Question about Nintendo NES Console
NES back connection problem
The connection in the back is loose you have to put the NES at an angle (resting on the wire connection) for there to be an image on the tv. It is not the wire, how can this be repaired?
    Problem Solver:
  • 6 Answers
The rca jacks on the console has two little prongs inside them. They are probably bent and need to be straightened.
Posted on Mar 09, 2008
Super nintendo
Original-Style Super NES RF to VCR Hookup
Installation Steps:
Locate the VCR's VHF IN [ANT, CATV, 75S(ohm)] or Cable Connector.
Disconnect the existing cable wire from the VCR's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your VCR's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire from the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the VCR. Note on Sharp TV/VCR Combo
After the system is connected to the VCR:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn your TV and VCR on. Set up your TV and VCR the same way you would to watch a movie on the VCR.
The game image should now be displayed on the TV screen. You are ready to play!
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck using the Stereo Audio/Video Cable.
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Feb 10, 2013 | Nintendo Super NES Console
NES controller input
Installation Steps:
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the NES (labled RF Out).
On the back of the NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
After the system is connected to the TV:
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Press the Power button on the front of the Control Deck.
Turn on the TV and set it to the appropriate channel (3 or 4.)
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Mar 02, 2012 | Nintendo NES Console
How do you hook up the super nintindo console to the tv?
Original-Style Super NES RF to TV Hookup
hook_sns_rftotv.gif Installation Steps:
  1. Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
  2. Disconnect the existing cable wire from the TV's VHF IN.
  3. Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
  4. Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
  5. Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
  6. On the back of the Super NES, set the 3/4 switch so that it matches the channel of the TV.
  1. Insert the Game Pak firmly into the Control Deck.
  2. Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
  3. Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
  4. Slide the Power Switch to the On position.
  5. Turn on the TV and set it to the appropriate channel (3 or 4.)
  6. The game image should now be displayed on the TV screen. You are ready to play!
Jan 13, 2012 | Nintendo Super NES Console
I have the first nintendo nes and i dont have the rca's i have the one you hook through the cable and it comes on but i cant find the channel to put it on to play the game ! What am i doing wrong ?
Installation Steps:
Nov 25, 2011 | Nintendo Super NES Console
Eu tava com o super nintendo ligado e ele espludiu a fonte
Aug 21, 2011 | Nintendo Super NES Console
I have an older (1988) Motor Home with a Ford 460 engine on a John Deere chassis. I am having trouble with the ignition system start/run function. I am looking for a wiring diagram for the system and...
I would assume that you have checked that the wiring connections to the switck are secure. Sometimes the spade terminals in the connector plug to the switch come loose and get pushed back inside the plug when it is connected. They are held in place in the connector block by a little tab that angles up from the metal part. Gently push then pull on each wire in the plug. There should be a little or no movement.Iif any are loose it will be obvious. I the connections are OK then the Switch is probably badly worn and needs replacing.
Aug 18, 2010 | 1988 Ford Ranger
NES system doesnt work with my t.v.'s. i have plasma samsung and a symphonic 20" older t.v. that it doesnt work on either can you tell me what to do?
NES to TV Hookup
Installation Steps:
Aug 06, 2010 | Nintendo NES Console
My nintendo nes works fine but when i put in mario/duck hunt i can choose which one i want to play and when i choose mario it gose to the next screen where you choose 1 or 2 players and this is where i...
Will try cleaning the game packs out with quips and vinegar try connecting it to a DVD player or a VCR then.
Installation Steps:
Connect the thin wire from the RF Switch (labeled Control Deck) to the back of the NES (labled RF Out).
On the back of the NES, set the 3/4 switch so that it matches the channel of the VCR.
Apr 14, 2010 | Nintendo NES Console
I have changed the pin connector on my nes, it does not flash anymore but now i get a blank screen can someone help me?
First try connecting through the av ports on the side of the console rather than the RF port on the rear of the unit.
If that doesn't work then your problem is likely a loose connection inside, go back in and reassemble.
I have had this issue with several consoles; these two solutions usually take care of it, though in rare cases a defective 72 pin connector was at fault even though it was brand new.
Good luck.
Mar 31, 2010 | Nintendo NES Console
Screen turns off when opened
There is a thin ribbon cable that runs between your screen and the rest of the laptop. every time you open/close the lid it flexes that cable.
Something in your cable is coming loose, it could be that a wire in the cable is broken and connects only at certain screen angles or perhaps one end of the cable is loose.
You need to take the bezel off to get to the cable, verify that the cable is plugged in, if the problem still occurs then replace the cable.
You should find the cable fairly cheaply on ebay, search for acer "model" lcd ribbon cable.
Let me know if this helps.
Mar 24, 2010 | Office Equipment & Supplies
Nintendo NES Console Logo
69 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
