try to set your channel to either 1 or 11.set also your router's broadcast setting to 'mixed'.place your wii near router with no interference from microwaves or such.if router setting is set up to allow only selected pc's (or mac addresses),don't forget to include wii's mac address to enable it to have access to the router.if your router password type is wpa,make sure also you know whether it's wpa-psk AES,wpa2-psk AES or wpa-psk TKIP,you need to consciously choose the right one on your wii internet setting.also,you could switch the dns ip addresses around like put 2nd ip address in primary and 1st ip address in secondary.no guarantees,hope this helps.
keep getting this message trying to setup wii. 'a error has occurred,press the eject button and...
(More)
keep getting this message trying to setup wii. 'a error has occurred,press the eject button and remove the disc,then turn the wii console off and refer to wii operations manual for help troubleshooting,'
