Question about Samsung CLP-600N Laser Printer
Printer won't stop jamming
Printer is folding and ripping paper leaving about 20% of the page (one corner) in the feed area and folding the remainder. Everything is cleared, but it won't stop jamming.
It jams with fresh paper, paper from the left had feeder, one sheet, multiple sheets in the tray or feeder.
We've only printed about 5-7000 sheets so far.
Have not tried powercycling the printer yet.
  • 1 more comment
  • jctank Mar 11, 2008
    My wife didn't tell me where the torn paper was hiding. Once I learned that I had to figure out what to remove to get to it.
    See the picture below.
  • Anonymous Mar 27, 2014
    doesn't print but blank paper has fold in center with paper jam area 1 error
    paper folded in center blank without print job completed
This is a "feature" according to Samsung, typically happens when you dont have the same size of paper in the tray that your sowftware tells it to print on i.e. your print page screen says print on letter but you have 11x14 in the tray. I spent an hour on the phone with them about this - their answer was to check the paper is correct before printing. Personally it's a design flaw that stops the print job in it's tracks when it doesn't detect the end of the page where it would expect it rather than continuing the page through the printer. The fallout from this is you have to open the side and remove the paper which is nosmall feat given the tension on the rollers, I fear one time I pull too hard I'm going to damage another component as it releases :-( KW
Posted on Apr 11, 2008
    Genius:
  • 3,587 Answers
Sounds like your printer wants to form it's own three piece band(kidding here).
sounds like you rollers are dirty or have something on one or both of them..like tires on a slippery road, these need to be clean and dry.
Posted on Mar 08, 2008
  • Patrick Michaels
    Patrick Michaels Mar 11, 2008
    well..if it's not going print, maybe you can take it to the local club, since it likes jamming so much, eh?
  • cpayne234721 Dec 21, 2010
    how do i clean the rollers?
Tip
Steps to clear paper jam.
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
on Jun 03, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Why does my Konica Minolta 1690MF have a fuser jam error whenever I print in color?
Everything you checked sound good. Might be printer software problem, and needs to be re-flashed. Software only available from secure web site that a technician would have, see what it cost if to much buy a new one with extra bells and whistles !
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 18, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Paper won't feed through to the printing area
If when you mash print and the paper doesn't move through to be printed on it may be because you don;t have the paper inserted properly or maybe someone jammed your printer and tried to unjam it the wrong way and didn't tell you....hope it helps
Nov 16, 2011 | Office Equipment & Supplies
Left corner is folded down on page
Sounds like an issue with the feed rollers. The roller on the left side might be hung up and is causing the corner to fold over when the paper is pulled through. I would try checking the feed rollers in either the actual tray or the back of the printer. Another thing to check is the other tray (the manual one). Does the paper fold? this should help you narrow down where the problem lies.
Mar 02, 2011 | HP LaserJet 4350 Printer
When I try to print anything the paper in my Brother HL-2040 gets stuck and doesn't properly feed through the printer. The paper light flashes and I have to open the paper tray, pull the paper down, and...
Sounds like there is a piece of paper stuck somewhere. In the back of the printer is a rear door, fold that down and check everywhere. Get a vacuum and first vacuum, then blow everything. Sometime dust can get in the way if it builds up. Make sure your paper is dry (hasn't gotten wet with humidity), and lays flat. Maybe try feeding some heavy weight paper with the manual feed in from to help push any jams out of the way. I've done all of the above at one time or another to help clear out my printer.....hope this helps
Jan 14, 2010 | Brother HL-2040 Laser Printer
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
The paper does not feed properly.
Replace the paper feeder or the rollers on the paper feeder are not rolling ar getting jamed. You need to have this serviced or just get yourself another printer. Lexmark are what I call in my expert advice throw aways the better ones are epson,xerox,HP and so forth. Please leave positive rating and feedback thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 09, 2009 | Lexmark X3480 All-In-One Printer
Hp laserjet 1320 folds corner of paper after it prints.
Open the back of the printer - make sure it is clear. Then remove the toner check throughout the printer - reseat the toner and try to print
Jun 18, 2009 | HP LaserJet 1320 Printer
Samsung CLP-600N Laser Printer Logo
697 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
