Opening the case of SR1403WM Computer
How do I open the case. There is one big screw on the side in the back and 4 smaller screws. What do I need to do to open the case.
  • 27 Answers
How do i open the acer al5100
From Acer Support,
"Opening the computer:
Remove the screws on the chassis. Slide the panel off"
Yeah, okay Acer.
To convert this computer to a tower position. there is a Stand.
Does the computer just sit in this stand, or are there screws that hold it to the computer case? If present they would come up from the Bottom. Remove.
Looking at the back of the computer case, with the computer standing up; it appears there is a Triangle shape, coming off the LEFT Side Panel.
Appears to be about halfway up.
Looking at the Front of the computer, the Left side.
Looking at the computer from the Back, it's the right side.
Triangle shape coming from middle of left side, has the 'top
cut off. Remove/loosen the single Philips head screw.
Pull BACK of the Side Panel.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 20, 2013 | Acer mb.sa409.002 - Al5100 Vl410 Desktop...
Opening a Toshiba MK8010GAH drive case - what size Torx bit?
I've had luck using a T4 Torx precision driver. Sometimes I strip one of the 5 screws out in opening it but you are right that the T5 is too big. I just put a lot of pressure on the screw.
May 07, 2012 | Apple iPod nano 5th Generation
C'ant open the case of my pc
Look in the back of the PC. there are often several easily accessible screws on the outside edge of the steel backing. Remove all the ones close to the edge and attempt to slide the side of the computer back, depending on the method they used to build it you should just have to pull back and up when it comes loose.
Mar 07, 2011 | Computers & Internet
I want to change the hard drive in an Acer X1700. I don't know how to gett to the drive beyond opening the case.
To change the hard drive, you need to unplug the computer and all cables, unscrew screws in back of the case on the other side so you can open the side panel, with the side panel opened you can unscrew the hard drive, if it has screws on another side and you can't get to them then you need to open the other side of the computer aswell and unscrew them from there.
May 21, 2009 | Acer Computers & Internet
Cannot open my computer
1. First of all, you need to shut off your computer. To do this press the power button on the front of the computer after you have shut it down from Start> Shutdown on your start menu.
2. Unplug the power cord from your computer. This is the big black/white/grey plug that plugs into the power supply on the back of your PC.
3. Unplug the rest of the wires from the back of the computer.
4. Find a sturdy flat surface on which to work on.
5. Unscrew all screws from the back of your computer except the power supply screws. You will make a mess if you unscrew the power supply screws.
6. Open your computer up by taking the side panel off, or sliding the cover off. It might be difficult but it will come off if you have taken all the screws out.
Oct 14, 2008 | E-Machines eMachines Desktop PC
Ppc 6670
You just need the touch screen (digitizer). There are actually 2 pieces that are mistaken to be the screen. The other piece is the touch screen and beneath that is the LCD display. Be certain to order the correct piece.
To replace, you need a micro phillips head screw driver and a T-6 torx screw driver. Also patience, and a steady hand.
You must start at the back of the device, through the battery door. Remove the 2 micro phillips at the top of the battery opening (one is covered with a tamper evidence sticker). Then carefully, starting at the bottom of the camera plate, pry upwards and to the speaker to unsnap the smaller facing. Remove the camera by gentally pulling up to unplug, then unscrew the circuitry and remove. This will expose the 4 torxs (2 in batt opening) to remove the back cover. After screws are removed, gentally work the covers snaps loose around perimeter and remove (pay attention to the speaker wire) unplug it from the circuitboard. Pull the antenna nub to detach.
Remove the screws holding the circuitboard, unpluging the keyboard and slider ribbon cable. Gentally hold the ribbon cable and remove the securing tape. (dont pull too hard!) Pulling the circuitboard exposes the 4 micro phillips screws (2 each side) to detach the slider.
Remove the 4 torx screws on the back of the LCD slider, then gentally pry around to separate the housing.
To remove the LCD / Touch screen you must unplug the ribbon cables. To do this you need to open the connector's trap (black bar). It hinges. Just pry upwards from the ribbon side. Once bar is lifted ribbon will slide out. Be careful if you need to remove the gold foil tape. Remove the single screw holding the ear speaker, and the ribbon should come out. The screen will not come out after gentally prying it free of the holding snaps in the casing.
Installation is simply the reserve. Hope this helps....
Jul 03, 2008 | Audiovox PPC 6700
Opening case
It looks like the metal cabinet will slide back. Maybe sticking a flat screwdriver between the black cabinet and the back panel will loosen it.
Jan 11, 2008 | Aspire CASE | ATXA9NW-BL/500 500W R
Scratched audiovox screen
You just need the touch screen (digitizer). There are actually 2 pieces that are mistaken to be the screen. The other piece is the touch screen and beneath that is the LCD display. The outer scratched screen is the touch screen.
Ebay, and various online retailers have them for around $40. You can do it yourself if you try.
Dec 07, 2007 | Audiovox PPC 6700
Opening the case
I am repairing my E173FPc Dell Monitor and to take off the back cover you must look on edge of frame to the lcd and you will see little Pry Slots. Get a flat head or knife and stick it in there, then give it a twist and "snap!!"..continue along the frame at about 4 inches apart till the whole frame is off (but dont take the frame off just yet. lay the panel down on the LCD on a Towel or somthing soft, then unscrew the 4 phillips screws to the stand and remove. then pull the back off. Now on the sides of the tin you will see 4 more screws,...remove and lift but be carful you must unplug about 7 plugs before you can get to take out the circut board but that has screws also that need removing.(((seperate and label your screws)))) or (((take a few digital Photos as you go)))).. THATS IT.. I WILL POST PHOTOS SOON SOMEWHERE THAT GOOGLE WILL PICK UP LABLED DELL E173FPc LCD Monitor repair Blank screen blinking green light specific>
Sep 14, 2007 | Dell E173FP 17" LCD Monitor
Open Case
you need to apply some pressure on the sides while opening, because the whole device is 'clicked' together
Oct 05, 2006 | YAKUMO Computer Products Delta 300
Computers & Internet Logo
225 people viewed this question
Alun Cox
David Payne
David Payne
