Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Bosch Dishwasher model : SHV...
By clarelou on Mar 08, 2008
Bosch Dishwasher model : SHV4313GB/17
The machine won't switch off and the pump is still trying to drain water ( there is no water left in machine )
The cycle seems to have finished as it has made the beep sound as if it has finished. The dishwasher is still working even when you open the main door. Have tried to reset it but to no avail. Even after turning it off at the mains it still starts up again as if in mid cycle !
HELP PLEASE
Same Problem
Nov 15, 2008
-   I have the same problem with my SHX46A. My repairman had replaced the valve at the front left of the bottom module, but it did not stop the problem. At the third visit, he decided the cause was due to using old Electrasol tabs that resulted in over suds. I tested the dishwasher without any dishwasher detergent and still had the same problem. He then told me that he would consult with other technicians. My problem remains.-   ddw308
Best Solution
posted on May 09, 2009
Very Helpful)
MontpelierVT
Rank: Apprentice
Rating: 100%, 3 votes
I have a SHV. My sink drain backed up, and the water accumulating in the sink then migrated to the dishwasher, through the drain pipe, causing the dishwasher to fill up and, it turned out, overflow a little. When I turned on the dishwasher, the water drained, but no new, clean water came through the hot water pipe. The drain just kept running, but nothing else happened.
Here's what happened. Under the main chamber of the dishwasher, by three inches or more, is a white plastic tray. It sits almost at the floor, and it may not be obvious that it's a tray capable of holding water. The overflow water spilled into that tray, which in turn caused a float in the far left side of the tray to lift (the way a toilet float lifts when the water fills in a toilet tank) and shut off the water intake valve (like the toilet float shuts off the toilet water flow). So long as that valve is closed, your machine will not run.
STOP: disconnect power supply at this point for safety.
To see the white plastic tray and thereby fix the problem, you'll need to take off the BLACK TOE-KICK (attached on my unit by two star-head screws at its bottom) and, possibly , the OUTER PANEL OF THE DISHWASHER DOOR (in my case, a custom wood panel (attached by a few screws through the inner side of the door, two screws that are accessed by popping off little--smaller than a dime size--covers on the sides of the doors, and then the door panel lifts up and out). (I took the outer panel off, but I can't remember if I would have had to reach into the white tray without doing so.)
Once you do that, you can see the white plastic tray. It doesn't come out--at least not without removing the entire machine--so try this. You can take your fingers and feel over and into the tray. You'll probably feel the water--I did. Look at the far left of the tray with a flashlight. Back there you'll see a flat, round, 3-inch diameter piece of white plastic sitting at the bottom of the tray. To its center is a generally U-shaped lever looking device, which, at its far left end, is connected to a red stick pointing up into the machine. When water goes into the tray, the float rises, causing the U-shaped lever to rise, causing the red stick to raise, which (though I couldn't see it) causes an electrical signal to run to, and shut, the valve for your water intake.
I took paper towels, and then a narrowly cut sponge, to sop up the water in the tray. I then took my shop vac and, using it as a blower, blew what little water was left right out. You might be able to use a hair dryer, but first sop out what you can or it'll take forever. Once you've done that, put everything back together and plug your dishwasher back in. My buttons are at the top panel. To reset, hold down the two buttons marked for clear drain for three seconds and release. You should be able to start up then. It took 15 seconds before the water started to run, but it did and the machine works fine again.
Interesting note: The valve that stopped the water from flowing in automatically opened once I got the water out of the tray. You don't need to reset the valve.
Good luck.
Montpelier Man
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 27, 2008
Very Helpful)
aquakdj
Rank: Apprentice
Rating: 100%, 1 votes
I am having a similar problem with our Dishwasher, although not the same model, they all have the same basic principals for operation. We have a Bosch SG13002GB/10 which is fitted with, what Bosch call "AquaStop"! This is a safety feature built into the base of the machine for the unlikely event of the unit developing a leak. There is a sealed chamber under the machine fitted with a float, when a leak occurs the water is channeled into this chamber where the float, when activated, cuts off the inlet water supply valve. In the event of a leak occuring during a wash cycle the drainage pump will continue to run even when the cycle has finished to ensure the machine is completely empty before any repairs are carried out. Check the operating manual for your machine to identify whether or not it is fitted with this feature.
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
When I turn the machine on, the drain pump works and my program starts. However, there is no water... (More)
Answer
How do I reset miele dishwasher - drain pipe now unblocked but will not commence cycle
Answer
dishwasher programme trips out during operation, tripping the fuse constantly when tring to restart.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dishwashers:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
