Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Firmware update. how to find firmware update for my router linksys befsr41?thanks
  • Anonymous Mar 12, 2008
    my old router befsr41 is has a problem.so i got new one at same model,befsr41 again,..but when i used new router,..my favorite online game its not working..but in internet is fine working..i just very wondering about my new one.. so ill tried to firmware update for this....but i dont know how ang how to find a firmware update for this model.
Get the latest firmware Upgrade from Website
www.linksys.com/downloads
Posted on Mar 10, 2008
I bought a Linksys BEFSR41 Cable/DSL Router W/4 Port, it dosnt seem to work with windows 7 and i dont know why, need help...
pcnn
To get this right,you're also going to need your hardware version number.It's on the same sticker that all the info is.It'll be 1.0,2.0 or 2.1.
Go to the link below,it will take you to the support page for the router.It doesn't include Windows 7 drivers,but it should run on the Vista drivers.
Read the different links to info and see if it can answer your questions.Probably so.
You can also download firmware for the different hardware versions.If what's listed there is newer than yours,you absolutely want to install the firmware.
You also want to go to the Linksys router setup page and go through the wireless and network setup processes again.I have to do that periodically with my D-Link because the power fails here a lot and it resets to default.
Let me know what happens,and if you need,I'll keep trying.
For good or bad,please rate my post?
Thanks
Bob
http://homesupport.cisco.com/en-us/wireless/lbc/BEFVP41
The url for Linksys to set up your router is 192.168.1.1
Aug 11, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
The area connections with internet were lost
Try updating its firmware, if its not yet making any improvements, consider buying a new one.
May 08, 2009 | Linksys EtherFast BEFSR41 Broadband Router...
Opening Port 123 on my Linksys BEFSR41 Router
Hi:
It turns out I didn't need to open port 123 on my router to get SymmTime to work.
Thanks for the efforts
Brad McMillan
Dec 16, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys Rouer BFR stops functioning
There's a possibility that the router is already going bad but you can try first updating the firmware of the router because sometimes this problem is related to the software of the router so you may need to update its firmware,but if still after updating and still the same a new router will be the best solution for this problem of yours..You can also call this number for technical support help and double checking if the router is bad or still can be fix 1-877-787-8749...
Don't forget to rate the solution FIXYA thank you....
Oct 18, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Slow load speeds
Yes, when your router gets old it really get slow, you can try to load a updated firmware to this router and that should help for this concern, You can also contact Linksys tech support for further help this is the number 800-3267114.
Hope that helps........
Aug 23, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys router limits speed to 5 meg.
Try to access the router's setup page and change the MTU settings. The default address for the Befsr41 is 192.168.1.1. Here are instructions:
1) Use a computer wired to the router.
2) Launch a browser and type in 192.168.1.1, leave the username blank and the password is admin or the password you have set when you first configured the router.
3) Click on the Advanced tab then click on the Filters tab. On the bottom part you have MTU.
4) Enable that option and set MTU to 1500, 1400, 1300 (for cable ISP connection) and 1492 (for DSL connection) and check if it will work.
4) If that does not work, you can try upgrading the firmware of your router.
Apr 29, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Idle
befsr41 it seem to be a old router......and it have old firmware on it.....so upgrade latest firmware ....and i hope you will not any issue with the router.
Apr 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Need to be able to stream
This patrticular b router from linksys is a older version, it is not compatible for certain products, try upgrading the latest firmware for the router through, www.linksys.com/downloads, or else replace the router and check..
Jan 20, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
How to upgrade the firmware on a BEFSR41
Firmware upgrades may erase all previous settings to your router's configuration. Before upgrading your firmware, make sure to record your settings. 1. Unplug and disconnect all computers from the router except for one. This computer must be plugged into the router directly. There can be no other network activity on the router during the upgrade, so be sure to power off all other computers. 2. Go to http://www.linksys.com/download 3. Select the model number of the Linksys router you have (BEFSR41) as firmware upgrades vary by model and version. You can find your router version underneath your router after the model number. For example, ?BEFSR41 Ver. 3?. 4. Click the Downloads for this Product button. 5. Once you arrive on the download page, click the Firmware button. 6. After the firmware page opens, click the link that says ?Click here to download the latest firmware...? and download the firmware file to your computer. 7. Once you download the firmware Zip file, unzip it. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. 8. After unzipping the firmware files, one of them will be called TFTP.EXE. Double click on it. 9. When the ?Upgrade Firmware? window opens, you will have three prompts. The ?Server? field is for the IP address of your router; by default this would be 192.168.1.1. 10. Enter the routers password into the ?Password? field; by default the password is admin. 11. Browse for the file in the Firmware Upgrade utility program by clicking on the button next to file with the '?' symbol on it. Look for the file named 'code.bin' in the folder where the firmware files were extracted to. 12. Highlight the code.bin file and click on the Open button to direct the TFTP loader program to put that file into the "File" box. 13. The full path should be displayed [example: c:\linksys\code.bin]. 14. Click on the Upgrade button to begin the upgrade process. 15. The upgrade should take about 1 minute, and you will be prompted after the upgrade is complete and successful. If you are still having troubles, contact Linksys Technical Support.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
98 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
