Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
Problem transmitting i have a pair of T5720's, one of them transmits and receives fine, the other one i can only transmit (won't receive). Anybody have any ideas why this may occur and a way to resolve. Thanks
Hi there!
i bought the same pair of motorola, and i hav the exact same problem
i found out that they work good only when they are on the same channel but the sub channel must be set on 0.
for example channel 22 sub channel 0 .
Posted on Apr 28, 2008
    Sergeant:
  • 250 Answers
Hello jayhawkrx,
Check the Continuous Tone Coded Squelch (CTCSS) settings on all the radios. (Note that some manufacturers refer to this feature as a Privacy Code or Quiet Code. The actual name of the feature may vary.) This feature encodes a low-frequency signal on your radio transmission. This signal is below the range of human hearing but can be detected by other radios. When the CTCSS feature is active your radio will ignore any signal that it receives that does not have the proper tone encoded on it.
In order for these radios to communicate, all of the radios need to be on the same channel and have the same CTCSS code programmed or the CTCSS feature must be disabled.
I suspect that CTCSS is activated on one of your radios but not on the other. This would result in the situation you describe.
Also take note that when using different brands / models of radios to communicate with one another that the CTCSS code numbering scheme may not necessarily be the same from radio to radio. For instance, CTCSS code 4 on the Motorola TalkAbout series actually corresponds to code A on the Motorola Sport models.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Posted on Apr 07, 2008
I have a set of Motorola T5720 walkie Talkies. I cannot determine if one of them is not receiving or the other is not transmitting.
One radio works properly, the other can receive. I assume there are more than two by the question. Check and then rotate you batteries, mark on the working unit battery that it is GOOD. Transmit takes a great deal more power than receiving. Batteries, even un-used only last 18-24 months typically. If no joy, then check your programming but I think that is unlikely. It really sounds like a power/battery issue.
Aug 28, 2016 | Motorola Talkabout T5720 (7 Channels)...
Doesn't transmit
Check your battery. Transmitting takes more energy than receiving. Also, check your frequency and code settings. The radio you are using this one with might have a different code setting than yours. http://shop.giantintl.com/Manuals.asp
Feb 13, 2014 | Motorola Talkabout T5720 (7 Channels)...
I have a pair of GXT 850 motorola radios. One receives and transmits, the other only receives. Any ideas
try by changing its chanel and sub chanel if subchanel is not the same it will recive only.. try it..
Dec 14, 2012 | Motorola Talkabout T5720 (7 Channels)...
Hello i have a yaesu ft-2900 it receives just fine but when i transmit it shows error. this radio is brandnew
Hi Gerald,
When you say you used the software to download frequencies, do you mean as in from the internet, or did you have to input frequencies via the software on your PC?
There is a difference, that's the reason I ask.
If, by using the software you manually input the frequencies, then did you input both the output and input frequencies or just output for each channel?
If the latter is true, and you are trying to access another user via a repeater, then that is the error.
Repeaters generally, require both the input frequency = the frequency you transmit on, and the output = the frequency you receive on.
Without both frequency pair, you won't be getting out, and no won can hear you, as you are basically transmitting as a simplex station on a repeater allocatted channel, hence the error message on your display.
The radio you have is used by many amateurs & CB operators, and both group utilise repeaters within their allocated spectrum, excluding 27 meg CB, which is simplex only, but with SSB included.
I hope this answers your query.
Best regards,
Peter
Nov 28, 2011 | Yaesu Radio Communications
One radio receives and transmits the second only transmits does not receive. Is this a setup problem, what am I missing?
You're not trying to use a privacy code on one radio without using the exact same privacy code on the other radio, are you?
Jul 11, 2011 | Motorola Talkabout T5720 (7 Channels)...
I'm using d-link dwl-3200 ap ( three) Received Frame FCS Error Counts indicate a problem? ___________________________________________ WLAN 802.11G Traffic Statistics Throughput Transmit...
Transmitted Error Count 4734440
Ack Rcv failure Count 15269951
  • As per the above there are error on Transmitting the packet and also for receiving the acknowledge packet.
  • Please check whether any disturbance in the link
  • Each PPP packet has a checksum attached to ensure that the data being received is the data being sent. If the FCS of an incoming packet is incorrect, the packet is dropped and the HDLC FCS count is increased.
  • Another reason for seeing too many FCS errors may be that the remote end has stopped talking PPP.
Feb 27, 2011 | D-Link AirPremier DWL-3200AP 802.11g/b...
Can Receive but not Transmit
1) Double check your interference code eliminator and the Qt filter. Make certain they are all set identical.
2) If you are still having trouble, shut off the Qt filter.
3) Then if you still have trouble shut off the code. (Off is sometimes "zero" or "n" for no.)
4) If the above steps do not help you have either a defective radio, or a bad battery. Switch the batteries out of the working units to the non-working and see if the problem switches to the other units. If so, replace the battery packs. (Note: it takes more battery power to transmit, so the problem would first show up in the transmit area.)
Best regards.
Nov 10, 2009 | Motorola Walkie Talkies 2-Way Radio
Motorola t5720 one buzzes and you can't hear transmission. It transmits to its partner just fine. It just won't receive transmission form its partner, just a loud buzz
Try trading the batteries between the units and see if the problem moves to the other radio. If so, replace the battery pack. If the problem persists, you have a defect radio, which needs replaced.
Best regards.
Nov 01, 2009 | Motorola Talkabout T5720 (7 Channels)...
Hisses/squeals when transmitting
Check the input voltage into the radio while in transmit. The voltage maybe dropping as you go into transmit which causes it to drop into receive. That in turn allows the voltage to come back up. With your finger still on the PTT it tries to transmit again, etc. This could cause a feedback squeal and other symptoms.
May 30, 2009 | Uniden PRO538W (40 Channels) 2-Way Radio
Staying keyed up after button release
I have never seen this problem before, check if the VOX is activated, this could cause to transmit the radio, but the voice must be transmited. check if the Accesory connector is not dirty, clogged or damaged
Feb 08, 2007 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
415 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
