THANK YOU!!!!!! I got it working! You were right it was the Convergance ICs.  Its perfect now, so I just wanted to thank you for your quick responces.  And for someone who has never even touched a circuit board or soldering stuff in his life, like me, you gave me amazing instructions.  Great job!  Any recommendations on how to not let this or anything else happen to my TV again? Thanks, Omar
  • 8,617 Answers
Youre welcome, and congratulations on fixing your set. No advice on prevention, just remember that if your set does exhibit any warning signs its better to shut it down and do some investigating and you will save yourself alot of money in repair bills. Enjoy watching the TV that you have fixed. It sure does feel good to have it back to normal doesnt it. Glad I could help you out.
Posted on Mar 08, 2008
  • Sonny Berry
    Sonny Berry Mar 08, 2008
    P.S. dont forget to give me a rating on this. talk to ya later.
Panasonic PT-47WX53 has intermittant convergance issue
I would chack the solder connections at the convergence ICs first. Since the set "recovers" on its own, it suggests a connection issue rather than a defective component. Also, if the ICs were installed without sufficient heat sink compound, this could happen as well. Look at low valued resistors in the area of the ICs for signs of overheating as well.
Keep us posted on your progress.
Dan
Oct 19, 2009 | Panasonic Televison & Video
Panasonic rear projection 47 inch
hi you are right this is common fault what needs replacing is the convergance ics theirs 2 of them but whils replacng these you will need any resistors checking for damage also as when the ics start to fail then its usually because a resistor has blown somewhere on the board causing the power to rise or fall and this causes the ics to fail
Feb 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Heater & window defroster does not produce heat
Thank you for your quick responce, I must delay working with you on a fix, if i can keep this open it would help for a later date.
Thank you again.
Paul
Jan 14, 2009 | 1997 Pontiac Trans Sport
I have a convergance failure on my 52" mitsubishi rear projection TV. How do I fix it?
you will need to replace the convergence ICs. You can get replacements at the following link with free installation instructions, and If your not sure which ICs your model uses, leave them a email with your model number they will respond quickly.
http://servicemanuals.vstore.ca/
Sep 01, 2008 | Televison & Video
Sony HS30 Convergance Issue
The STK ICs are located on the D board their locations are IC801 and IC 802 they are both STK392-560 and you will only have to remove the D board. Usually only 1 or 2 resistors go bad right next to the ICs heatsink. You can get replacements at the following link and they include installation instruction plus free tech support heres the link.
Apr 07, 2008 | Sony KP-46WT500 46" Rear Projection...
FIXYA PROBLEM
Usually when your convergence ICs go they take out 1 or 2 resisitors right next to the Ics. The tower your refering to is a capacitor. it should have a rating stamped on it such as 50uf @50 etc. Hope this helps
Dec 30, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Tv is dead
Hi, Yes! the convergance board can stop the unit from coming On. No need to change the board, just change the ICs. This is what it looks like,you will have to remove the board from the unit take note of the wires before removing them, -794a500.jpg
Nov 14, 2007 | Samsung HCN4226W 42" Rear Projection...
Convergance
Your convergence amp ICs are bad. You will need to replace both of them. Its an easy fix if you can solder. Check the resistors right next to the ICs also often 1 or 2 of them burn open when the ICs go out. Let me now if I can assist you further.
Sep 02, 2007 | Zenith R40W46 40" Rear Projection...
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
