Epson c1000 hi there i've got a epson c1000 aculaser and it keeps blowing the little fuses on the tonner drum/cartridges. 2 drums are new and 2 look about half full, PLEASE can you HELP me???? many thanks Rich
  • bigrichbig Mar 08, 2008
    no nothing? strange one its got me!!!!
    it has also been printing 7 to 10 sheets then red light come on and stops printing, all filters are clean and no jams?
    Rich.
    Genius:
  • 3,587 Answers
Hmmm..those fuses are there to protect inner mechanisms..sounds like your laser is running on overload. Is there anything jamming the paper path?
Posted on Mar 08, 2008
Printer Driver for Linux : Epson C1000
Hello
Try these links.
driverscollection.com/?...ACULASER%20C1000...Epso... - United States
support.epson.ru/upload/library.../howtoinstallprinterdriver_linux.pd
www.downloadsarea.com/Free_driver-epson-aculaser-c1000-linux/
http://www.dataentryjobs.us/67948.html
Feb 09, 2012 | Office Equipment & Supplies
Aculaser C1100 After replacing the black toner cartridge with an original new, high capacity one the prints come out with many, uneven vertical gray bands. Cleaning the print head did not...
A print cartridge (or a drum unit if it's separate from toner container) has a thing called wiper blade; it's essentially a rubber (sillicone) strip that wipes any "leftover" toner off the drum. When this strip is positioned wrong or faulty it gives symptoms similar to what you describe.
Sometimes it develops such behavior after long usage (especially if the cartridge was repeatedly refilled with toner), but in rare cases it may come like this new, due to manufacturing defect. I had this a couple of times in my career.
If you take out the cartridge and in subdued light (not to expose the drum to too much light) try to push the gear wheel so that the drum revolves (don't ever touch the shiny drum surface with fingers!) you can look at the drum; if you see toner streaks instead of a clean drum then you need to claim this cartridge as defective with the supplier. You should get a replacement without problems.
Please come back and leave a rating/testimonial if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 26, 2011 | Epson Aculaser C1100 Printer
The black toner needs replacing but I can't get to it. The Cyan toner is at the front and I can't move it round to get to the black! It's an Epson Aculaser C1100
there maybe a cartridge replacement button to drag the print head etc out of the way so you can get at the cartridges.
I hope this was helpful
Jan 11, 2011 | Epson Aculaser C1100 Printer
Pl advice our printer problem, we had refill tonner but print is coming light, and their is problem in chip
Depending on make and model ( which you did not mention)...some cartridges are one piece..meaning toner and drum are all in the one cartridge...so refilling the Toner only gets half the job done as the drum portion of the cartridge is still used. Even if it is a 2 piece system where the toner is one cartridge and the drum is another cartridge ...most new machines these days have the cartridges either "chiped" or "fused"...meaning that the machine will know if you did not put in a "NEW" cartridge and therefore may not work properly.
Nov 09, 2010 | Office Equipment & Supplies
How do you remove the other cartridges from the Epson Aculaser C1100? The Cyan cart is at the rear and easily accessable. I cannot see any levers, etc to access other cartridges and the download setup does...
On the left hand side is a lever. Pull down door 'A' and on the Left hand side you will see the arrow indicating the toner guide placement.
Directly to the left of this is a slot. Insert a biro (screwdriver or whatever fits) into it and push the lever UP to allow free rotation of the drum assembly.
Mar 10, 2010 | Epson Aculaser C1100 Printer
Konica Laser says no toners installed. How do you
Take the tonner catridge and shake it left to right and reinsert then it will be ok
Dec 20, 2009 | Epson Aculaser C1100 Printer
Changed the photoconductor unit on epson aculaser c1100
Hi, the E511 is caused by the printer not "sensing" rotation of the PCU drum & transfer belt (TRO Sensor error). It could be the PCU was faulty. First thing to try is to open the top cover and remove the PCU. Be careful not to expose the drum to bright light, avoid touching it if possible and be very careful not to scratch it. Using thumb pressure at the edges of the drum check it rotates. On the underside of the PCU is a little cut-out window, rotate the transfer belt until you see a little silver square appear. Give this a good clean with a soft cloth. Inside the printer you will see a little sensor sticking up (TRO Sensor) that aligns with this cut-out, give this a clean too. Hopefully your problem is now fixed.
Please take a moment to rate this solution, thanks.
Apr 02, 2009 | Epson Aculaser C1100 Printer
Epson aculaser c1100 cant access empty ink cartridge.
go to the reset menu (right arrow and then down arrow until reset menu is displayed) on the lcd display and then choose change toner #(right arrow until the desired toner is displayed) Hope this helps
Sep 27, 2007 | Epson Aculaser C1100 Printer
256 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
