Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Philiphs 60" tv sound problem
I have a 60" Philips Tv that the picture is fine on but after on for a little bit the sound goes in and out... If any one can help please do.
  • 137 Answers
Replace sound Ic
Posted on Jun 29, 2008
I have a 50 inch Philiphs DLP,, th picture wasdark one day now theirs no picture nor sound...What could bewrong with it?
By the sounds the light source is gone and will need to be replaced. This is not something that is customer serviceable.
I recommend contacting Philips' customer service. They may likely have repair techs in your area. I'd expect the cost to be between $150 - $300. Their customer service number is below.
1-866-310-0787 Monday - Saturday 12.00 PM - 9.00 PM EST Excluding major Holidays
Feb 28, 2011 | Philips 50PL9126D/37B 50" DLP TV
Need to fix Philiphs model 60p8341 ptv915
unplug the tv and remove the back cover,locate fuses and see if there bad.if so and you replaced a bad fuse and the unit works consider yourself lucky and invest in a surge protector if you dont already have one.if no fuses are bad you have a bad board most likley the power supply board.theres a risk of live voltage so be careful.
Aug 27, 2007 | Televison & Video
Well hear goes, I have a Philips 60pp9363 60"
Coolant Fluid is a common Problem ,most of the time it will be the Green and Blue Coolant Fuild that becomes dirty and comtainated
With TV on. Look down into each Tube If it is not clear then change the coolant fuild .
Mats Electronics has Coolant Fuild 1-800-628-1118
Oct 29, 2010 | Philips 60PP9363 60" Rear Projection...
Why does my tv not come on but power light just
tv will not come on sound will for a little bit and then quit but the standby light blinks 10 times
Feb 03, 2010 | Philips Magnavox 9P6034C 60" Rear...
I have 60" projection tv sometimes the picture goes scrambled if you hit beside power switch it comes back on. Sound is there just no picture.
HI,
Common problem on this set.
SSB ( small signal board) Bad.
This part cost about $135-$245.
encompassparts.com
provide model number tv and they will help you.
Thank you
Sep 26, 2009 | Philips 60PP9352 60" Rear Projection...
Philips 60pp9202 - Sound and OSD, no Picture
I contacted my cable provider and he told me the tv defaulted to antena and reran auto set up I get picture but no sound cable man is coming to fix weak signal hope it fixes sound
I may need parts>>>haha
Sep 21, 2009 | Philips 60PP9202 60" Rear Projection...
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
Little dots all over the screen
Sounds like something might be heating up
you could get a can of freeze from radio shack and spay it on the ic's one at a time till the problem goes away to locate the bad part.
Oct 13, 2007 | Philips 60PP9202 60" Rear Projection...
Color fades in and out of picture
The first thing I would check is the antenna or cable connection into the set. When an analog TV signal is weak, the first thing to go is the color, then the picture, then the sound. If you have another TV, connect it to the very same cable or antenna connection and see if it fails the same way, too. Make sure you just disconnect the cable end right where it goes into the failing TV and connect it to the other TV - don't disconnect the antenna cable from the wall for this check. If the second set does not fail, gently pull on the antenna wire - not too hard, you just want to put a little tension on it to see if it makes the color cut out. Reconnect the first one and try again. If it's fine now, the connection was loose. If not, it has a tuner problem that must be repaired. Also, when you look at the end of a TV connector, the center wire should stick out just a little bit, like in the attached photo. If it doesn't stick out as bit, it won't make good contact, and will result in a weak signal. I appreciate your rating if you find this helpful.
Nov 13, 2006 | Philips 27PT643R 27" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
