Question about Durabrand BH1304D 13" TV
HOW DO I SET UP THIS TV? - Durabrand BH1304D 13" TV
  • 4,102 Answers
Hi set it up for what give me more detail then i can assist you further
Posted on Mar 08, 2008
How do i connect my set top box to my digital tv
Ok, I am confused. How old is the TV? If new, hook the ariel directly into the tuner on the TV. The ATSM tuner in auto configure will identify and setup the channels with no need for a set top box. On old TV using an Analog Tuner will need a box. Antenna in goes to the antenna, antenna out goes to the F connector on the TV. Should be one coax connector on the TV. That is an F connector. Set the TV to channel 3 or 4 depending on what the switch is set on the back of the set top box.
Nov 16, 2013 | GPS
Tip
Dont Make This Mistake With Your Lcd Tv Set!
Ok lets just say you wake up one morning and the screen on your lcd tv set does not want to turn on, outside it is cold.The tv set turns on but the screen does not, turn off the tv set leave it like that for acouple of seconds turn it back on and your tv set should be up and working, if for some reason this is not the case try it one more time just to see what happens.After trying the above suggestion your tv set does not work than the problem is the backlight, Thank You.
on Dec 18, 2009 | Televison & Video
Tv went out itself red light ( power on off ) just blink, we can't turn on tv set neither fron remote or at the tv set
Jun 30, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I set up teac HDB840 to tv- via coxial cable from wall to set top box, then rca cables output of set top box , then to input to tv.-tried av button on tv showing av1 av2 and av3 but still no picture only...
Hi, Your set top box (PVR) is running on channel 3 or 4. Go to menu and sellect a source TV, DVD
Note: Do not connect more than 1 set of cables to tv or you may damage something.
TV > box connect RCA cable or HDMI not both.
Set top box > connect RCA or HDMI Not both.
audio devices > TV connect RCA or HDMI not both.
Good luck.
Jun 18, 2011 | Televison & Video
My ELCOT TV ask password, TV screen showing Limit Set, Limit Lock ON ask Password.
May 10, 2011 | Televison & Video
Need code for asda remote model#URC20-D1F for use with my sony tv
URC20 D1F
Set up by Automatic Search
1. Turn TV on
2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds.
3. The LED flashes and the remote control starts the automatic search.
4.The OFF signal is automatically sent to the tv from the remote control.
5. Once the TV switches off press any button except SET to stop auto search.
6. Switch your tv on using the POWER button.
Sony TV codes
010,011,028,030,031,077,107,128,131,166,203,237,302,309,367,444,445,446,449,160
To enter. Just hold SET and TV at the Same time.
The red led light stays on you are in set up mode.
Enter the first code on the list and try power button.
Keep following the steps untill you can turn the tv off.
Then its set.
Feb 08, 2010 | Televison & Video
Need key number for my baier tv set
I recommend using the auto-search function to find the correct code for your Baier TV set.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Nov 09, 2009 | One For All URC-3021 Remote Control
Urc-3021Boo one for all set up and codes for a sanyo tv
To control a Sanyo TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the code 0154.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, try the auto-search function.
Hope that helps.
Oct 17, 2009 | One For All URC-3021 Remote Control
Setting up receive set top box and tv for surround sound
Plug the TV to an open channel on your receiver via this output:
*Rear, 1 x Digital audio output (coaxial) ( TOSLINK )
This will look like a single RCA output plug.
Set that input channel on your receiver to some sort of virtual surround mode because it doesn't look like your HDTV has a decoder in it (meaning it will come out stereo and the receiver will have to fake it).
Turn the volume all the way down on the TV and use the receiver to control TV volume just as you do with DVDs.
*Substitute this with the digital audio output on your set top box if you are sending video only to the TV from the set top box (component, DVI or s-video connections). So video goes to the TV, audio to the receiver.
Feb 03, 2008 | Televison & Video
Silly remote
press and hold "set" then "TV" (or whatever device) then press "set" again. Point the remote at the device and press repeadly the power button until the device turns on. Press "TV" again to complete the programming procedure.
Done.!
Jan 14, 2008 | Televison & Video
Durabrand BH1304D 13" TV Logo
18 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
