Question about Kitchen Ranges
Touchpad MORE is broken. Gas range #mgr4452bdw ser#14421141jl(?)
  • ww1951 Mar 09, 2008
    I can't set the temp on the oven or set the time!
  • Anonymous Feb 15, 2009
    half of the tuchpad doesn't work
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Not a good model number to check up on, but genearlly if theres button on the touchpad not responding replacing the touchpad is only option. the touchpad is not a servicable item. needs repalcing
Posted on Mar 09, 2008
Code F1
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced GENE
Sep 10, 2011 | Maytag MGR4452BDW / MGR4452BDQ /...
Model# mgr4452bdw The surface burners light but the oven and broiler do not. when i set it for 350 degrees it stops at 100 degrees and no flames or heat. Do you know what the problem could be? Thanks...
You will need and ignitor to correct this problem, part number 12400035, or click on the link below.
Ignitor
When they become weak, the can extend cooking time and sometimes create a gas odor. One number problem is your unit is over 3 plus years and you do alot of baking. Normally is a 20 min replace job.
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 17, 2011 | Maytag MGR4452BDW / MGR4452BDQ /...
MODEL # MGR4452BDW SERIAL# 16419405NA The oven turns itself on and cannot be turned off with the digital controls. I have to unplug the oven from the wall outlet to turn it off.
their are two possibilities causing that,
1) bake or broil button on the touch pad has shorted out causing the touchpad to act as if it were being pushed to turn on.
2) a relay on the control board has shorted out and constanly sending power to the element
Gene
Aug 05, 2011 | Maytag MGR4452BDW / MGR4452BDQ /...
I have a maytag MGR4452bdw gas oven. it will not heat up above 350 degs, what's wrong? please advise
first thing to check is the ignitor,remove the racks and remove the bottom inside floor,if anything else is there remove it so you can see the ignitor,set the oven to 350,if the ignitor glows but doesn.t ignite the flame in 40 seconds change out the ignitor,the reason why i say this is if the sensor or anything else would bring up an error code.hope this helps.
May 16, 2011 | Maytag MGR4452BDW / MGR4452BDQ /...
MGR4452BDW Maytag Gas Range. The oven will not heat up. The burners work fine. You set the temperature and hear a click, but never get heat or smell gas.
Hi Maureen,
Strange.. I just had the same problem with my oven tonight. I have the same model as yours.
Can you tell me if you were able to solve your problem?
You can e-mail me at gml07@excite.com
Dec 13, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
The Maytag gas oven Model: MGR4452BDW and Serial:
Are you sure it's clean/ Does the smoke smell like wire burning or plastic? Is there a chance that there is some left over spill just burning off?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 22, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
I have a Maytag gas range model MGR4452BDW. The control panel has fallen in on itself. How can this be repaired. It is 1 yr old
I repaired it myself. I took it apart and re-enforced the plastic with a strip of metal (where the screws are). It works fine now. Nothing wrong with the circuit board just the poor design. You have to push on the control pad for the oven to function and when the plastic breaks the panel falls in on itself. Plastic with metal screws and NO support behind the panel. A new circuit board costs at least $150 + tax + service call + labor. It probably would be better to buy a new range and all because of the poor design!!!
Jun 05, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
Electriic oven control broken
maytag #mgr4452bdw the clock will not set the face reads 5-A-6 and the oven will not come on
Aug 27, 2008 | Maytag MGR4452BDW / MGR4452BDQ /...
Kitchen Ranges Logo
248 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
