Question about Princeton Digital VL1812 18.1" Flat Panel LCD Monitor
Monitor will not display
My Princeton Model VL1812 will not display when I boot up computer. The green power light is on. If I turn the monitor off with the monitor power button the CPU beeps continuiously.
  • 7 more comments
  • rpmedina1 Aug 13, 2008
    My Princeton model V1812 has an unlit screen. The power on light goes on and off at a regular rate, whether you push the button or not. I suspect a power supply problem. However, I cannot open the monitor up to view the inside. There are four screws, one at each corner, but the two halves will not separate even with all four screws removed. Does anyone have a tip for opening it up without damaging the case?
  • Anonymous Sep 15, 2008
  • Anonymous Sep 28, 2008
    Same issue - Screen would not come on, electronics appears to work(green light on), top of the screen seem to have some yellow back light. Remove 4 screews, black cover does come off (watch that the black cord is not holding it on). You might remove the screws in the base (through oblong hole in base), then remove base 4 screws through mount - these don't appear to be holding anything but made it easier to remove black back (also note black back pulls away from silver front - not the other way around - pull from bottom center of black frame)
    As to the real issue - screen does not come on. Nothing obvious to fix. I was hoping there was something obvious that could be exchanged to test out as I have 2 of these monitors with one still working. But allas we live in a throw-away society (and new 22" screens go for about $280 these days makes it hard to spend a lot of time salvaging something small with lower resolution. Good Luck!
    Ok That fixed it! Bad power supply - I now have the other montior working. Just swapped the power supply (real easy - just 4 screws and the two easy clip connectors - one from the Power cord, the other to the main electronics / controller board)
  • bdeluke Sep 30, 2008
    won't display
  • Anonymous Oct 02, 2008
    Ok - Found the issue in the Power Supply - component I801 Bad Power Switcher (4 pin w/FET on the large heat sink above the large Capacitor on the board). The PN is a Fairchild 1M0565R which I purchased online at http://www.bluestar-online.com/1M0565R_p... for 4.99 each.
  • Anonymous Oct 05, 2008
    I had a similar issue after I pushed the brightness up, evidently too far - screen when blank and stayed blank - I had to lower the brightness "blind". so try this - turn off and on the monitor (reset) hit button 1 (far left button), a menu is displayed even if you can't see it. Hit button 4 (the right most in the group of 4) twice - selects brightness, hit button 2 a bunch of times to reduce brightness. Hit button 1 twice to exit (2 menus) power off and on and see if that helps.
  • jlvb1 Sep 23, 2009
    How do you take the back off of a Princeton VL1812 LCD?
Hello, tech support online at Sony was able to help me correct the problems.
Posted on Mar 09, 2008
Where can i finde the vga cord the plugs from the computer into the motherboard of my princeton vl1812
We have that cable in stock. You can get more information at:
http://www.ccl-la.com/catalog/product_info.php?products_id=54
The cable runs $4.50 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Nov 16, 2010 | Princeton Digital VL1918 Monitor
Service Manual with Schematics for Princeton VL1916 LCD Monitor
this issue might not be because of your Monitor. Anyway, I can only provide manual to this legacy product of princeton if you want...
Sep 06, 2007 | Princeton Digital VL1916 19" LCD Monitor
The monitor shuts off. Turning the power off
the monitor is going into power saving mode ... it can happen if it is not receiving any signal from the pc ( pc is not running or booted properly, bad video cable connection monitor to pc) or the pc is itself in suspend/standby mode.
Aug 08, 2009 | Princeton Digital Computers & Internet
Same problem
Check the Inverter card Connector which goes to pannel,Next Panel to AD card signal Cabble,..
Jul 10, 2009 | Princeton Digital VL1918 Monitor
Princeton VL1715-1 no display
From what you say there is probably not much you can do with it, the parts inside are SMD, to small
to work on. If you could still see txt on the screen when you shine your torch, it could be fixed by
replacing the back lighting PCB.
Hope this helps
Have a nice day.
Dec 22, 2008 | Princeton Digital VL1812 18.1" Flat Panel...
Monitor does not turn on automatic
change your power cable.
also check your power suply and earthing.
Nov 19, 2008 | Princeton Digital VL2018W Monitor
Monitor will not come on
Most of the tiime if the monitor has a blinking green or amber light there is a problem with the signal going out to the computer. there are 2 ways how we can determine if the it is an issue with the monitor or the video card of the computer.
Since, we have a new monitor cord that could eliminate the possibility that your monitor cord causes the problem.
1. Try disconnecting your monitor from the computer and check for the green blinking light
2. Try connecting a different monitor to determine the issue.
Keep me posted.
Jeff
Oct 12, 2008 | Princeton Digital VL1812 18.1" Flat Panel...
Not getting any Video or Sync. Power light does come on green but just fades in and out when PC is on and off. VGA connector does appear to be missing a couple pins. Same issue on multiple PC's (Laptop and...
I have same problem, believe it to be capacitors on the power supply have slowly leaked over the years (mine is Oct 2002).
Some may having bulging capacitors visible. Replacing the bad caps should resolve long start up time.
Nov 08, 2007 | Princeton Digital VL1812 18.1" Flat Panel...
PRINCETON LCD-15BLK MONITOR
Looks like one of your backlights is bad, first indication is the red or pink tint, replacement of the lamp is fairly easy. If one lamp is bad the inverter will not work. You can get a replacement lamp from Mouser electronics for about $12
Sep 27, 2007 | Princeton Digital VL180 18.1 in. Flat...
Open Questions:
Princeton Digital VL1812 18.1" Flat Panel LCD Monitor Logo
366 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
