Question about Indesit Washing Machines
H20 is showing on my display on my indesit
H20 is showing on my display on my indesit washing machine what does this mean?
  • Indesit Master
  • 3,463 Answers
H20 means not filling with water properly.
Check hoses and that taps are fully turned on , make sure water pressure is o/k, no kinks in hoses
Posted on Mar 13, 2010
I found a disconnected tube linked to the pressure switch beneath the top cover was the cause of the problem. In short, this tube forces air to the pressure switch and cuts off the valve feeds.
Posted on Feb 15, 2013
Refer here for indesit washing machine queries: https://www.indesitservice.co.uk/help-advice
For any course: https://www.fita.in/big-data-hadoop-training-in-chennai/
Posted on Dec 29, 2018
SOURCE:
Indesit washing machine when on quick wash does not complete cycle and shows message h2o answer please
Make sure your water taps are on full, the hoses aren't kinked or bent and if there are any small filter screens to the machine water inlets that they are not blocked with debris. The H20 error is indicating the machines' water level is being interfered with somehow.
Sep 07, 2018 | Indesit Washing Machines
Why is code h20 flashing during the washing cycle?
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Jul 12, 2015 | Indesit IWE91481 White 595 mm Washer Front...
Why is my indesit washing machine displaying H20 and not opening
• The water container must be emptied? The "Empty water container" indicator light flashes and the message appears "H2O" (see Maintenance).
Dado
Jun 29, 2015 | Indesit Washing Machines
Indesit washing machine showing H20
code showing h20 is the clue water is also known as h20,so your problem is the inlet valve letting the water into the back of your machine needs replaced or water pipe is kinked and no water is at the supply,. these valves are cheap at 10 dollars,adrian.....
Dec 20, 2014 | Indesit W 123 Front Load Washer
My indesit washing machine is flashing H20 i dont know what is wrong
Oct 09, 2014 | Washing Machines
H20 is showing on the display screen of my hotpoint washing machine. I'm aware this means water but I'm wondering why this is displayed?
Possible that there is no INLET pressure or water flow to the machine, check the inlet filter and valve, check for good flow to the valve if the hose is disconnected. If not it needs to be checked if the panel board is showing error due to memory fault..
Jan 23, 2013 | Washing Machines
Hotpoint wt740. When starting a wash cycle the machine tries to fill but shows the H20 code and the water goes straight out of the drain tube (it appears to have normal pressure and flow rate).
Indesit (Hotpoint, Ariston) Error code H20
(Quote)'If the machine is not in the demo mode and this error is displayed it means there is no water being supplied to the machine.
To cancel press and hold start/cancel then press again to cancel the drain and the machine should now be reset and display 'ON' as usual.'(unquote)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 04, 2011 | Washing Machines
Display periodically flashes H20
The faulot is related to the incoming water supply.
Chaek inlet hose for restriction or low water pressure.
Jan 19, 2010 | Washing Machines
Washing Machines Logo
5,514 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
