On this 5 burner propane grill I can light up to two burners and they work fine. If I light a third, the flames drop 75%. Even if I turn off all but two burners the low gas flow rate continues. Any two will work fine and lighting any third will start the problem. FWIW the side burner and rotesserie burner work ok and have no impact on the problem.
Your problem lays in one of two area's.
Either your regulator needs adjusted or most likely it is your LP tank
Look in the tank fitting for a small brass ring It will have 2 small slots on either side. This ring can back off over time and then will not allow the male fitting to fully depress the valve in the tank thus reducing your gas flow. I have had this happen on several tanks a bit of caution and a small flat bladed screw driver has always fixed the issue
What do I do with the small brass ring?
