Air Conditioners
Problem for Air Conditioners
Generic problem for all Air Conditioners
Panasonic air conditioner
By hawnrob on Mar 08, 2008
my a/c drips from the front. no water dripping from the back
Solution #1
posted on Mar 08, 2008
Not Rated)
Slinteriors
Rank: Guru
Rating: 89%, 3689 votes
You will have to check the rear drain hole to insure it isnt plugged. Also just tilt it a little further towards the rear that should take care of your problem. There is a small hole inside the unit in the back that drains a leaf or something has clogged the hole causing it to run out the front.
Popular Solutions for Air Conditioners
Questions and Unsolved Problems for Air Conditioners
Answer
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a... (More)
Answer
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at... (More)
Answer
We are having trouble setting the thermostat on a ambiance amac 12,000 portable air conditioner. Do... (More)
Answer
lost manual for hotpoint 1400btu portable air con and would like to know how to get another. aircon... (More)
Answer
air con keeps turning off swing and timer lights will flash while it turns off
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air Conditioners:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
