I have a Brother FAX-2800 fax copier I bought in 2001. During the last year the paper feed has routinely failed, causing a "paper jam" error message. Something is wrong with the paper feed. Typically, the paper feed will load about 25% of the page length into the machine, then freeze up, then the message appears. I can usually get it to work by removing the paper, putting a different page on the top and bottom, then reloading the paper. Sometimes I have to do this several times. Is there anything I can do to improve this bad performance? When I look into the innards of the paper feed I don't see anything obvious, but maybe dust/dirt has accumulated on the rollers. Got any advice for this? Thanks. --Mike Potterfield
    President:
  • 3,130 Answers
You need to replace the roller as well as the presure spring. This happens on these all the time. As a matter of fact this happens on a lot of inexpensive printers as well. Someone told me they had a repair kit for this but I never found it. Good Luck
Posted on Mar 09, 2008
Keep have paper jams
1. Make sure the paper feed rollers are clean, You can clean them with a soft cloth moistened with alcohol. Don't use paper towels.
2. Also make sure all the sensors inside the printer are clean and that there isn't any dust or debris on them.
3. Look for any small bits of wayward paper that may be stuck in the paper path.
Feb 18, 2011 | Brother IntelliFAX 2800 Laser Fax
I had a paper jam. I removed the paper jam already but computer says it still there. How do I reset it?
It's possible there's still a small piece of paper or dust stuck in the paper feed. Try blowing the area out with compressed air.
Aug 31, 2009 | Brother IntelliFAX 2800 Laser Fax
Original jammed in fax feeder of Brother Intellifax 2800
lift document feeder cover and look for paper. if no paper is present there are one or two switch levers that are on the bottom of feeder cover. make sure they can move freely and are not stuck.
May 27, 2009 | Brother IntelliFAX 2800 Laser Fax
Brother Intellifax 2800 Paper Jam Issues
Pull open the doc feeder and look for an obstruction. A wayward staple, paper clip, push-pin, post-it note?
Sep 27, 2008 | Brother IntelliFAX 2800 Laser Fax
Paper not feeding
If there is no paper jammed inside the machine, then look at the "paper out" roller, this is the last roller in the paper path. I would suspect it is out of alignment.
May 11, 2008 | Brother IntelliFAX 2800 Laser Fax
NOISE OR PAPER GETTING STUCK IN FAX MACHINE WHILE SENDING FAX
look in or around scanner area to see if there is any foriegn material trapped in paper handling area.
This is area where the original document feeds through
Jan 22, 2008 | Brother IntelliFAX 2800 Laser Fax
uplug from the wall and replug to remedy this problem
Dec 31, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother Intellifax 2800 Plain Paper "NO DOCUMENT"
no document mean that there is not paper in the paper feeding
Aug 29, 2007 | Brother IntelliFAX 2800 Laser Fax
Document feed doesn't
drive gear is wore down on bearing surface good luck finding one
Apr 11, 2007 | Brother IntelliFAX 2800 Laser Fax
Computers & Internet Logo
47 people viewed this question
Alun Cox
David Payne
David Payne
