No signal turn on comp but the monitor says no signal been useing this comp and monitor since 1996 and boom just like that is the monitor dead or is there something wrong with my comp
Dear sir my computer is working properly but moniter is on and it is off within 2 second.when its on/off button presses it is on but after 2 second it is offwith cherrrrrrrrrrrrrr sound.plz help me.
Posted on Apr 30, 2010
    Novelist:
  • 138 Answers
You can check if your monitor can be fixed or not. After you turned it on, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 09, 2008
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
Monitor gets no signal
yes. it is almost positively the video card.
you can get a PCI video card and install that in an open slot.
if you don't need to play games, you don't need a fancy one, just a basic card.
Jun 03, 2010 | Insignia D300a PC Desktop
My monitor will not boot up when my comp is turned on
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 11, 2010 | AOC LM 520A 15" LCD Monitor
My Compaq P110 monitor's VGA input does not working
posted 2 times, please erase one, thanks.
P110.
its a tuby 4:3 monitor, useless for wide video. plays.
1600 x 1200 at 85 Hz
do not exceed this, or boom. 1920x1080 will fail.
no resolution stated by you. and matters big time on all old monitors. (old = poor resolution only)
redux for less....words...
does it fail on all PCs connected, sure
does it fails set to lowest Resolution and 60hz?
RGB BNC only proves the analog side works.
not the digital side.
The VGA needs sync
if the PC is working (is it? on other monitors set to below reso.?)
then the 2 sync lines are active
at 1600 x 1200 , max (cant exeed this, ever)
then if that is true then the OSD buttons now work
do they? this is next.
does the On screen menu button work?
if not? it's a digital failure.....
or power to that section dead. or weak.
only googling finds schematics this old.
sorry.
nobody fixes these now, for good reasons.
labor costs on it would exceed a new LCD. fast.
we call this throwing good money after bad.
Sep 15, 2017 | Compaq P110 21" CRT Monitor
I'm trying to get my '96 MK VIII to pass smog but 3 monitors won't complete. The guy at the garage said some thing about doing a drive reset or something? Any suggestions?
Your car is equipped with sensors, that monitor
different functions of the drivetrain, usualy emissions
related. When one of these sensors detects a malfunction, it sends a signal to the cars computer
that in turn sends a signal to you via the check engine light. The computer stores these codes until
the problem is fixed. But the comp. retains the codes
until cleared. If you clear the code with an obdII scanner, the inspection computer will detect this and
reject it. To keep people from scaming the system.
A drive reset is to drive the car about 100 miles I
believe. To make sure the problem has been repaired
The computer will now reset itself.
I hope this helps. Good luck.
Feb 04, 2010 | 1996 Lincoln Mark VIII
Monitor directly enter into power afe mode wen we
turn off the cop and unplug all the cables and open the comp tower and remove all memory chip and turn on the comp by plugging just the power cable and leave the comp on for 2-3 min and the comp will beep and thn turn off the cop and pull the power out and put the memoy chips back in the comp and plug all the cables asnd then turn on the comp anf the issue resolved le me know if any problems at tauseef.razzaq@yahoo.com
Memory Installation Guidelines
Sep 18, 2009 | Computers & Internet
How to connect to external monitor?
You need to determine the fault first.
Can you determine exactly where the boom came from (the adapter or laptop)?
When you turn on your laptop does the LED lights indicating that there is power to the laptop and you can hear the hard drive spinning as well as the fan?
Do you know the power adapter is OK (you can test it with a multimeter)?
If the laptop is dead then the external monitor is of no use.
The laptop normally has a blue video output connector, usually on the back edge of the laptop where you can connect an external monitor or a data projector. When a monitor or projector is powered up first and then the laptop the display goes to the external video first. You can switch between the laptop screen and external video by clicking the blue Fn + F4 function keys.
Mar 01, 2009 | Compaq Computers & Internet
THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
Sep 30, 2008 | MTX Thunder 3401 Car Audio Amplifier
Computers & Internet Logo
443 people viewed this question
Alun Cox
David Payne
David Payne
