Question about Refrigerators
Wiring diagram I need the wiring diagram of the ice maker + water valve + optics circuit for a Kenmore Coldspot model 106.56542400 side by side fridge. Can anybody share it or tell me where to get it? thanks
  • vvvzzz Mar 09, 2008
    The serial number of the fridge is SS2030477.
    thanks
    Genius:
  • 3,587 Answers
Sure..hang on..can you tell me the actual part number or serial number on that unit?
Posted on Mar 08, 2008
  • Patrick Michaels
    Patrick Michaels Mar 09, 2008
    ok..this will take some time...those are hard to get..this under warranty by chance?
  • nikuze olive Mar 11, 2016
    Patrick tell me where to buy an ispracontrol of AEG side by side fridge please.
Kenmore Coldspot 106.53592300 ice maker valve does not seem to be working. I have replaced the valves but there does not seem to be power to the ice maker water valve
Go to page 18 on the PDF at the link here=> http://appliance911seabreeze.com/whirlpool_icemaker_troubleshooting.pdf
and use a jumper wire to cause the water valve (Water Valve - L to V) to come on if the water valve is good. Here is an Ice Maker for your model=> HERE and a water control valve for your model HERE
APPLIANCE911
Aug 20, 2016 | Kenmore Refrigerators
Kenmore coldspot ice maker not working
check to make sure the water hasn't frozen in the tube that it should fill the tray with. Please let me know if this isn't the problem and I can further assist you. If frozen, you should thaw out the freezer to get it working again.
Good luck
Apr 11, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore Coldspot model#106.53359300 the ice maker not making/dispencing any ice, help?
Make sure the metal lever on the ice maker is in the lower on position. Check that the water valve for the 1/4 inch supply line is attached to the fridge and to the valve . Screw that water valve all the way in and then all the way out.
Jun 06, 2016 | Kenmore Refrigerators
No ice is being made.
Most likely either water valve is bad or ice maker is bad. You would need to determine if Ice Maker is sending voltage to water valve. If it is, replace valve. If it's not, replace ice maker. Also be sure filler tube going through back wall is not frozen. If it is, replace water valve.
Sep 02, 2017 | Kenmore 22.0 cu. ft. Side-By-Side...
Getting water
I have Kenmore Coldspot refreidgerator and am having a problem with water pooling inside the fridge at the bottom underneath the drawers (mostly the left side). Where is the water coming from and it formed a thin ice.
Thanks
Nov 25, 2009 | Kenmore Refrigerators
Ice maker will not produce Ice
Make suer the freezer temp is 5 degrees or lower. If not the ice maker will not operate. Also make sure that you have water pressure at the back of the fridge. If so, you most likely have a bad water valve. It is what your water supply connects to. You can test it like this. Disconect the water line on the fridge side of the valve. Unplug the wires from the valve. Supply 110v to the plug. If water comes out from where you disconected the line, the valv is good. If not, you will need to replace it. If you can't find the answer with this. Reply back and I'll talk you through until we find it.
Please rate this solution if helpful.
Aug 21, 2009 | Kenmore Refrigerators
What size is this fridge?
there is a sticker some where inside that will tell you cubic feet
Dec 12, 2008 | Kenmore 53542 / 53544 Side by Side...
Ice maker won't make ice
The ice maker tells the water valve when to send the water on up. Replace the ice maker! goodluck!!!
Dec 16, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
501 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
