Question about Frigidaire 24 in. GLD2150RCC Built-in Dishwasher
Rinse Aid Reservoir Will Not Fill
When I try to fill the unit with rinse aid, the liquid just sits there and will not drain into the reservoir. I can recap it and close the door and it still does not flow into the reservoir, so I don't think it's something as simple as an air bubble. Tried brand name and store brand rinse aids with the same results.
What could be causing this?
SOURCE: Rinse Aid
We have the same problem on a Kenmore model 665.17032. Is is plugged or more likely an electrical problem for release (if that's how it's actuated)? I fine several posts on different sites, but no comments or solutions. Should be a relatively simple issue, surely. Simple mechanism.
Posted on Oct 10, 2008
aborcass
  • 2651 Answers
SOURCE: rinse aid leaks into the dishwasher when the door is closed
sounds like acrack in ht eseal of hte dispensor itself, replacing the dispensor is the remedy
Posted on Nov 13, 2008
SOURCE: put rinse liquid detergent in dishwasher rinse aid compartment.
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart.
2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
Posted on Apr 30, 2009
SOURCE: Dishwashing liquid was added to the rinse aid, how
Get a squeeze bottle of warm water and flush the container out.
Posted on Feb 21, 2010
FixinFax
  • 3085 Answers
SOURCE: i put liquid dish soap in the rinse aid dispener
get an ant ifreeze tester from an auto parts store to **** the rest out.
Posted on Jun 27, 2010
Hotpoint Aquaris df62 - the rinse aid reservoir seems to be blocked with crude and won't allow me to fill it up..How do i clean this out?
you cannot clean it out ,the whole dispenser needs to be replaced . you should be able to get the dispenser kinda cheap
Feb 20, 2013 | Dishwashers
Why does my rinse aid indecator light stay on?
Generally, it's because the Rinse Aid reservoir is empty. Have you added rinse aid liquid to it? If not, then that's the problem. If you have added rinse aid to it, it may not have been enough or the screw on lid to the dispenser was not replaced properly. Those are the things you start with first, in troubleshooting the problem.
Hope this helped to solve the problem.
Mar 10, 2011 | Grilling
Greetings from Downunder, i have a HDWSE12 dishwasher Rinse aid light flashes all the time and it won t go. I put dish liquid in rinse aid container - still flashes. Don't normally have to use rinse...
the rinse aid compartment has to be one of the biggest things in your unit. it helps with drying process or you will have wet dishes, helps with spots, and also with the cleaning process, this is what you can do . add jet dry or rinse aid not soap .fill compartment then close door ,then raise and lower door 3times then open the compartment door and add more repeat this process until you cant add anymore. this will pull all of the air out of the dispenser and allow you to fully fill compartment . the light should go off .
Mar 04, 2010 | Dishwashers
Dishes are not always dry, even after sitting overnight
hi
make sure you are using rinse aid as this helps to evaporate the water at the end of the cycle in the drying stage. I know tablets have rinse aid built into the tablet but this can wash away on some wash cycles and do nothing so even if you are using tablets i reccommend still using rinse aid.
Jan 24, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
13 year old daughter put liquid dishwashing soap in the rinse dispenser. Now all dishes come out covered in soap scum. How do I get liquid dishwashing soap out of the rinse dispenser?
Sorry but thats funny!!lol About the easiest way I know to tell you is take a turkey baster or marinade injector & draw as much as you can out of the reservoir,fill it with water & repeat until you get very little foam when putting water in it.Fill with rinse aid & the rest will just have to work its way through.Should be fine after a few wash cycles.
Jan 07, 2010 | Admiral 24 in. DWUA601 Built-in Dishwasher
The rinse aid reservoir seems to be gummed up and will not fill all the way is there a way to clean it out?
The short answer... NO. But, be careful... There are a lot of older Maytag dishwashers that were recalled due to rinse aid dispenser leaks causing a fire hazzard. Check here: http://www.cpsc.gov/cpscpub/prerel/prhtml07/07094.html
If your unit is covered under the recall the entire inner door will be replaced and you won't have to worry about cleaning the dispenser.
Oct 16, 2009 | Maytag Dishwashers
Put rinse liquid detergent in dishwasher rinse aid compartment.
Apr 04, 2009 | Kenmore Dishwashers
Drying Agent reservoir problem
if the resevior is full then it should go right in.. if you try filling it every day it wont take anymore.. the rinse aid should only be filled maybe once a mmonth or once every other month
Jan 20, 2009 | Kenmore 24 in. 15652 Built-in Dishwasher
Dishwashing detergent in rinse aid compartment
not good there is no way to drain it out. you might be able to take the door apart and take off the rinse aid reservoir and clean it out
Dec 20, 2008 | Dishwashers
Frigidaire 24 in. GLD2150RCC Built-in Dishwasher Logo
860 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
