Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Adding xp on same computer with vista
Xp pro already installed. When doing a vista install for dual boot you come to the place where vista says that the current operating system will be removed and it's files saved in another folder on the drive.
So how is it possible to retain xp? Vista wants to monopolize the operating system. Doesn't look like xp can co-exist.
  • gamc Mar 09, 2008
    Problem isn't having enough space. Plenty of room for both systems.
    Problem is how vista wants to do the installation. It won't allow another op system to remain on the computer.
    This is probably because microsoft won't offer support if vista isn't the sole operating system.
Y can also try first instal window xp and then instal vista it will be intaled its very simple
Posted on Mar 11, 2008
    Genius:
  • 1,027 Answers
Are you comfortable with running GPartEd, Gnome Partition Editor. There is a linux bootable cd for gparted, from there you chang partition size of the ntfs.
full instructions are on this site.
http://apcmag.com/5023/dual_booting_xp_with_vista
Make sure before you do this that you have defragged XP.
Posted on Mar 08, 2008
  • Mark Williams
    Mark Williams Mar 10, 2008
    For vista to be installed it has to have its own partition to go to, if you use vista dvd on the product key page, press SHIFT + F10 to launch a Windows PE 2.0 command window. Then type in DISKPART and press enter to get into the DISKPART utility.Now type in LIST VOLUME - this gives you a readout of the
    volumes available on the system. Select the main Windows XP volume
    (probably Volume 0) by typing in SELECT VOLUME 0. Now type in SHRINK. Vista will reduce the size of Volume 0 (the selected Volume) by around 50%
    Once that is done, type in EXIT and EXIT again to get back to the Vista installation window.
    If you've used DISKPART then you just need to continue the installation. Once the install gets to the install location,
    there should be at least two options: a partition marked as Primary and
    unallocated space. Select the unallocated space and click Next. The
    install will then commence.
    Once Vista is installed and the system reboots, you’ll be presented
    with a boot menu with two options: “Microsoft Windows Vista” and “An
    Earlier Version of Windows”.
Upgrading windows vista to windows xp in presario 115DX
You cannot 'upgrade' Windows Vista to Windows XP - that is technically a 'downgrade' and would need you to save all your user data on Vista then format you Windows drive then do a clean install of Windows XP.
If you try to install XP over the top of Vista you will have lots of problems because of the difference in architecture and boot manager changes.
The only alternative would be to set up a dual-boot installation where you install XP alongside Vista but would be best done on either a separate disk partition or on a second disk. Normally such a dual-boot configuration would start with having XP installed then adding Vista as the second operating system.
Jan 11, 2012 | Compaq Presario CQ56-115DX Laptop
Needs driver for vista or win 7 Sony VRD-VC10 DVD±RW Dual Layer Burner
Sony does not support this burner for any operating system for Win2k and XP. The VRD-VC30 is supported in Win7 but no earlier models (from the Microsoft Compatibility Center). The Vista Compatibility Center lists the VRD-VC20 as unknown for Vista support.
There are work-arounds. Install XP as a virtual computer or in a dual boot configuration on your system and install the hardware on the "XP box". If you have Win7 Pro or Ultimate, you can download and install the XP mode for a free virtual computer. (This requires you to download two programs from Microsoft and install them (Virtual PC and the XP mode itself). Otherwise, you will need a valid XP license to install in the virtual computer software. The dual boot may work better for you since virtual computers can't share files from the main computer directly. They need to be transfered to external media or a different partition or disc that unmounted from the real computer and mounted on the virtual computer.
I hope this helps.
Jun 25, 2010 | Sony VRD-VC10 DVD±RW Dual Layer...
While installing xp showing error
Hi Friend
Try this may help you in creating a dual boot.
First find the drivers for your network components, wireless card or nic, and save them to an external device such as a floppy disk or flash drive.
Then you will need to go into the BIOS on your computer startup. Scroll to the System Configuration tab and go down to the SATA Native Support and change its setting to Disabled. Then hit F10 to Save and Exit. (You don't need to change the BIOS if you have an ATA or IDE hard drive.)
Next, insert your Windows XPmag-glass_10x10.gif CD and create the partition you wish to install XP on. After the installation is complete you should boot automatically into XP. (To do this, right click the Computer icon in start, and select manage. Then select Disk Management, and you can do whatever you want with your partition.)
Now you need to move some files. First, make sure you have set your folder options to see hidden files and to show protected operating systemmag-glass_10x10.gif files. Then open Windows Explorer and go to the drive where Vista is installed. Copy the folder Boot, and the files bootmgr, boot.ini, NTDETECT.COM and ntldr and paste them to the root of your XP drive.
Then download Vista Boot Pro and save it to your desktop or somewhere else that you can easily access. Unless you already have .Net Framework (v2.0 at least) it will redirect you to a Microsoft page where you can download this necessary component.
Install and run Vista Boot Pro and open the "Bootloader" tab. Select "Reinstall the Vista bootloader" and press Apply. Then go to the Manage OS Entries tab and select "Add new operating system entry" and make sure you select "Windows Legacy". Give the new entry a name (ie: Windows XP) and select the drive letter you have XP on and then select Apply. You can also choose which entry you would like as the default the system will boot to.
And now you should be able to dual boot between Vista and a previous OS.
I hope this will help you out. Please vote for me.
Oct 06, 2009 | Compaq Presario Notebook
I'm using win2k pro sp5 can i do a vista upgrade?
How to dual boot Vista and XP (with Vista installed first) -- the step-by-step guide with screenshots
UPDATED | Got a Vista PC and want to install XP so you can dual-boot between them? Here's how to do it, in an easy, step-by-step format. Page 1 - Intro
Scenario: You want to install Vista on your PC alongside your XP installation, on the same drive. You have installed Vista already. (If you have XP installed first, check out our earlier tutorial on how to dual boot Vista and XP with XP installed first.)
Tutorial Summary: We need to shrink the Vista partition on the hard disk and create enough space for an installation of XP. This can be done in three ways - using the GPartEd Live CD, the DISKPART utility on the Vista DVD or the Vista Disk Management GUI - and we'll cover all three. We'll then install XP and install EasyBCD to reinstate the Vista bootloader which will be overwritten during the XP installation, and then use EasyBCD to configure Vista's bootloader to boot the XP partition.
Updated September 2008: This is an updated tutorial, based on our first Windows Vista/XP dual-booting workshop. The main differences are that we are now using Windows Vista SP1 and Windows XP SP3. EasyBCD has also been updated and this makes some of the steps in our first tutorial redundant - the whole process is now easier.
This tutorial has been tested on a VMWare 6 Workstation.
VISIT THIS FOR THE COMPLETE TUTORIAL :
http://apcmag.com/how_to_dual_boot_vista_and_xp_with_vista_installed_first__the_stepbystep_guide.htm
Mar 16, 2009 | Microsoft Windows Vista Ultimate Edition
Dual boot xp and vista on one hard disk
http://majorgeeks.com/VistaBootPRO_d5625.html
from here download vista boot pro ..and install it..there u can find option to add OS MENU while booting...
Feb 12, 2009 | Microsoft Windows XP Professional
On my pc running win xp pack2 i want to install win 2000 pro. how can i do it? please suggest me.
You can either run a dual-boot system where you can boot into XP and Pro when you start your computer, or reformat and install 2k.
If you want to dual-boot you would need a blank partition on which to install it. Unfortunately if you do not already have more than one partition on your current drive, it would be difficult to split a single partition drive into adding another partition unless you are familiar with the tools required to perform such an operation.
However, if you only need to install 2k without having access to XP, all you need to do is insert the Win 2k disk and follow the installation wizard. When it comes to selecting where to install, it should show a partition containing winXP, which you can then install 2K to. Remember, all files on your XP install, including the operating system itself, will be removed. You would lose everything on that partition. If it is a single partition drive, anything on the drive is removed. You should back up any files you want to save by either transfering them to a different drive if you have one, or burning them to CDs/DVDs.
Select the partition you want to install to (if it's a single partition disk, there will only be one listed. If there are more partitions, you can select a different partition to install to which would allow you to keep XP), and I would recommend selecting reformatting the partition to NTFS.
Once it is done reformatting and copying files, it will ask to restart. Restart the computer, but do not press any keys upon startup when it pauses to ask to boot from CD. Wait until the 2K graphical installer loads from the disk, and then you can follow the setup wizard for 2K.
If you have any questions or problems, please add a new post stating them, and I will try to answer.
Dec 14, 2008 | Microsoft Windows Vista Ultimate Edition
Trying to install xp on a vista
First, have you deleted Vista, or are you trying a dual boot?
Second, you do not have to disable your HDD or you cannot do the installation!
For a step by step procedure to install XP on a Vista computer (dual boot), please check here:
http://www.syschat.com/dual-boot-vista-xp-vista-already-1946.html
or
I do not recommend removing Vista completely,if that is what your laptop/PC came with, as most components and drivers installed will be Vista specific. If you need to have XP, make sure you have all the drivers for XP first.
May 26, 2008 | Microsoft Windows Xp Home Edition Sp2...
Not possible xp installation
How to Downgrade Vista to XP Downgrading from Windows Vista to Windows XP is almost like installing Windows XP for the first time. You should take all the normal precautions like backing up all your important files and record important passwords in a different place, preferably on a CD. When you downgrade from Windows Vista to XP, note that Windows Vista will be completely removed from your system.
(Note: There is a way to have both Vista and XP in a dual boot configuration, but that's an option for more advanced users. See Dual Booting Vista and XP for more info on that.)
Before you begin the XP installation, make sure that the necessary XP hardware drivers are available, or included on the XP disk provided by your PC vendor. If in doubt, check the vendor's website or poke around with your favorite search engine to see if others have attempted the XP install on the same hardware. You may be able to install XP without all the needed drivers, but some hardware may not work afterwards.
Also, make sure that you have a genuine Windows XP CD before you begin the downgrade. Be sure to read the section earlier in this article to see if you qualify for a low/no cost XP recovery disk from your PC vendor. If not, perhaps you have an XP disc that came with another computer. If you've upgraded an existing computer from XP to Vista, the best choice would be the XP install/recovery disc that came with that computer. One some PC's the vendor doesn't ship a CD, but the recovery CD can be created from disk images on the hard drive. If all else fails, you can always buy a copy of Windows XP on Ebay. Just be sure it's a legal, licensed copy.
Follow these steps to install Windows XP on your Vista machine:
  • Insert your Windows XP install/recovery CD and restart your computer.
  • Install Windows XP normally, providing either the product key that came with the disk, or the one you got from Microsoft customer support. If the installer warns you that another copy of Windows is already installed, don't worry. Remember, this install will wipe out your existing Vista installation.
  • Activate your copy of Windows XP when it prompts you to do so. If you run into the "already activated" problem, you can use the option to activate by phone.
  • If you own Vista Business or Vista Ultimate, explain to the rep that you want to use your Downgrade Rights to install XP Pro.
  • If you own Vista Home Basic/Premium, or you are installing XP Home Edition, don't mention ANYTHING about Vista. Just give the rep your XP product key (not the Vista key), explain that you are installing XP on a new hard drive, and tell them you need to activate.
Mar 30, 2008 | Computers & Internet
Dual boot/hard drive seetings
Install first the media center on the primary harddrive with master jumpered.. when everything is working fine... then proceed to
the next harddrive. Set its jumper to slave not cable select and install xp pro, it ask you for an option to have dual boot then select the location of windows to be installed...
Hoping this helps... Fixya!!!
Feb 02, 2008 | Maxtor Hard Drive
Install xp pro
windows xp cannot be installed on a system with pre loaded vista . because the boot loader of xp is older than vista as it cannot create boot loader . the order of installing operating systems is from LOWER 2 HIGHER ie XP to VISTA . first of all u nedd to format drive containing vista and then try installing xp
Dec 14, 2007 | Creative Labs Sound Blaster Live! 24-bit...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
64 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
