Question about Dryers
Dryer puts out very little heat. takes a long time to dry clothes
    President:
  • Dryers Master
  • 2,651 Answers
Check your venting!!!! possible kink in line where it leaves the home might be clogged.Most heating issues a direct effect of bad or inadequate venting
Posted on Mar 09, 2008
Wrinkles clothes terribly. Solutions.
Check your settings on your dryer. See if it's on a longer duration of time to dry. Dryers have different wording depending upon the make and model. If you're trying to dry smaller loads the heat settings s
does not have to be set for very long. Heavier, loads with thicker clothing will need to dry a little longer. When you take the clothes out of the washing machine, do you shake the clothes before putting them in the dryer? And do you use dryer sheets? Believe it or not, they're not only used to help make your clothe's smell fresh but they also help elevate static and a few wrinkles.
Mar 23, 2015 | Washing Machines
Why do clothes take a long time to dry even if dryer is heating?
One basic reason is your washer could NOT be spinning most of the water out, therefore your clothes are wetter than they should be, thus taking longer to dry:-)
Jan 22, 2015 | Whirlpool Dryers
Takes to long to dry clothes
after checking and replacing the vent going outside still the air was not venting and inside my drier everything was wet although the air was hot. After removing the rear panel i saw the blower belt disconnected. it took me some time to get the belt on but everything is ok and the air is venting and clothes getting dried. Also note that the little pulley came off its positio too.
Feb 14, 2013 | Whirlpool Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
There is a lack of heat. It gets a little warm
Please ensure that the venting from the dryer to the outside of the house is clean and free of lint.
Ensure the venting behind the dryer is not kinked.
Long time to dry issues are usually caused by restricted venting to the outside.
Since you have heat this may solve the problem.
Jan 13, 2010 | LG DLE2516 Electric Dryer
Dryer has some heat but is taking a long time to dry clothes
This type of problem can be caused by a partially burnt heating element, a blown thermal fuse, or a faulty high limit thermostat. All of these components can be checked using an ohm meter or multimeter. Sure hope this helped and best wishes.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Take too long time to get cloth dried
how much are you putting in ? Is it a 220 volt dryer? May have a dead line (electris) to heating coils, or thermaostat is not functioning and letting the dryer coils get to operating temperature. Your heat setting control may be faulty. I wouls look at heat control first.
Jul 02, 2009 | Frigidaire GLER341A Electric Dryer
LGE59777S Not drying
There is a little sensor that tells the dryer when to heat and when not to heat. that sensor is bad. If you take the back of the dryer off you will see it. It is about the size of a half dollar and has 2 wires that plug into it. While you have it apart make sure that the dryer vent on the back of the dryer is not plugged with lint. Major cause for fires in dryers.
Jan 04, 2009 | LG DLE5977 Electric Dryer
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
Taking to long to dry
This could be two problems. First problem, you must have good ventilation. Blow out the dryer vent with a leaf blower or some other type of fast moving air. Also be sure that the vent on the outside isnt blocked by little woodland creatures trying to find a nice warm home. Also be sure that the vent isnt kinked or blocked between the dryer and the wall. If that doesnt work, you may have only 1 of the 2 elements actually heating behing the drum. This would entitle removing the front and drum to check. Let me know if you need further help.
Dec 08, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Dryers Logo
104 people viewed this question
Top Dryers Experts
Marvin
Marvin
