I was watching a movie and all of a sudden it froze. The DVD was stuck inside, and would not eject. I turned off the whole unit, but it keeps turning itself back on. I also tried unplugging the machine, but it did not work. How do I unscrew the casing of a Philips DVD750VR to remove the DVD manually?
  • 1,512 Answers
First disconnect the power
Posted on Mar 08, 2008
  • Graeme Ross
    Graeme Ross Mar 08, 2008
    Then remove the lid screws. You may then have to remove the screws that hold down the transport and turn the transport over to access the large drive cam for the drawer. Rotating this large gear will open the drawer and release you DVD. If you have any dramas, please ask me here and I will assist you further
    Good luck
    regards
    Graeme
Toshiba SD-6100KU2 DVD Player keeps freezing up.
check blu ray dvd for finger prints or scratches. may need to clean the dvd disk with a soft cloth with pure alcohol or metho.
Sep 22, 2016 | Toshiba Televison & Video
What's wrong with my sony dvd player?
I would just replace it rather have repaired even if that's possible , they don't cost a fortune and are easy to fit.
Oct 20, 2014 | Sony Televison & Video
I can't eject a dvd from a JVC player because movie I was watching kept freezing.
Unplug player from wall receptical, and detach any other leads that plugged into it, press and hold power for at least 2 minutes in an attempt to clear the microprocessor controller ic, if this fails! you may have to take the top off to manually eject the DVD.
May 04, 2012 | JVC XV-N310B DVD Player
Flashing Red Light
take of the top then take out the disk drive and pull the game out. Then send it to Sony to have them fix it.
May 09, 2010 | Sony Playstation 3 (PS3) Console
DVD player suddenly stopped working
Turn unit off and unplug, then plug back in and keep finger on eject button, and then hit the power button.  Nothing?  Get your phillips screwdriver and remove the shell.  Then retrieve you disc.  While your in there look for signs of a burned capacitor off the ic port chip and take a little glass cleaner and clean the optical lens with a micro fiber cloth.
Nov 15, 2009 | Philips HTS3500S System
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
DVD side won't load to play
yea, your going to haft to reuturn the unit and get a new one. some times the lens messes up like that, sorry
Jan 08, 2009 | Symphonic WV806 DVD Player/VCR
Hts 3450 home theatre system- dvd in player- but won't come out
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Dec 10, 2008 | Philips HTS3450 System
DVD Stuck in Player
While the above problem is not in the manual, I would try pushing and holding down the Open/Close buttton for an extended period to see if the unit will 'unlock' itself.
Mar 16, 2008 | Sanyo DWM-390 DVD Player
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
Electro Med Services...
