Question about Brother FAX-575 Plain Paper Thermal
I have problem with a quality of fax
When I transmit a fax whoever is a reciever has black vertical lines 4" wide on the left. I have "Brother" 625. Thanks
  • 168 Answers
Make a COPY and see how the copy comes out. If you see the same black vertical lines that other people are seeing, then you probably have something like whiteout on the scan glass.
Open the fax top cover where you feed your originals, and then look inside for a piece of glass about 10" long by 1/2" wide. Then I would try cleaning the glass with rubbing alcohol and also go over it again with windex.
After cleaning the glass, try making another copy to see if it has improved. If it has, but still has more lines, then try re cleaning the glass.
Hope this helps.
Good luck.
Mac
Posted on Mar 08, 2008
I have a vertical strip about 3/16" wide about 3/4" from the left side of the page that will not print in the black only. I have replaced the black toner and black drum unit, and it is still there.
The LED Assembly LU5831001 is probably bad. This machine has 4 LED assemblies mounted in the top cover. It doesn't use a laser scanner.
To troubleshoot, you can clean them, then swap them between colors before you buy it.
25296363-yargu4yf5zncljh0zgcte5yj-3-0.png 25296363-yargu4yf5zncljh0zgcte5yj-3-2.png
Nov 24, 2014 | Brother Hl3070cw Hl-3070cw Color Laser...
Black vertical lines on transmitted faxes.
Just go to menu and then in tools...run alignment and clean them....
Jun 29, 2010 | HP 1040 Plain Paper Inkjet Fax
Line goes through page when fax is sent
Open up the document feeder and clean the small glass. If the line is more than 1/4 inch wide you have a bad scanner block.
May 13, 2010 | Brother IntelliFAX 2800 Laser Fax
Black line on page vertical on receivers end
May be you have, a trash or something on the scanner glass or scanner section lamp.Try to disassembly and clean the lamp.
Jul 21, 2009 | HP Photosmart C5280 Printer
Black vertical stripes on copy
Replace the drum unit, you've done all the cleaning you can do.
Jan 23, 2009 | Brother IntelliFAX 3800 Plain Paper Laser...
3-INCH WIDE VERTICAL LINES RUND DOWN LEFT SIDE OF FAX MACHINE
Do your incoming faxes have the same marks?
If not you might find that the scanning part of your machine has a dirty mark on the glass or that the unit has become faulty.
Try and take a copy from the machine and print from a report or any print from memory.
If you have the black lines on both then i'd suggest getting a new drum unit, if u have it only on the copy I would have a look at your scanner glass and see if there is a dirty mark on it. if not maybe call out an engineer as the scanner unit maybe faulty.
Need anymore help msg me.
Dec 11, 2008 | Office Equipment & Supplies
Transmitted pages are too dark, practically unreadable :
I suspect your scanner unit is going bad or it is extremely dirty.
Making a copy gets same result as when you send.
Nov 01, 2008 | Brother FAX-8360P Plain Paper Laser
Even vertical lines on fax/copy
TYPICALLY SF900 FAX USES A DIFFERENT CIS SCANNER , THSI SORT OF INDICATION IS EITHER SMPS BAD OR CIS SCANNER BAD. HAPPY FAXING OMNIRESENT
Sep 16, 2007 | Panasonic KX-FHD331 Plain Paper Thermal...
Brother FAX-575 Plain Paper Thermal Logo
119 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
