GE WASHING MACHINE GWSR3090W
WATER OVERFLOWING DURING RINSE CYCLE
  • AUTOSMART Mar 11, 2008
    i too thought it was the pressure switch & replaced it. It still overflows, Can the new pressure switch be faulty too?
  • Anonymous Mar 12, 2008
    water overflows during rinse cycle. checked inlet valve by disconnecting the power, water stopped, replaced pressure switch, but still flows. Stopped machine and removed water manually (levelled it at the top of the box where the flexible hose (from the pressure switch) connects. Ran machine water does not overflow. Would someone tell me at what level should the water fill say during a medium load setting? I feel it has to do with too much water coming in.
    Sergeant:
  • 351 Answers
Check the inlet valve when it flood unplug power the water should stop if it doesnt its the valve.if it does it could be the pressure switch.hope this helps.
Posted on Mar 09, 2008
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
WDSR2120J washer will not fill in rinse cycle
possible 3 solutions for this problem 1 could be the cold fill solenoid 2 could be brushes in motor 3 could be main pcb
Feb 20, 2013 | Washing Machines
Maytag Atlantis washer drain hose is over flowing during rinse cycle
It probably has some coins stuck in the pump or a kink in the hose. If the washing machine won't drain, remove the access panel, and follow drain hose into machine and to the pump.You will need something to catch the water. Take pliers and sqeeze clamp and slide away from pump. Pull hose off and drain water. Remove coins from pump inlet and reassemble. If it is overflowing where it drains into the wall, you will need a pipe snake or a plummer.
Dec 29, 2012 | Maytag Washing Machines
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
Machine fills with water during rinse cycle, overflowing onto floor
sounds like the drain cycle is out of sink with the timer maybe you need a new drain pump
Feb 26, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a GE washing machine the model number is WHDSR209DZWW. It will not agitate during the wash cycle. It will also not stop filling with water during this time. The water leaks out of the bottom. The...
You need to check to see if the pressure tube and switch are ok this is how the machine detects it;s water level. Eg the tube may have just popped off or there could be a hole in the Pressure tube. Any questions feel free to ask Cheers
May 15, 2009 | GE WDSR2080D Top Load Washer
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
GE Top Load washing machine not draining
  • to me it sound as if waterpump is not working
Apr 09, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
162 people viewed this question
Top Washing Machines Experts
