Tascam DP-02 Portastudio error message - Poor memory
I'm getting an error message when I try to recording saying poor memory and it won't record record. What do I need to do?
SOURCE: Tascam DP-01 FX/CD
Check to find out the size of the active FAT partition. You may have a 'less than optimum' amount of memory left in that partition. Switch to another partition and see if you can record in that one.
Posted on Dec 10, 2007
SOURCE: Tascam DP-01 FX/CD Portastudio
froze
Posted on Dec 13, 2007
  • 189 Answers
SOURCE: Tascam DP-01 FX/CD Digital Portastudio
Here's a link to a forum where someone else encountered the same error. Seems it was due to running out of disc space in that instance.
http://www.tascamforums.com/lofiversion/index.php/t10089.html
Posted on Jan 03, 2008
robotek
  • 1512 Answers
SOURCE: Hi there, Do you know
Hi there
You can get the quick start guide an the full manual from here
Good luck and happy recording!
regards
Graeme
Posted on Feb 28, 2008
headman333
  • 82 Answers
SOURCE: How do I connect an
first you have to check the output terminal of the AKA and the input of the tascam. If they have the same feature, you can buy the connector on a store but if they are not of the same feature maybe you can buy a connector for each of those and find an adapter to establish a connection to for it.
P.S. If this helps please rate me. Thanks.
Posted on Jul 09, 2008
How do I import a CD created on the Tascam DP-02 into the Tascam DP-32?
I have the Tascam DP-02 it uses a fat 32 partition, Fat 32 partitions are pretty much obsolete replaced with the New Technology Filing System or N T F S for short. Using the DP-32 systems software try plugging the DP 32 in to your computer once the software for you new unit loads locate and open the fat 32 system folder I'm not sure if the DP 32 uses the same fat 32 partition, But if it does the fat 32 folder should be there, Locate and open it you should then be able to move or delete your recorded material as desired
Oct 04, 2014 | Tascam DP-32 Portastudio 32trk Digital...
My tascam dp 02 started up with this mount error message I bought a tascam dp 02 for my son for christmas. When I plug it into the mains the display shows ' mount error :oc /please pwr off'. my email is...
The TASCAM DP-02 Owner's Manual has no reference to a mount error in it. There are many people online complaining about mount errors on their computers, mac and win, when hooking the tascam up via USB, but your post suggests this error was on the DP-02 itself, is that correct?
I get less than a dozen hits of people asking this question online, and absolutely no useful answers or responses.
Do you have the DP-02CF model? If so, it may be a faulty CompactFlash Type I card that it is trying to mount. If there is a disk in the drive, I'd remove that cd in case it is trying to mount a bad disk.
I can most likely help troubleshoot a troublesome USB-to-computer connection, but otherwise I'm going to have to refer you to TASCAM customer service, (although I must say the forums I've perused have little positive to say about them.) TASCAM support in the UK (a guess, but you did use the term 'mains' in your post) is provided by TEAC UK Limited at +44-8451-302511 or www.tascam.co.uk.
Best of luck & I hope that helps.
Dec 26, 2009 | Tascam Dp-02cf Digital 8-track Recorder
Peavey PV14 to Tascam DP-02
The usual setup would be to use the main outs to your Tascam as the master faders control the levels there. The control room outs are more geared towards monitoring and are tied to the headphone outs level control.
Apr 20, 2009 | Tascam 2488 Portastudio Multitrack...
Poor Recording Level on the Tascam DP-02CF
When I record on DP-02/CF Tascam I can't get the music to play back. Do I have to do something other than rewind to be able to hear it? Albert S.
Feb 08, 2009 | Tascam 2488 Portastudio Multitrack...
Memory poor
This is an error in Tascam's code that usually means 'out of disk space'. Try using 'delete unused' to free up some space first within the song you're on and after that you might consider backing up some songs to your PC and then deleting them from the DP-01 to free up more disk space.
Hope this helps.
bd.
Dec 04, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam DP-01 FX/CD
Dec 04, 2007 | Tascam DP01 All-In-One Recording Package...
135 people viewed this question
 Grubhead
Grubhead
