Question about Shop Vac 285-00-10 Back Pack Vac Wearable Wet/Dry Vacuum
Shop Vac just stopped
I have a 90L Quiet Series Shop Vac. I was using it and it just quit. No noise, no smoke, no smell. And now it won't turn on. Do they have a reset button of any kind?
  • Throckmorten Feb 18, 2009
    my 5.0 Hp 12 gallon industrial shop vac just stopped, and I am guessing the brushes need replacing on the motor. But I can't seem to find anywhere that sells replacement parts.
    It seems that they treat it as one unit, which isn't very environmentally friendly.
If you remove the motor, you will see that the wires that go from the switch to the brushes. On one side there is one wire connected directly to the brush. On the other side the wire goes to a plastic plug with a second wire going to the brush. This is probably where the problem is. This is a fusible link and it has most likely melted creating an open in the circuit. I put a piece of solder where the link was and the motor ran BUT the brushed arced like a sparkler. Upon further examination the brushes were crumbling apart. I have been unable to find replacement brushes.
This machine has a five year warranty. I called Shop Vac Customer Service 1-888-822-4644 and they sent me a new motor.
I had a Shop Vac QL50EIC which had exactly the same problem but the warranty was expired so that I had to buy another motor for about $50.
Posted on Oct 18, 2008
I called Shop Vac Customer Service 1-888-822-4644 and they sent me a new motor, my unit was 2 years old and has a 3 year residential use warranty. Great customer service!
Posted on Sep 10, 2010
    President:
  • 1,673 Answers
Some do, but it would be in the open by the cord. But you could have a bad cord, switch, or a problem with the motor.
Posted on Mar 13, 2008
Can i use a shop vac quiet series 2.0 model 86m200 w out a filter of any type to get up water and some funky stuff
You can do that but you absolutely shouldn't. The filter is what prevent particles from entering the motor and what creates a break for incoming water. That way a solid stream of vacuumed water doesn't go directly up the motor.
Dec 25, 2017 | Shop Vac Vacuums
How do you replace the switch on a shop vac 2.0 quiet series
The switch should be connected to the power cord just use a multimeter to work out where the wires go , do you have a pic of the switch ?
Jun 25, 2014 | Shop-Vac Products 5-gallon 2 0-peak Hp Wet...
Vacuum motor noise and smell
If the ball was stuck and you sucked water into the motor it could cause it to smell like it's burning if it ruined the motor
Jan 10, 2014 | Shop Vac Vacuums
The paper filter on the Shop Vac locking ring won't stay on, how do I fix this?
It has to be pushed all the way on to where the plastic is solid. It's usually quite hard.
Apr 13, 2013 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
My series 90L suddenly stopped and would not restart. A check of the circuit breaker found it tripped. The vac would not turn on when the circuit breaker reset. Using an AC voltage sensor indicated power...
From the description it sounds as if there had to be a short in the unit somewhere. This is what would have tripped the breaker. the fact that it is not tripping could mean that there is a fusible link or that the wires or whatever have burned back from the short, and are no longer shorting out.
Jul 04, 2011 | Vacuums
My new shop vac is smoking and smells like electrical fire. Any suggestions? Should I just take it back to the store?
Hi. ABSOLUTELY return it. It has an internal electrical issue which may cause a fire. Return it ASAP!! J.
Aug 09, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Motor stopped running...i have veard this could be
I have the same shop vac with the same problem. I have disassembled it and can tell you the motor core windings go to two posts of what appear to be some sort of fuse, and that's where the open circuit is in mine. (I bypassed it to test the motor, and it started up fine). Now I'm trying to figure out whether that fuse can be replaced.
Jul 04, 2010 | Vacuums
My shop vac blows dust as soon as it's turned on and throughout use. I have changed filters, nothing is helping. What part of my vac can not get wet, or is there a better way to clean out the system?
there should be a cover or sock over the filter,this will stop the dust.the paper filter is the part that can not get wet. if you don't have a cover for your filter use an old sock or something simular to a sock.
Aug 04, 2009 | Shop Vac 584-04-00 Quiet Canister Wet/Dry...
Hoover SteamVac quit working.
there is no reset button to this machine. in some cases if the machine stops or makes a weird noise or a smell like electrical, most likely it's the motor that went out or you could just have a switch that went out. if you didn't have any of these things happen, then take it to your local vac shop to get an est. done to see if would be worthe replacing the broken things or would it be better to buy another machine. hope this help's
Aug 01, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Shop Vac 285-00-10 Back Pack Vac Wearable Wet/Dry Vacuum Logo
3,267 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Jim Parker
Jim Parker
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
