Question about Paradigm PDR 10 Speaker
Power problem with Paradigm PDR 10 Subwoofer
If the subwoofer is not working, I have to plug and unplug it untill it comes on again. After a period of time, it kicks off again. I've tried pluggit into other outlets with the same results. Could there be a bad connection in the subwoofer?
  • 56 Answers
Yes it can be.You can check it with ohmmeter the impedance should be 4 or 8 ohms.But if you can disassembly the sub its better then you can see and check everything.My guess is that one of the cables on the speakers connector is broken and its just touching the conntact.
Posted on Mar 10, 2008
My Paradigm PDR-10 subwoofer needs a new fuse (1.5amp 250v) but I cant find the physical location of the fuse on the sub anywhere. Ive looked at it for a long time now. Any help? Thanks, Bryan Tal
Try right behind the power panel. Certain models you have to remove amplifier back panel. Then some are soldered on and some are encased in some kind of holder usually by the power input. Be carefull of electric shock. Make sure device is un-plugged while powered on to help with discharging internal capacitors if possible or drain caps with appropriate resistor to drain them safely if possible.
Nov 17, 2014 | Audio Players & Recorders
Subwoffer will not power up
PDR-8 Specifications
Design
Single driver, bass reflex system with critically tuned resistive port and built-in amplifier Amplifier High-current, discrete output, 90 watts RMS
Amplifier Features Soft clipping, thermal protection Frequency Response On-Axis 29Hz - 150Hz Low Frequency Driver 210mm (8 in) extended travel with 38mm (1-1/2 in) voice-coil, aluminum former Low Frequency Extension 29 Hz (DIN) Finishes Black Ash, Light Cherry, Dark Cherry Inputs From A/V receiver/processor or Paradigm X-Series Subwoofer Control Unit mono-sub out or preamp left/right output;From receiver/amplifier speaker terminals or main/satellite speaker terminals Weight 25 lbs. (11 kg) Dimensions HxWxD 13.25" × 9.75" × 15"
(34cm × 25cm × 38cm)
Specifications are subject to change without notice.
© 2016 Paradigm Electronics Inc. Conditions of Use Privacy Policy Unauthorized Dealers WARNINGSouth Africa
Dec 26, 2013 | Paradigm PDR 8 Subwoofer
Paradigm pdr80 no sound
If it is a powered sub, the sub power supply may have failed. There might be an open fuse.
Dec 25, 2013 | Paradigm PDR 12 Speaker
Getting nothing out of this speaker. Was clicking for a while. Power light is on.Can I open it up and just hook up the speaker by itself to check that part It is a pdr 8 subwoofer
That would be one way to isolate the problem to either the woofer or its amp.
But do you know that it's getting an audio signal from your ?? unnamed source? Its setup could be at fault.
Or you could jack a CD player or any other audio source directly into the sub amp and see if THAT works. Start with something low as you won't have control of the volume.
Dec 22, 2010 | Paradigm PDR 8 Subwoofer
I have a 110v power input Paradigm PDR10 and would like to convert it to 220/240. I'm sure it's a case of change the series connection to parallel on the transfomrer but I'm not sure the exact functions...
I have the same problem. An external transformer would step down the voltage, but it wouldn't help with the frequency, which would still be 50Hz. Paradigm says there's a risk of burnout if an unmodified PDR-10 is run at 50Hz rather than 60Hz
Oct 16, 2010 | Paradigm PDR 10 Speaker
PDR-10 subwoofer has no output. 120vac to unit is
I have exactly the same situation with my PDR-10. Paradigm techs were of no help, don't me to take it to a service centre which i did. Of course when it was there they plugged it in and it stayed on for a day and a half so no problem right? Get it home, nothing, plugged and replugged, got it on once but not for long. Opened up back, everything including fuse looks solid and fine....to naked eye anyhow.
Dec 20, 2009 | Paradigm PDR 10 Speaker
Hum coming out of Front left/right speakers but not center
There is a chance that your wiring is producing this problem. Manufacturers don't always make equipment that is compatible with each other. The biggest problem's are "ground loops". Radio Shack has a non-electrical device that separates the common ground from all equipment. You basically connect it between your amp out's and in's - cables included. It is possible that other manufactures also make and sell this device too. It's main "Google" name would most likely be - "Ground Loop Isolators". If you are using the actually speaker outputs into your subwoofer amp input(s), check your polarity wiring again. Good luck with your system - it sounds like it'll rock when it's all setup correctly.
Nov 06, 2008 | Paradigm PDR 12 Speaker
Alarm
Click on Paradigm (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. If available, that is.
And dont forget to rate me on this great site.
Jan 02, 2008 | Paradigm PDR 8 Subwoofer
Power Indicator Light on Front Doesn't Light
The indicator light needs to be replaced, there is a loose or poorly soldered connection on one of the led's leads, or the circuit providing the signal (voltage) for the light isn't functioning.
Sep 17, 2007 | Paradigm PDR 10 Speaker
1,139 people viewed this question
Top Paradigm Audio Players & Recorders Experts
 Grubhead
Grubhead
woodzowl307
Don Hart
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
