Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Convergence prblm My red conevgence just went out one day last month. I tryed to adjust it with the remote but it would not adjust at all. I have read the posts and tryed to fix my problem by replacing the two IC "STK392-040" But this did not fix the problem. I was wondering if you think it may be the conergance module assymbly?
  • timmy47 Mar 09, 2008
    watching and just went out. have had about 4 years and ***** had any trouble. have ** sound or picture. red timer light on front of tv respondes to remote, but red light is all I get.
  • 2,336 Answers
If you have replaced the "STK392-040", I would suggest to go back and use a magnifier tool 2X to 4X to inspect the solder joints. Also use a multimeter check for good electrical connections from the pads to IC leads.
Check the fuses for open conditions as well the low value resistors nearby the IC's or you might also need to solder touch-up some joints that do not look very shiny.
Good Luck.
Posted on Mar 08, 2008
I have a Sony KP-65WS500 from 10/2002. There are thin red arcing lines across the screen when the scene is dark or black.
This tv have a problems known as a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 16, 2010 | Sony KP-65WS500 65" Rear Projection...
Suddenly the blue and red went way out of convergence and the picture is bowed, like upwards.. when i try to adjust convergence with setting and remote nothing moves
The Phillips DPTV305-DPTV345 convergence repair kit should fix the issue. The kit is avialable at www.tvrepairworld.com and contains the parts and the CD with instructions
Oct 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture looked 3d now tv wont come on. red lite flashes 6 times.
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts down
  • TV Chirps
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 03, 2009 | Sony KP-51WS510 51" Rear Projection...
Convergence problem wiht jvc av 48wp30
Bad chips...There are a ton of cheap fakes out there....Or bad resistor...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 29, 2008 | JVC AV-48WP30 48" Rear Projection...
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Red convergence way off
I had the same issue as you pretty much exactly and so do others right around this last few weeks so I am thinking that this is a common problem with the product itself.
You can fix this pretty quickly with the link below. I bought it and it resolved the issue.
http://www.partstore.com/Part/Samsung/Samsung/PCN5425R/Samsung/Samsung/BP9500142E/New.aspx
Jan 02, 2008 | Samsung PCN5425R 54" Rear Projection...
Samsung HDTV
If you changed the ICs you need to adjust convergence, read carefully the instruction and alingn the lines using remote control commands. Is a long process. My tv loss convergence three times , i will never buy another samsung product. I told every body that i know that never buy another samsung product.
Oct 26, 2007 | Samsung HC-P4752W 47" Rear Projection...
Convergence Problems
If you did not use heat sink compound then you probably have not hurt the new IC's yet but you should remove them and add the heat sink compound NOW. If the convergence IC's are bad then you will have access to the convergence menu but the adjustments will have no effect. The fact that you switched the IC's and got the same results shows that the IC's are good. If your red convergence is still way out when the new IC's are installed then the old IC probably burned out the low value resistor associated with the Red Vertical (RV) channel.
Jul 02, 2007 | JVC AV-48WP30 48" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
29 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
