so Im trying to figure out the best settings to put it on and it take good pictures.
You can download the manual from
http://butkus.org/chinon/canon/canon_eos_rebel-x_rebel-xs/canon_eos_rebel-x_rebel-xs.htm
The best settings depend on the situation and the effect you're trying for. That's why cameras have so many possible settings.
Apr 25, 2011 | Canon Cameras
Canon 580EX clicks when turned on, cannot push buttons on back
Send it in to canon for service. This is not a simple problem that can be fixed in this forum.
Jan 14, 2009 | Canon SPEEDLITE 580EX TTL Flash
Film wound on wrong side of camera
It sounds like you have a jam.  When you have finished taking shots and have used all the film, you must press the film-rewind button on the underside of the camera; this does not rewind the film, but allows you to commence the next step.  Once you have done this, flip up the rewind-crank on the top left hand side of the camera. It is situated on top of the film speed dial. turn this clockwise until all the film is back in its cartridge.  You should now be able to open the back of the camera.
I hope you have fun with your t50!
Dec 11, 2008 | Canon EOS-AE-1 35mm SLR Camera
Manual shooting mode problem.
The exposure compensation dial (at the back) doesn't work when you're in Manual. In Manual, you set the shutter speed and aperture to get an image with the amount of over- or under-exposure you need. In the view finder, the "exposure meter" at the bottom shows how much light there is where the lens is pointed. When it shows what you called "2-stops", its really underexposed. Thus your black images. You need to increase ISO, open the aperture and slow down the shutter speed (or a combination of these 3 options)
Set your camera to P or full-auto. Do the photos turn out ok? If they do, then there's nothing wrong with your camera and you just need practise on the Manual mode.
Aug 13, 2008 | Canon EOS 40D Digital Camera
Canon Sure Shot 80 Tele/Date 35mm Point and Shoot Camera Logo
212 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
