USB Floppy disk drive
Hello, I need to install a mass storage driver on my Intel Motherboard. Windows XP is asking for the floppy disk that came with my motherboard. The motherboard does not have a FDD port. It requires the use of a USB floppy drive. According to Microsoft, there are only 3 drives that, it claims, XP will recognize. Something about the "Txtsetup.sif file". I've searched around the web and I cannot find any of those drives. Can you, please help me
Thanks, Dave
  • 2 more comments
  • Comprookie Mar 09, 2008
    Hello, I am using a home built computer. I am using 2 SATA Hard drives. The motherboard only has 1 IDE port. I have a Sony DVD R+W drive plugged into it.
    I am trying to set up a RAID Array. That's why I'm using the 2 SATA Drives. The motherboard is RAID ready, but XP needs the mass storage drivers. Is that what you're asking?
    I guess I should have said, I need to install the RAID Drivers. Sorry 'bout that!
  • Comprookie Mar 10, 2008
    The Product Guide, that came with my motherboard, **ted that I would have to use a USB diskette drive, in order to install the RAID driver. As I previously stated, there is ** FDD port on the board. They provided a link to Microsoft. It stated there were only 3 compatible USB floppy drives. I don't understand why ! The Product Guide did, however, state that RAID configuration could be set up after XP was already installed on just one of the SATA drives. If XP was already installed, it makes me wonder if, possibly, "any" USB Floppy Drive would work.
    Genius:
  • 3,587 Answers
Yes..this one is a little complicated...who's computer are you using? Home built or off the shelf?
Posted on Mar 08, 2008
  • 2 more comments
  • Patrick Michaels
    Patrick Michaels Mar 08, 2008
    this might be able to be done from bios, but that board most likely only supports a certain number of drives, and of course, they will need to be compatible(IDE, EIDE) etc...what type of drive you have currently?
  • Patrick Michaels
    Patrick Michaels Mar 09, 2008
    ok..and the mass storage device..is it PCI or USB compatible?
  • Patrick Michaels
    ahh..got it..wondered about that. There is a whole differenty set of Bios drivers needed for that. Did someone you know suggest you could do this?
  • Patrick Michaels
    Patrick Michaels Mar 10, 2008
    the major issues here are the on board chipsets, the memory and uP capacities to handle that much data. This is the essence of the PC world, the configuration options. I wish you good luck on this project.
    thanks for using fixya
Keep getting 0x0000007b (0xf78d2524, 0xc0000034, 0x00000000,
So, where did you get the Windows XP drivers for the controller? Are you sure that they are XP compatible?
Is the USB floppy even being recognized and read by the setup program?
The Windows Setup program only supports a handful of USB drives for F6 driver installation method, that is explained here:
A connected USB floppy disk drive does not work when you press F6 to install mass storage drivers during the Windows XP installation process
Adding the standard Microsoft USB storage drivers to the txtsetup.oem file on the floppy diskette usually resolves this problem, see here: http://www.intel.com/support/motherboards/server/sb/CS-026606.htm
Adding the USB floppy's vendor ID should also fix the problem, see here for an example:
http://blog.mreza.info/archive/2007/09/19/windows-f6-driver-and-usb-floppy.aspx
None of my business but why not use Windows 7 on the new laptop, instead of going through all this trouble installing an operating system that is 10 years old and that is living on borrowed time?
Jan 19, 2013 | Dell OptiPlex 330 Desktop Desktop Computer...
Bought new hard drive for mini 1012 dell bios sees new hard drive but when i try to install windows xp , xp says no mass storage device detected.
In the bios change the drive options to anything but AHCI if possible. You will need a windows xp driver and USB floppy disk to install the AHCI or SSD driver. It's also referred to as an F6 Floppy. Dell should have the download you need.
Jul 18, 2011 | Dell Inspiron Mini 1012 Netbook...
Dfi-64 tc problems. i just to install xp (before was windows millenium )now each time when xp load appears a message saying that bus ide drivers does not installed but when i run the drivers disc...
when a person goes install windows xp they encounter the problem of not being able to find any hard disk drives installed as if they weren't connected. The hard drive is detected with no problem in the BIOS and also on start up POST, able to boot up Linux Live CDs but the hard drive is just not being detected in Windows setup. Here is the exact error message.
Setup did not find any hard disk drives installed in your computer.
Make sure any hard disk drives are powered on and properly connected to your computer, and that any disk-related hardware configuration is correct. This may involve running a manufacturer-supplied diagnostic or setup program.
Setup cannot continue. To quit Setup, press F3.This problem is quite a common one and is simply due to the fact that when Windows XP was created, the SATA chipset itself and SATA hard drives weren't available to the masses, so support for it wasn't included in the XP setup process. As most computers within the last decade or so have some form of SATA controller, if you try to install Windows onto a SATA drive, XP won't recognize it because the drivers aren't present on the installation disc, so they need to be loaded manually for the drive to be picked up.
Thankfully there are a few ways to get around this problem and enable Windows XP to be installed onto a SATA hard drive so you can enjoy the extra performance and other functions like hotplug/AHCI etc. Setting the BIOS Correctly
The first and mos obvious method is to change the SATA Mode to IDE in the system BIOS. Most BIOS's for several years have included a fallback mode to enable a SATA drive to behave like an IDE drive, and therefore makes it visible to XP during setup. The problem with this setting is it comes under several different names and can be found in different sections within the BIOS. It depends entirely on the computer or motherboard's make, model and manufacturer to know which setting you have and where it is. If you have a manual, it's certainly worth reading.
The most obvious thing to look for is a setting which can change the SATA controller to IDE or PATA mode, with options such as AHCI -> IDE or SATA/RAID -> IDE etc. Basically any option you come across to reduce the SATA/RAID mode to IDE/PATA should be the correct one. Don't confuse this option with a similar one which will disable the SATA controller completely. Here's some names we found it could be under in a few motherboard manuals we looked at:
Integrated Peripherals > SATA Devices Configuration > SATA Mode > [IDE]
Integrated Peripherals > Serial ATA Function > Base
Storage Configuration > SATA Mode Selection > Emulated PATA Mode
SATA Configuration > SATA Configuration [Enhanced] > Configure SATA as > IDE
Integrated Peripherals > South OnChip PCI Device > SATA Controller > IDE Mode
Using a Floppy Disk
If you're unable to change RAID mode to IDE or disable SATA in the BIOS, then the next option would be to download SATA/RAID drivers from your motherboard manufacturer's website, extract the drivers to a floppy disk and then insert the floppy into your computer during Windows XP installation. This method obviously gets around the problem of XP not having the drivers on the install CD by you providing them manually.
Windows XP setup won't recognize USB flash drives, so you need to have an internal floppy drive available, many USB floppy drives will also work though. As you can see in the image below, it clearly states that the SATA RAID driver is for use on floppy drives. You need to make sure any drivers you download are explicitly designed for putting onto a floppy and not a generic driver, usually the file will be around 1MB or lower which is a good sign it's likely to be the correct driver.
Insert the Windows XP CD and boot it up. You should see a message that says "Press any key to boot from CD..." Simply hit any key and it'll start to boot from CD. Pay attention to the next blue colored windows setup screen. When you see a message that says "Press F6 if you need to install a third party SCSI or RAID driver..." at the bottom, immediately hit the F6 key.
After loading some files, you will come to a screen that says the following:
Setup could not determine the type of one or more mass storage devices installed in your system, or you have chosen to manually specify an adapter. Currently, Setup will load support for the following mass storage devices(s):
< none >
* To specify additional SCSI adapters, CD-ROM drives, or special disk controllers for use with Windows, including those for which you have a device support disk from a mass storage device manufacturer, press S.
* If you do not have any device support disks from a mass storage device manufacturer, or do not want to specify additional mass storage devices for use with Windows, press ENTER.Make sure the driver floppy is inserted and press S. It will present a list of drivers which it read from the disk earlier. Select the appropriate driver and continue the Windows XP installation. The setup will continue and this time it will recognize the SATA hard disk drive in your PC. This problem is quite common when trying to install Windows XP on newer computers because most if not all are using SATA hard drives. After installing Windows XP, you can easily and automatically install all required device drivers using the DriverPack Solution disc.
If you thought it wasn't possible to use a USB flash drive instead of a floppy drive to load the drivers during the F6 phase, we have a solution that could !!!
Oct 04, 2017 | DFI CA64-TC Via 694T/686B Mainboard...
How to create floppy with SATA drivers (NO mobo CD)
Don't need to use a floppy - copy the files to a USB Flash drive, and when the Windows asks for the source, select the drive.
Apr 22, 2010 | Intel Motherboard
I can not install windows XP on Toshiba Satellite U300, windows
You must have latest Windows Xp CD .
Latest Motherboard chipset does not recognise hard disk without proper sata raid or sata driver. So you can install sata driver if u have USB floppy drive by downloading latest Sata raid to floppy. At the time of installation you will see a message press f6 to if u need to install raid driver.then press f6 asking for floppy drive and floppy insert press enter to continue.
Jun 27, 2009 | Microsoft Windows XP Professional With...
USB driver 2
Can you be more precise? You don't need USB driver for this PC...
Jun 25, 2009 | Gigabyte Computers & Internet
Not able to install windows XP on sata hard disk having Intel d101 mother board. please help but not using F6 option as I don't ahve floppy disk drive on my system
You need to sliptream SATA drivers into your setup disk.
Download from here
http://driverpacks.net/DriverPacks/
driverpacks mass storage
copy windows CD to hard drive then use "Nlite" to insert them into the drivers section
then burn to a new CD.
and reboot from it should have no problem then
Dec 10, 2008 | Intel D101GGC Motherboard
Motherboard drivers
I contacted HP the other day for a problem while trying to load XP on a VISTA box. They sent me to this site.. and gave me instructions for resoluation or at least an attempt.. Hope this helps
Thanks David
Let me know it if works for your problem
Solution: The reason for this error message is that notebook has been shipped with SATA hard drive i.e SATA hard drive controllers. But Windows XP does not have built in SATA controller drivers.
To solve this problem we need to install SATA Controller drivers before we install Windows XP using a USB floppy drive.
Many customers are not ready to buy USB floppy drive and installation of XP is so complicated using USB Floppy drive.
We have found the driver for the SATA controller on Intel Website. Customer has used it and installed retail Microsoft Windows XP with SP2 successfully on his dv6500 notebook.
The same can be achieved in all the dv2500, dv6500 and dv9500 also DV2600, DV6600 and dv9600 notebooks.
Here is the link for the SATA drivers:
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&lc=en&softwareitem=ob-39535-1&jumpid=reg_R1002_USEN
1. The file contains the Intel Matrix Storage Manager Floppy Configuration Utility.
2. This utility will create a floppy disk containing the RAID driver files for installation on a 32-bit operating system.
3. This floppy can be used to pre-install the Intel Matrix Storage Manager driver during the F6 portion of Windows setup.
4. You needs Microsoft Windows XP with SP2 Operating System disc and the USB Floppy drive.
5. After downloading the SATA driver in another notebook, you needs to extract and execute the file. It will help in creating the floppy disk that has the SATA drivers.
6. Boot with the Microsoft Windows XP disc and make sure the USB floppy drive with floppy disc is connected to the notebook.
7. At the F6 prompt, select F6 to install additional drivers which are not in-built in the retail Microsoft Windows XP Operating System disc.
8. When the prompt comes up to install additional drivers, insert the floppy and select the correct SATA Driver. It is Intel 82801HEM/HBM SATA AHCI Controller.
9. Once that is done, the rest of the installation runs as normal. There are only 2 drivers in the floppy disc that would work.
10. After the Operating System is installed in this manner you can install the chipset drivers for the notebook.
11. However for the other device drivers once Microsoft Windows XP is installed you may not have them from HP as these series are not released with a Microsoft Windows XP Operating System. The drivers like audio, ethernet and media card reader drivers etc.
12. Please be sure with EU that he might not have the other drivers from HP after installing the retail Microsoft Windows XP.
Note: Do not click on the link. Copy and the paste the link into the address bar of the web browser.
If the above solution does not resolve the issue, please login to chat support with the results of the above troubleshooting steps. Also, please use the same email ID.
Dec 07, 2008 | Compaq Presario Notebook
Have a HP DV9500 laptop and I am trying to remove Windows Vista and install windows xp. When I get to the blue screen to start the install it says it can not locate my hard drive and the only option...
Hi.
I will explain you the issue.
The notebook is preinstalled with a SATA hard drive which needs seperate drivers to be installed inorder to get the hard drive detected. The drivers for the SATA can be installed only by using a floppy drive. As the notebook does not have a floppy drive installed, we can either try disabling the SATA native support in BIOS or install the drivers with the help of a USB floppy drive.
If the USB floppy drive is not available, you have the alternative steps to install the SATA driver.
Please refer the following link to install SATA driver without the USB floppy drive:
http://www.scribd.com/doc/4864999/sata
or
http://cid-3a2fd42defd10b67.skydrive.live.com/self.aspx/Public/sata.pdf
If you have the Floppy drive you can install the SATA driver.
Just follow the below procedure:
Download the SATA driver:
ftp://ftp.hp.com/pub/softpaq/sp37001-37500/sp37005.exe
1. Download the driver to a directory on your hard drive.
2. Execute the downloaded file and follow the on-screen instructions. A diskette containing the driver is created, and the driver files are also made available at c:\swsetup\sp37005. If you choose to cancel diskette creation, you will need to copy the driver files to the chosen media.
Installation Instructions:
NOTE: A USB diskette (floppy) drive is required to use this driver. If an external USB diskette drive is used, ensure that it is plugged into the system before starting Step 1.
1. Insert the operating system CD, and Power On the notebook to boot
from the CD.
2. At the very beginning of the operating system installation, the following prompt is displayed at the bottom of the screen:
"Press F6 if you need to install a SCSI or RAID driver...."
When the prompt is displayed, press F6.
3. Later in the operating system installation, you are notified that a mass storage device could not be detected. When this notification occurs, press S (S=Specify Additional Device).
4. When prompted, insert the diskette that was created from the SoftPaq file, and then press Enter.
5. Select "Intel 82801HEM/HBM SATA AHCI Controller (Mobile ICH8M-E/M)" and press Enter.
NOTE: At this point, the following prompt MAY be displayed, depending on the version of your operating system CD. If the prompt is displayed, press Enter to use the default Windows driver and continue, if it is not displayed, continue with Step 6. The prompt reads as follows:
Windows already has a driver that you can use for
"Intel 82801HEM/HBM SATA AHCI Controller (Mobile ICH8M-E/M)".
Unless the device manufacturer prefers that you use the driver on the floppy disk, you should use the driver in Windows.
S=use the driver on floppy ENTER=use the default Windows driver
6. Continue with the operating system installation, as prompted.
NOTE: If a problem is encountered when using the external USB floppy drive, refer to Microsoft Knowledge Base Article 916196: "A connected USB floppy disk drive does not work when you press F6 to install mass storage drivers during the Windows XP installation process."
Sep 09, 2008 | Computers & Internet
USB external floppy drive
In windows XP and later the USB mass communication driver are in built, so you can use these devices like USB Floppy drive, USB HDD, Memory card, flash memory etc...
But before windows XP Microsoft did not supply the driver for USB mass storage devices. So, in your case you have to install the Driver for your USB Floppy drive, then you can use this drive as Floppy drive but after complete boot of your Windows 95.
If any problem or more question Just Ask me
Thanks
Iqbal
Apr 07, 2008 | HP Compaq Business Notebook NX9010
Computers & Internet Logo
156 people viewed this question
Alun Cox
David Payne
David Payne
